Old 06-05-2019, 01:01 PM
  #40826
acdii
My wife encourages my hobby(now to get her OK on a Laser cutter, but it IS my money) We are going to the SIG Flyin Saturday, was going to skip it this year, but decided to just drive there early Saturday morning instead and come home that night since it is only about a 5 hour trip. We did the same thing the very first time I went, this time taking mutt and butt with.
Old 06-05-2019, 01:19 PM
  #40827
Glowgeek
Originally Posted by FlyerInOKC
Just wait until you spill fuel in the Tahoe and then we'll see how long its plane hauling days last.
Funny you should say that. I warned her about hauling gas in the tahoe, nope she wouldn't listen. She swerved to miss a deer day before yesterday and spilled at least a quart out of one of the jugs when the cap popped off. Gave the rear carpet a good soaking of ethanolated gas. What a stink!
The way I figure it I could spill up to a quart of fuel to be even. On the other hand she's a woman so it's my fault she spilled the gas to begin with.
Old 06-05-2019, 04:09 PM
  #40828
Jesse Open
Jesse Open's Avatar
Geekster I do have a new in box 182 if you happen to have need and are interested in trading
Old 06-05-2019, 04:16 PM
  #40829
acdii
Yeah but 2 cycle fuel is worse, that oil gets rank after it sits and bakes! And if it is 20% caster glow fuel, look out!!!
Old 06-05-2019, 04:38 PM
  #40830
Glowgeek
Thanks for the offer but baby needs new shoes, so to speak. I've been selling off some engines lately to finance my habit of buying preowned planes. Mostly selling old 2 strokes and OS 4 strokes. I just cleaned up and re-bearinged a lovely super low run time FS -26. Amazing little thumper. When compared to a Saito OS 4 strokes are a beatch to rebuild.
Old 06-05-2019, 05:51 PM
  #40831
the Wasp
Could be. A NIB non GK 100 FA-AAC from Horizon has a $339.99 price tag, by comparison $290 doesn't look so bad but it doesn't mean a prospective buyer will pay it. It has been a long time since I could afford to buy an R/C engine 2 or 4 cycle in a store.
Quick question if I can fit it under the cowl do you guess think a Saito .80 would be too much engine for a 9 to 10 lb. civilian scale job? I fly in more of a scale like fashion, I don't fly 3D or fly patterns. I haven't got the coordination or reaction times for that.
Mike
https://www.youtube.com/watch?v=_VrFV5r8cs0
Mike, go to YouTube, search Saito FA80 and watch many videos, you will get an idea just how powerful that engine is, my thoughts are for scale, if the 80 will turn a 13X6 or 7 or 8 it should turn a 14X4 and that should do it for scale
Jim
Old 06-05-2019, 06:26 PM
  #40832
the Wasp
well with sanding for 20 seconds and fitting and sanding and fitting and sanding and fitting for 3 hours I fit the Mustang's wing to the fuselage.
I said to myself "what a piece of junk, screw the Incident meter, if it fly's it fly's, if it doesn't just as well because I will stomp it into it's next life and send the video of me doing it to Air Borne Models as well as to World Models",
LOL you see I found a another problem, one screw hole in the wing for mounting the wing was drilled in the wrong spot, LOL when will it stop ?????? LOL
hey, did I tell you guys, to never buy a Wold Models plane, if I didn't>> don't
Jim
Old 06-06-2019, 01:52 AM
  #40833
Glowgeek
What year was your WM arf built Jim? Is it a 46 or 60 size?
Old 06-06-2019, 04:18 AM
  #40834
Glowgeek
Gary, have you ever made a 12mm 15° adaptor that simulates the angle of a factory saito muffler inlet? Looks like that's the only way I can mount your custom muffler on my fa82 Sbach without cutting up the cowl a bunch more because putting an angle adaptor on the engine would change the header pipe location drastically. So I would leave the header as is, screw on the 15° male/female adaptor and lock nut and then screw on your muffler with lock nut. No change to the cowl would be required and as a bonus I would be able to remove the muffler before removing the cowl; less cowl flexing that way. Another bonus would be the ability to point the muffler more downward which would eliminate the need for that pesky unsightly Dubro exhaust deflector.
Old 06-06-2019, 05:14 AM
  #40835
Jesse Open
Jesse Open's Avatar
Can you make a sketch ?
