Old 06-24-2019, 01:49 AM
  #41101
Hobbsy
Hobbsy's Avatar
Jim, here is shot behind my 115 at about the 20 minute mark in it the break in,as you can see at 18% there is a veritable flood of oil and it is washing the factory lube, (the black stuff) out. This would have been at 5,000 rpm, low throttle, three turns out.
Old 06-24-2019, 03:38 AM
  #41102
Jesse Open
Jesse Open's Avatar
BTW Jim,
With the dual Check valves, you can easily pipe that oil right out past the rudder, free and clear of the plane.
I have been playing with a catch can to capture that oil. The oil could probably even get re-used with only a simple straining
Old 06-24-2019, 05:25 AM
  #41103
acdii
I do something similar with the exhaust, but externally. I have a soft brass line that is strapped to the muffler with the end beveled where it meets the exhaust. The other end is hooked up to the breather. Keeps the plane clean, just get a bit of slime on the landing gear and rear stab.
Old 06-24-2019, 05:55 AM
  #41104
Jesse Open
Jesse Open's Avatar
Same here, that is pretty much what led to moving the line right inside. Just to tidy things up a bit. It also seems to keep the oil blast pattern narrower and more concentrated , winding up with less oil on the plane.
Old 06-24-2019, 07:18 AM
  #41105
Hobbsy
Hobbsy's Avatar
Saito 50 GK run after re-build
1st prop tried: Graupner 11 x 6 rpm exceeded 11,900
Prop=======Xoar 12 x 6 as pictured
Plug=======Fox Miracle
Exhaust====Davis SoundMaster in cowl muffler, (neighbor lady in bed recovering from operation.) The exhaust is nearly silent.
Old 06-24-2019, 09:42 AM
  #41106
Jesse Open
Jesse Open's Avatar
Yep,
Likewise with the homemade aluminum canister on the beefy Saito 125. Weiighs about the same as the Saito.Easily reconfigured to suit in cowl as needed.
Old 06-24-2019, 02:48 PM
  #41107
Glowgeek
The canister is a real nice piece of work Gary.
I thought I saw that Toledo Special cowl in the background of some earlier pic you posted. Looked like it was undergoing some bodywork repair. Man, that old girl has seen some air time.
Old 06-24-2019, 05:29 PM
  #41108
Jesse Open
Jesse Open's Avatar
Those cowls are hard to find and a bad crash busted that one into 4 pieces. Yep, it was payed back, spliced and coaxed. I then made a mold from it. Have laid up a new cowl yet so I just screwed that one on the repaired again plane.
This version of the canister is very quiet indeed. A lot quieter than I had anticipated . I actually like it.
I added a different baffle to the very modified YS shell in the above pic. My wife even commented Sunday on how it just " purred along" so smoothly. The electric guy flying at the same time was actually louder.
Old 06-25-2019, 12:11 PM
  #41109
the Wasp
Originally Posted by Jesse Open
Jim,
The oil isn't actually getting dumped into the muffler. That brass tube passes through from front to back . The plane used to get very oily on the bottom and up the port side. Now the sides both stay clean and only the bottom gets slimed.
Not sure what you were trying to do with the break in but with two check valves, yes you can inject additional oil to a running engine. You still need to allow air in as well.
knowing that much of the oil passing by the piston is used my thoughts to add fresh oil to the crank case was only for the brake in. yes> air is needed, my thoughts on sucking in air was to only add a squirt of oil to the header tank every few minutes as the engine brakes in, this would allow both air and fresh oil in.
know this now about me, for sure I may not be the best engine mechanic, but I am very picky about certain things, and when it comes to braking-in a new engine (specially like a Saito) my mind strives for the best result, so if I can add fresh oil to my rod bearing that may help me get to that result. plus I will enjoy testing my method.
I like the idea of pumping the used, vented oil to the tail of the plane. it seems to me that with using a tube that long should help hold a bit more oil in the case
Jim
Old 06-25-2019, 03:25 PM
  #41110
Jesse Open
Jesse Open's Avatar
"Used"?
Do you really think that single pass from top to bottom does the oil much harm?
Here I am, pondering catching the vent oil, straining it and using it as part of the oil in fresh fuel!
No kidding
NameLast modifiedSize Go to parent directory
Old 06-25-2019, 05:57 PM
  #41111
the Wasp
hey guys, my son is going to buy a ticket and go up in a B17 when it comes to Vt next month, how cool is that
"harm" naa, but it's diluted a bit.
that 82 sound so cool !!
Jim
Old 06-25-2019, 06:19 PM
  #41112
acdii
Thats funny, been playing with the laser cutting software trying to make an engraving of a B-17.
File Type: bmp
Old 06-26-2019, 01:47 AM
  #41113
Jesse Open
Jesse Open's Avatar
That engraving sounds pretty cool. B-17 is one of those ruggedly handsome planes. Jim, I wonder if that B-17 is the Yankee Air Force B-17?
I
Old 06-26-2019, 06:12 AM
  #41114
acdii
Is anyone else getting spammed by RCUniverse?
Are Weight Gain, Digestive Discomfort, and Heart Problems Caused By This One Food?
Old 06-26-2019, 06:28 AM
  #41115
BarracudaHockey
BarracudaHockey's Avatar
if you want to talk about this, go to the thread in Forum Support. I'm shutting any discussion of that here down right now.
Old 06-26-2019, 06:56 AM
  #41116
acdii
Just being cautious! Remember I am in IT and was the lead of an ISP for 16 years!
Old 06-26-2019, 07:11 AM
  #41117
BarracudaHockey
They came from RCU, the email addresses weren't sold and it's not spoofed. If you dont want them just click un-subscribe and you won't get them, and it doesn't affect forum notifications or pw reset emails etc.
Old 06-26-2019, 07:16 AM
  #41118
acdii
Thanks. I read through that thread. I rolled my eyes.
Old 06-26-2019, 09:52 AM
  #41119
Jesse Open
Jesse Open's Avatar
Jim
Filtered in paper and set out in the sun, all the volatiles evaporate off
The stuff looks and acts like new, even measuring the viscosity by drip method. Oil costs about the same as nitromethane.
You didn't say which B-17 your son is riding(?)
I will post some pics of a flight simulator my buddies and I restored here at work. It was for the Yankee Air Force at the old Ford, Willow Run Airport.
Old 06-26-2019, 10:15 AM
  #41120
Glowgeek
The ever popular B17 is a handsome plane indeed. The DC3/C47 is my favorite from that era. Here with twin Saito fa30's.
Old 06-26-2019, 10:24 AM
  #41121
acdii
One reason I bought the laser cutter is to build the Jan Hermkins 1/8th B-17. I plan to use 4 Saito's converted to CDI. Not yet sure if they will be 72 or 90, or something in between.
Old 06-26-2019, 10:56 AM
  #41122
FlyerInOKC
FlyerInOKC's Avatar
I remember seeing several DC-3s built around the Graupner/OS Wankel radials
Old 06-26-2019, 11:11 AM
  #41123
BarracudaHockey
Yea, lol, there's one at the local "antique" store down the road from me. Its got old Futaba gear and a couple of Wankel engines.
He only wants $3700 for it.
Old 06-26-2019, 11:40 AM
  #41124
FlyerInOKC
FlyerInOKC's Avatar
I hope you didn't bust a gut laughing! He'll grow old with that stuff.
Old 06-26-2019, 11:47 AM
  #41125
acdii
My friend has been wanting to build a PBY with a pair of those. Would look good, but will it fly well?
