Official Tamiya TT-01 Thread
Old 03-27-2008, 01:23 PM
  #4076
The Collector1
The Collector1's Avatar
Default RE: Official Tamiya TT-01 Thread
The only thing that original on my TT01 is the lower arms, body mounts and servo mount everything else is either a Tamiya hop up or a 3R hop up.Diffs are ball diffs.
Old 03-27-2008, 01:59 PM
  #4077
cornel4web
cornel4web's Avatar
but are them separately aquired...right?
Old 03-27-2008, 02:49 PM
  #4078
The Collector1
When I bought my car 2yrs ago from an LHS, the ball diffs were in the box, but normally you have to buy them unless you get the TT01R which has some hop ups already but I dont think that one has a body. I need to get some foam tires for my car because the rubber keeps ripping off the rims[:@] yes I glue them on but they still come off[:@]very violently too[:-].
Old 03-27-2008, 03:50 PM
  #4079
osr
Hi all, do any of you use hard cased lipo cell's ? If so how do strap them in ? Im wondering if there is a decided 'best way' or to just use fibre tape or maybe sew some velcro into an old rucksack strap or something....
Any suggestions welcome. if you do something a little different some pics would be really helpfull.
Thanks all !
Old 03-27-2008, 05:09 PM
  #4080
TIGER76
TIGER76's Avatar
Hey m8 i havent used lipos yet but that strap ideal sounds best and maybe use one of those lipo sack thing to protect the chassis just incase ( a flaming fireball hurtling along at 50mph plus lol) < thats the reason i havent switched yet ever since my mates burst on his car charger and set fire to the front passenger seat lmao[:@]
as for the earlier post about thermal shutdown on ESC it stops the heat from damging electric parts sort of a fail safe for electrics etc
If you get alot of thermos it either means the esc cant handle the motor your using,temps of the weather,best to start using a fan above the esc if you do get alot of thermal shutdowns
Old 03-31-2008, 09:17 PM
  #4081
ooberkan
hey how important are the bearings?
im broke and all i cud afford is the shaft
Old 04-01-2008, 08:14 AM
  #4082
TIGER76
TIGER76's Avatar
Metal bearings come into play as it rolls 100% better.
The plastic bushings u get with the standard kit wear down and slow the car down alot,i did my bearings first then when i upgraded the motor i upgraded the propshaft as the standard motor will work fine with the plastic prop,but the standard prop will bend alot on a modded motor []
Its not much of a problem really just save up for the bearings as i would rate them as a defo upgrade for the TT
Old 04-01-2008, 09:43 AM
  #4083
tcv_racing
tcv_racing's Avatar
HI to all!
Im planning to use my TT01 off road, mostly sand and loose soil and I've already upgraded my suspension..
I just wan to know if its okay to get sand or dirt inside the motor?
Thanks in advance!
Old 04-01-2008, 10:14 AM
  #4084
TIGER76
TIGER76's Avatar
Hi m8 welcome to the thread
Well alot of people use there TTs for rally etc so you should have no problems really,just be careful of any small rocks etc getting into the motor holes they will damage the comms inside while spinning,some people tape up the hole underneath the motor on there TTs which seems to work but you also need to let the motor breath while running.
If you do get dirt or dust inside the motor spuirt a lil motor oil thro the motor hole to wash the comms out as the dirt will harden and end up damaging them.
But like i said many have used them for rally purposes so you shouldnt worry and if your using the stock motor they really cheap to replace anyway
Alot of guys on here higher up there travel on shocks too for offroading so you get a bit more ground clearance.
Hope that helps ya [8D]
Old 04-01-2008, 10:29 AM
  #4085
davedp01
I would use a heat sink that covers the holes on the motor and clean it often. (Sand and moving parts Not Good.)
Old 04-01-2008, 10:40 AM
  #4086
tcv_racing
tcv_racing's Avatar
Thanks so much! Ill keep that in mind.. Do you guys use under body lexans to keep dirt away from the inside part of the car? Or you just use it as it is just with higer suspension..
Heres my rally TT01:
Well since I used it for drifting before it pretty much have all the important upgrades for drifting
Aluminum hop ups, Rear diff lockers, front ball diff set, upper carbon, heat sink, ball bearings, univ drive shafts, 23T Yokomo motor and a lot more..
all that I had to do was increase the ride height and install rally block tires..
Old 04-01-2008, 10:43 AM
  #4087
tcv_racing
tcv_racing's Avatar
Do I have the right ride height? or i need more for rally?
Again thanks a lot for the fast replies!!!
