Great planes ultimate 160
#4026
My Feedback: (32)
RE: Great planes ultimate 160
ORIGINAL: dougpeck
Sorry Bubba, I am using DA50R .. I know it is slow but am trying to sneak up on full bore giving engine plenty of time to break-in....I'm probably too conservative but haven't done any fix on wing problem yet ...
On a glow engine running it sloppy rich works well, on gas it could actually cause problems.
Again I mean no disrespect at all
#4028
SC
Today's question??? Why is it that you can run a weedeater engine, a chainsaw, a leafblower and numerous other implements operated by 2 cycle engines and never clean it, never change the plug until it gets so fouled it won't run, never clean the air filter, throw it around like it was yesterdays newspaper, and it just runs and runs without missing a single beat, but take the same engine and put a prop on it and it wouldn't run for crap?? [sm=biggrin.gif]
RMFLYFISH...you are welcome. Thats what we are here for...to share ideas and tricks. [sm=idea.gif]
#4029
IA
Not sure what this has to do with the Ultimate, but I'll play along anyway.... I think you'd be surprised at what brands of 'model' engines are simply chainsaw cylinders and cranks, some with fancy machined or cast cases, some with the stock ones. They're doing just fine with props on them
It was said recently that we should worry more about crashing our planes, than replacing parts in our gas engines. If they are even half way taken care of, they will outlast us.
and to keep this related to the Ultimate 1.60....I'm one of those with a garden equipment chainsaw engine in mine
#4030
My Feedback: (32)
Ben,
Could it be that weedeaters, leaf blowers and some chainsaws are far less expensive that some of the engines we pay for. At least that's how I look at it
I know when I pay $600 or more for my engines I take extra good care of them and BTW, I have the best running weedeater and leaf blower on the block How do you think I taught myself to tune a 2 stroke gas engine
I can't argue your point though. My weedeater is quite old and I'm not very careful about the oil mix let alone the brand being used. My blower is fairly new and it gets about the same treatment as my weedeater. Could you imagine a 100cc weedeater or a 150cc leaf blower [X(] or even a 4 cylinder 200cc chainsaw
#4031
SC
Well, my question was mainly just to poke a little fun at the way we DO take care of our hobby engines. My point is that, I, especially take better care of my Brison(s) and my Fuji better than I do my garden type engines, but they just keep running right along regardless with only a hint of maintenance.
Bill, Speaking of the 4 cylinder chainsaw, do you remember "Tim The Toolman Taylor" and his Chevy powered riding mower?
My Ultimate and my Skybolt are on charge for tomorrow. Temps are supposed to be in the 80's with little wind. [sm=tongue_smile.gif] There will probably be so many guys wanting to fly that we will have to draw numbers. Kinda sad note here though. I am the only one that is flying bipes at our site now. All the others (bipes) have been taken away by the law of gravity.
I am knocking on wood.
#4032
My Feedback: (32)
Yea, my first sentence was a little serious then it dawned on me that you were joking so hence the rest of the post
Depending on who you listen to we are suppose to either have rain all day, or only in the AM or on and off all day with temps in the mid 60's, Same for Sunday so MAYBE I'll get to fly.
In any case, the Ulti and 2.3m are all charged and ready to rock
#4033
My Feedback: (17)
ID
In lumberjack competitions the best use 500cc single cylinder motorcycle (converted) engines. Now...that engine would be interesting on an airplane....wouldn't it?
barry
barry
#4034
My Feedback: (14)
ok. just did it. Dropped the hammer on a GP Ultimate just a minute or two ago. Should be here by Tuesday (yeah, sometimes it's nice living only about a hundred miles from Tower). She's gonna get a Brison 3.2, all Hitec 5645's, Futaba rcvr. I plan on beefing up the joiners, as suggested, possibly adding some wires to it. Any other good suggestions?
mcmike
mcmike
#4035
My Feedback: (32)
I wonder what size the DA 6 cylinder they did a couple of years back was. If you saw the Wildberry Tucson Shootout DVD's they showed a pic of it
I know 3W makes a 324cc. It's on the 75 pound Edge540 that is on Bill Hempel's web site under video's
#4036
My Feedback: (32)
mcmike,
just what was listed previously in the links. The rest is more personal preference. You should be fine on the 5645's as long as you use 6 volt. You definitely want to be a bit overkill and the Brison 3.2 couled with either a MSC22x8 (noisy) or a Vess 22B (very quiet) will make the thing a 3d monster, even at 16lbs it will not fly like it's 16lbs and mine is heavier than most
One other thing to mention is using different hinges (pin type) for the elevators but using them everywhere is not a bad thing. I'm on plane #2 and did not use the pinned ones on either one and so far (knock on balsa) I've been lucky and I hammer mine into walls and serious KE spins so the elevators take a pretty good beating
We also posted how to balance it without the wings on which makes it tons easier, did you catch that?