Old 06-06-2019, 05:16 AM
  #40836
FlyerInOKC
FlyerInOKC's Avatar
Jim
I have a SIG 1/5 scale Cub with a second hand .80 on it with a 14X4 prop to be scale. I need to pull the engine and get the needles set correctly. I recently bought another .80 from a forum member so I may just swap it. It was a bear getting it in without lengthening the nose (Box firewall).
Old 06-06-2019, 05:26 AM
  #40837
Glowgeek
Default 12mm 15° Saito exhaust adaptor
I'll leave it to you to determine proper internal/external thread lengths, wall thickness, material type etc. Thanks
Old 06-06-2019, 06:25 PM
  #40838
the Wasp
it's a 60 size, here is a link to it, how do I tell what year it was made
Jim
Airborne-Models
Old 06-07-2019, 04:07 AM
  #40839
Glowgeek
Jim
Airborne-Models
Thanks. Yeah, you can't tell what year it was made unless you bought it close to the release date. Was wondering if it was early production or a later one. Manufacturers many times fix problems with early releases as time goes on. My WM 46 size P51 was an early release so I had to strip the film back and reinforce the gear blocks. Later releases were better built and actually came with retracts.
Old 06-07-2019, 08:45 AM
  #40840
the Wasp
LOL this is nuts, LOL I found the threads on the tail's push/pull rods are tapered, the cleaves are loose, some of them can be simply pushed half way down the threads, the rods can't be trusted to hold the cleaves so I have to buy new rods, go figure
along with the hole drilled in the wrong spot, this^ gives me good reason to Email Air Borne Models and tell them what I think,,, again
Jim
Old 06-07-2019, 09:12 AM
  #40841
FlyerInOKC
FlyerInOKC's Avatar
Jim, that is why I associate "ARF" with dogs!
Old 06-07-2019, 10:31 AM
  #40842
the Wasp
you must be a cat person LOL, all the cats my wife's has had bonded with me, I guess I'm a good person LOL
you'd be surprised how good my VQ P-40 is, but I can not find it's wing joiner ********* I can't believe it
Jim
Old 06-07-2019, 10:40 AM
  #40843
acdii
Arf's usually become a kit eventually. Crash them enough times and they become un-arfs and unique.
Old 06-07-2019, 10:51 AM
  #40844
FlyerInOKC
FlyerInOKC's Avatar
Jim
Nope, I dyed in the wool dog person. If you don't believe me just ask Millie she is the boss! I will warn you though she thinks she is the Queen and expects to be treated as such.
Old 06-07-2019, 12:55 PM
  #40845
the Wasp
man, this must not be my year!!!!!!!!!!!!!!!
I can't believe what is going on in this hobby! I just called Byrons/Wildcat, they wont sell me what I want, they wont sell me 1 case with 2 different fuels in it, I want 2 gallons of 10% for braking-in, and 2 gallons of 20% for flying, if I want 2 different fuels I have to buy 2 cases, I don't need or want 4 gallons of 10%,, I ended the call
I tell you, if I knew last Spring all the troubles I was going to have to get these planes in the air I would have stopped flying and never spent another penny on the hobby!!!!
later
Jim
Old 06-07-2019, 01:57 PM
  #40846
Glowgeek
later
Jim
Try S&W fuel, they'll send you whatever you want in one case.
Sorry to hear about your modelling woes. I get depressed sometimes with all the work it takes to get a plane flight worthy. It all goes away after the first flight so cheer up dangit!
Old 06-07-2019, 03:57 PM
  #40847
the Wasp
thanks for the good words!!, you know how I feel, it's just a pi$$er.. but on the good side check this out, $25.5 a gallon for 15%, 6 gallons in a case, I wonder what the street price is or if there is a coupon number around somewhere, I wonder what the shipping is to Vt, too late to call tonight, I will try to call tomorrow
the listing here,
https://vpracingfuels.com/product-ca...plane-rc-fuel/
Jim
Old 06-07-2019, 04:33 PM
  #40848
Jesse Open
Jesse Open's Avatar
So how much is wildcat fuel nowadays ?
Our LHS will no longer order wildcat but they do handle Morgan's Cruel Power and all the VP fuels.
Old 06-07-2019, 04:39 PM
  #40849
Hobbsy
Hobbsy's Avatar
later
Jim
Jim, I fly 10% only all the time, you will never miss not having 20%, I have used a few gallons of 5% also, engines run really nice on it. Guys in other countries fly 0% and have as much fun as we do.
Old 06-07-2019, 05:03 PM
  #40850
acdii
I have only ever used 15%. I don't see the need for anything higher in a 4 stroke. 2 stroke OTOH need all the help they can get.
