Old 04-29-2019, 03:18 AM
  #40376
Hobbsy
Hobbsy's Avatar
Colt 40
I've been brain stormin about what to do with the Saito 50 I have been running lately. I've got it, I have a NIB US Aircore Colt 40 that would be perfect for it. I had one several years ago with first, an Enya 46 MKII, then a Super Tigre 51 Diesel conversion. The Diesel exhaust eventually took all the paint off the right side. I think I'll build it and use the 50 that way. It's a great flyer, landing is simply a matter of throttling back and when about a foot from the ground, go to idle and it settles down as smooth as silk.
Old 04-29-2019, 03:29 AM
  #40377
Hobbsy
Hobbsy's Avatar
Well, as I said I don't care much for the bent wire method, that is simply my preference, it is a simple easy method though. On some installations, when I want the throttle servo low in the fuse I use a double ended servo arm with the servo rod on the bottom and the throttle rod on the top.
That picture of the Duc may end up gone if it starts a MC binge. Not by me though.
Old 04-29-2019, 03:30 AM
  #40378
Captcrunch44
Originally Posted by the Wasp
any one know what's going on with JR, are they out of the hobby for good ??
I would like to buy some XBus 2 and 4 port cables but I can't find any
Jim
JR the company is gone
but DeForce has picked up there engineers and the JR name. Now they are producing radio’s and receivers under JR pro / deforce. They have all the X-Buss stuff that JR started. It all works great I have the JR/Deforce Radio equipment in several airplanes
i haven't messed with X-Buss yet but it sounds cool as hec.
Old 04-29-2019, 03:32 AM
  #40379
Hobbsy
Hobbsy's Avatar
Thanks Mike, may Deforce be with you. I am loaded down with JR stuff and a lot of Hitec servos.
Old 04-29-2019, 03:49 AM
  #40380
Captcrunch44
yeah me too I have a couple dozen receivers on 72 and 6 of the radios I still use. Manly the 9303,8103,8103 with 2.4 module. But this last year I picked up an XG 8 and I am starting to get comfortable with that system. The battery telemetry is pretty neat always knowing what’s on your receiver pack is comforting.
Got to keep those Saito’s in the air with the best equipment out there.
Old 04-29-2019, 04:23 AM
  #40381
BarracudaHockey
BarracudaHockey's Avatar
Just a friendly reminder to keep the theme about Saito engines and not motorcycles
Yes, the thread drifts out and back a little sometimes but lets try to focus.
Thanks!
Old 04-29-2019, 04:39 AM
  #40382
Glowgeek
I have a NIB US Aircore Colt 40 that would be perfect for it. I had one several years ago....... It's a great flyer, landing is simply a matter of throttling back and when about a foot from the ground, go to idle and it settles down as smooth as silk.
I saw one those cloroplast jobbies at a fly-in a couple of years ago. Looked like it flew very nice and the guy said he'd had a couple of them over the years. Said it was a very tough airframe.
Old 04-29-2019, 05:26 AM
  #40383
Jesse Open
Jesse Open's Avatar
Countersink s, used with flathead screws.
The u-turned rod sometimes stutters from being too springy. The swing lever as I have shown and the Dubro are very precise.
Of course, trick is just making it right. Once you have the knack they work very smoothly. Many folks use too large wire . I have only used the DuBro once and picked up on the trombone setup. It was worth the tinkering in the long run.
In most cases you can avoid using either.
Here are a few pics of Counterbores VS Countersink tools. Not unusual for folks to get the two crossed up
Counterbores using interchanges pilots to allow any diameter counterbore with any bolt diameter.
Counterbores are also called \"Spot Facing" to provide a flat seat on irregular surfaces.
Old 04-29-2019, 05:29 AM
  #40384
Hobbsy
Hobbsy's Avatar
The cargo belly was optional too, I did not opt for it though.
The first one I had was the Knight Hawk with the optional flaps, powered by an Enya 46 MKII first then later by a SuperTigre 51 Diesel conversion.
Old 04-29-2019, 05:40 AM
  #40385
Jesse Open
Jesse Open's Avatar
Pete
You take the high sliders, they seem to hurt about the most. I'll take the low side
Hopefully the "counter" thing sunk in.
Hard to know......,
Old 04-29-2019, 05:46 AM
  #40386
Hobbsy
Hobbsy's Avatar
I did some nosing around and there are a lot of Wanted ads for US Aircore planes with some noting they will get Saitos. I'm am surprised there are still some around.