#4037
None taken, Bubba ! This is the first real expensive gasser I have ever had so I welcome all the input I can get . I'll lean the carb tomorrow till I get peak rpm ... I sure don't want to cause problems on engine !
#4038
My Feedback: (14)
I've got a vess ordered, and will go 6 volt with 5945's (stupid fingers!) so I''ll have plenty of servos. I missed the balancing without the wing bit. but that's a trick I've used for years with bipes. Get a good balance point with the wings on, take 'em off, see where it is then and use that as a 'base point'. I'll see if I can find the post tho...
thanks!
mcmike
thanks!
mcmike
#4039
My Feedback: (32)
mcmike,
after you get it all assembles, put on the carrying handle (there is one in the kit that you make)measure anywhere from 1 inch to 1.5 inches from the back bolt. That range is your balance. I'll see if I can find the posts
I found the post
http://www.rcuniverse.com/forum/fb.asp?m=4855801
I found the post
#4040
My Feedback: (198)
Bill, I think we figured out 1.25" forward from the rear cabane bolt was a good, solid, non-pitching setup....the freakin' search function here is SOOOOO Lame...
ORIGINAL: bubbagates
mcmike,
mcmike,
#4041
My Feedback: (32)
Bob,
Yea the search function bites and that's when it's working. I did find the post and edited my last one then I went and edited the a1pcfixer post to add it to it. (benefits of being the mod in this thread)
a1pcfixer, I hope you don't mind that I edited the thread with all the links and added the balancing tip
I'm at one inch and if you look at the post after I posted the pics of mine you can see my description which said
But I like mine very nuetral like that. 1.25 to 1.50 would be better for the first flights. Even at those points she still slows to a crawl
Just for the record, at my measurements, when I do a 45 degree upline inverted with a full tank and let go of the stick, the plane takes about 15 second to drop the nose enough to be level. At 10 minutes into it the tank, it never drops the nose, so I am slightly nose heavy when full and dead on at about 1/2 tank.
#4042
My Feedback: (198)
Bill - the dimension *is* referenced to the rear cabane bolt, right?
Bob,
Bob,
#4044
SC
82 degrees here today. Needless to say, we flew the afternoon away...."poet and don't knowit"... Tomorrow (Sun) is supposed to be a carbon copy of today...the Ultimate and Skybolt are on charge again for another good "wringing-out."
We even had a visit by a full scale glider that had ran out of thermals and had to land.
#4045
My Feedback: (198)
Thanks, Bill. That reminded me.... that I had to check mine.... it was a tad NH.
Appreciate the pic.
ifly - Would you take our 25+ winds, near solid overcast and gusts for a few days?????
[&o]
Appreciate the pic.
[&o]
Bob,
yes they are, if you click on the link, it takes you to the pics that I took while measuring it. You can easily see just how and where I measured it from. I actually just got back from doing another 4 flights on it between rain showers
Bob,
#4046
My Feedback: (32)
Ben,
Did you guys lend that poor sail plane pilot some thermals so he could get back to the airport??? Or did someone have a gas powered Telemaster to tow him back into the air
They changed our forecast for tomorrow. It was 35mph gusts all day with mid 60's now it's high 50's with 5 - 10 mph winds. Wanna guess where I'll be
Bob,
No problem on the pic...[sm=thumbs_up.gif]
Bob,
#4047
SC
ORIGINAL: aerobob
Appreciate the pic.
[&o]
Appreciate the pic.
[&o]
Bob,
Bob,
Bill...The glider pilot had to get a special trailer to rescue him. The trailer probably cost about as much as the glider...NEAT!!!!!
#4049
My Feedback: (198)
Nope. No wings, but cowl, spinner, prop, empty tank. Fuse otherwise complete, RTF.
Very reliable comparitive method, and I use a 1" dowel to lift the carrying handle at 90* to the handle. VERY precise, believe me.
ORIGINAL: arobatx
Bob and Bubba,
Balancing using the carrying handle....I assume the bottom wing is not installed either, correct?
Bob and Bubba,