Old 04-01-2008, 12:05 PM
  #4088
TIGER76
TIGER76's Avatar
Looks like you have ample clearance there m8
And love that color on that scooby nice to see a different color to all the standard blue scoobys about [sm=thumbup.gif]
Old 04-01-2008, 04:38 PM
  #4089
MarkedMenaceGTR
MarkedMenaceGTR's Avatar
Hi all! Im new to eletrics and i was just wondering how long my run time is going to be with brushless Speed Passion Exige Brushless ESC & Motor 17T and Intellect SC-4200 6 cells?
Old 04-02-2008, 11:16 AM
  #4090
compression
hi all i have a tt-01. i'm looking for a second shaft-driven car.
should i get the tb-02? or the tt-01r? or the tt-01E? or even the tt-01ER?
btw, i was just thinking, a stock tb-02 out of the box, is just about as well equipped as a mid-way hopped up tt-01. so why the rage about tt-01?
i got my tt-01 cos everyone was saying how good it was. why not encourage first-time buyers to get the tb-02?
just pondering...
Old 04-02-2008, 11:17 AM
  #4091
compression
ORIGINAL: tcv_racing
hi tcv,
what do rally block tyres do? jsut curious. have never seen them in my life...
Old 04-02-2008, 12:56 PM
  #4092
TIGER76
TIGER76's Avatar
They add a bit more ride height (check his pics for tread size) and they grip alot better on loose dirt than the TC tyres do,but they wear down quick on hard surfaces
Old 04-02-2008, 04:17 PM
  #4093
osr
TCV your 20mm ride height there is about as far as you can get with a TT-01. In fact, i would guess at that height you are already getting a cogging effect/noise. The diff's and drive shafts are just not designed to go much beyond 18mm without a much higher stress on the parts.
If you remove your bumpers and take the motor out and try moving the car at different heights, at some point ~(around 18-19mm i'd guess) you will find more resistance than is good for your parts. That's how i judged where to grind my bumpers down to.
This is assuming standard diff's. Ball's and one ways might be different.
I rally my TT-01 a lot but i have only ever stuck with the standard diffs and just stiffened them with grease to gain traction. I would be interested to know if different diffs would allow extra ride height
Edit to add, Don't take that shell rallying ! It's a great shell, the pipes and everything look fantastic. My rally shell is more just a cover for roll protection so think about getting a cheap shell before you go rolling around in the dirt !
Old 04-02-2008, 05:42 PM
  #4094
ooberkan
umm i got a monster 27 and my shaft keeps bending and hits my turning thingy
will bearings stop that?
Old 04-02-2008, 07:41 PM
  #4095
mindwreck
mindwreck's Avatar
you need to get a aluminum center shaft.. If im understanding your problem correctly. don't know what you mean by turning thingy
Old 04-02-2008, 11:39 PM
  #4096
ooberkan
srry the umm stering thing that connected to the servo
sorry dont know what its called
the bearings wont stop the shaft from bending cause the tamiya xgb or w/e has the same shaft but doesn't bend
i guess i shud buy the shaft
Old 04-03-2008, 06:03 AM
  #4097
tcv_racing
tcv_racing's Avatar
I don't get the cogging noise with my 20mm height, and in fact it looks like I can still add more.. I changed my stock drive shafts with
the Tamiya universal shaft assembly.. Its a lot thinner the stock ones..
http://www.tamiyausa.com/product/ite...oduct-id=53792
and if you plan on using those too, don't forget to get this also coz the stock cup joints are too big:
http://www.tamiyausa.com/product/ite...oduct-id=53790
Do you guys use under body lexans to cover the inside of the car from dirt an derbris? or you just use them as it is?
Just want to know coz I tried running my car in the sand and loose dirt and my chassis was full of it!!! tons!!!
Old 04-03-2008, 11:49 AM
  #4098
TIGER76
TIGER76's Avatar
Undercover what?? lol
damn i just take the shell off to protect it and kick up dust me
[link=http://media.putfile.com/dust1]http://media.putfile.com/dust1[/link]
Old 04-04-2008, 04:54 AM
  #4099
tcv_racing
tcv_racing's Avatar
Nice video Tiger!!! I guess its ok to get dirt inside and just blow it off after playing.. Thanks!
Old 04-04-2008, 08:01 PM
  #4100
pontuna
Speed Controller and batteries, I just bought a tt01D spec and I was wondering what the largest battery in mah I can run in the car. In my other brushless car run I run the 5000mah nimh battery and would also like to run that in this car.Also the previous owner thought the speed controller was bad and took it apart and lost the case/housing for it and I was wondering if anyone have a TEU-101BK that the might want to get rid of.
One last question what brushless setup works in this car and am looking for suggestions as to what work best.
Bob