Old 04-29-2019, 06:08 AM
  #40387
Jesse Open
Jesse Open's Avatar
I am waiting on the next batch of Tharpe Flyin King planes. Gotta go YS with this one
Will be listing one of my FA-182 twins and one of the 100 teins, both are brand new.
Old 04-29-2019, 06:24 AM
  #40388
acdii
You guys are overthinking the throttle setups. Just use a throttle cable. I have a couple where the arm nearly touches the firewall, and with a little slotting, a cable works perfectly, that and I can put the servo just about anywhere and route the cable around the tank and batteries. So far the only plane I have not used a cable on is the B-25 engine pods I just finished. I can use a wire push rod for those since it is a short direct path to the throttle arm.
Old 04-29-2019, 06:30 AM
  #40389
Hobbsy
Hobbsy's Avatar
Flyin King's are graceful flyers, my first one went through a dead pine tree going backwards, the stab and the wings were reduced to fuse width in a hurry. I had been flying it with a Fox 74 Diesel conversion and then pulled a bonehead move by not replacing the Tygon clunk line when I installed the Saito. The glow fuel hardened the Tygon and the clunk was sticking straight out into center of the tank, when the 80 went lean it kicked back, spun the Harry Higley Heavy hub off and went tail heavy with no thrust. I have another one ready to cover, just needs some minor sanding, I think it will get a 90-T. I built both with nose gears.
Old 04-29-2019, 06:42 AM
  #40390
Hobbsy
Hobbsy's Avatar
Here of late I've been using these little fellers as throttle servos, so easy to mount.
Cute little guy
Old 04-29-2019, 06:51 AM
  #40391
Jesse Open
Jesse Open's Avatar
Not really. I use flex cable,same as you in almost every situation, especially since I rarely build real small planes the call for anything else is all but history.
With the Saito, flopping the carb so the arm is closest to the outside wall and placing the servo in a direct straight line behind makes for very easy going.
There are some cases, usually with the 20 to 30 size planes where something different simply works better. At that point a little thought never hurts.
I always use high resolution and very fast throttle servos. I like brisk response in that area.
Hey Dave, how about a Laser for the FK? Got a clean one for cheap.
Old 04-29-2019, 12:51 PM
  #40392
Hobbsy
Hobbsy's Avatar
I just sold a LASER 100, fine engine, just no need for. It was 7 oz heavier than the Saito 100 and a couple of hundred rpm weaker.
Old 04-29-2019, 01:23 PM
  #40393
acdii
Cute little guy
Wondering now if the Hitec HS645MG is overkill for the throttle servo. I certainly don't need the torque, just the metal gear for vibration reasons since it's gas. Would rather use Futaba 3004 instead.
Old 04-29-2019, 03:02 PM
  #40394
Hobbsy
Hobbsy's Avatar
I haven't tried these but even that little guy has a metal gear brother.
Old 04-29-2019, 04:25 PM
  #40395
Jesse Open
Jesse Open's Avatar
Resolution and speed are what I look for in a throttle servo. Most standard servos have surplus torque.
Yes sir , Lazy Lasers are just that Dave, overweight and short on power. Been saying that a long time.
Old 04-29-2019, 07:28 PM
  #40396
the Wasp
thanks for the info on DeForce, I forgot about them, I called them some 4 or 5 months ago, but no XBus, I will check out their site and call again
Jim
Old 04-29-2019, 07:48 PM
  #40397
the Wasp
Dave, I have a couple Airtronics 94141 wing servos, with only 2 flights on them, they are small and light, I have JR adapter plugs on them, they sell for $60. I was thinking about using them of the throttle of my mustang and VQ P-40
https://servodatabase.com/servo/airtronics/94141z
Jim
Old 04-29-2019, 08:04 PM
  #40398
the Wasp
Woo Hoo, me get-n me some XBus, cause I got me a wing with 6 wires, 4 servos and 2 retracts, it will be really slick having only 1 wire to hook up when mounting the wing
oops, an edit here, the retracts will be using a Y-harness that came with them
now I got to come up with names for the M-Mustang and the P-40
https://www.deeforce.net/product-pag...-4port-xb1-cv4
Jim
Old 04-30-2019, 02:50 AM
  #40399
Hobbsy
Hobbsy's Avatar
Jim
Good find to put on a hopped up Saito powered Bosstang.
Old 04-30-2019, 03:12 AM
  #40400
Captcrunch44
Yup
you can’t call it a Hogasaki that’s taken. Lol
Mustysaki sounds cool
