#4151
AR
RE: Welcome to Club SAITO !
Member #243 here. I've recently installed an FA-82A (my first 4-stroke) in a 40 size Spitfire (fits perfectly within the cowl) and have begun running it in.
Thanks to info gained here, starting, running at proper rpms & proper mixture have given good results.
Lowspeed setting had been changed from factory(bought off the shelf), but I reset well enough for first round of break-in.
Can't wait...............
#4152
Stall, the Saito LS needles are deliberately set very rich from the factory for two reason, #1, to make sure the frist runs are rich and cool for break in. #2, if the LS needle is too lean then no amount of richening the HS needle will do any richening.
#4153
AR
TW, thanks for your response. Again, info gained here warned me to attempt to reset the LS rich enough. Your reply added more useful information.
I am waiting until high 100deg temperatures here abate so that overheating won't tend to lean the mix while finishing run-in.
#4156
Kimhoff
The Saito 56 will power the Four Star 40 very nicely you will need to put an APC 12/6 for sport flying or an APC 11/8! I prefer the APC 12/6
for the flying that I do mostly sport and a few stunts and you can look for about 16 minutes of fly time also check your CG real close I needed 2 1/2 oz of weight around the tail of the plane to ballance the Four Star with a Saito 56 Your going to love the way the Four Star fly's with the 56!!
#4157
My Feedback: (12)
MA
Thanks. That's reassurring. Any issues with the timing mechanism? I'v replaced bearings on 2 strokes, but never on a 4 stroke. Thanks for your feedback
cheers
/colin
cheers
/colin
#4159
My Feedback: (14)
ORIGINAL: Kimhoff
Will a Saito 56 fly a 4 STAR 40?
The model was originally shown with a Saito .50 on the plans and warned that Schneurle ported .40's or higher could lead to wing failure without throttle management. The .56 should be just fine.
#4160
I have installed a onboard glow driver, that is the only reason it will idle at all! Horizon Hobbies has told me several times that it should idle normally mounted inverted without a glow driver, but I cant get it to. Ive tried different plugs, fuel, tank positions, etc. to no avail.
#4161
Inverted Saito, early high compression version with upgrade spray bar and HS needle.
Fuel WildCat 15% Premium Extra with 18% 80/20 syn/castor blend.
Plug Early H9 SuperPlug.
Top rpm 9,500 plus.
With the tank full I leaned the LS 1/4 turn then set the throttle for a 2,000 rpm idle, give or take a few. I then went into the house to get the camera and then in my shop to get the tach, it was still idling when I got back. The transition is as clean and linear as when upright.
Top rpm 9,500 plus.
#4163
I never ran it inverted before, it spent most of life side mounted on a Kombat .60 and Kombat Bi-plane from the Airplane Factory. It always had wet midrange before. But is completely clean in the transition now.
#4164
MB, CANADA
Hobbsy - looks like my setup. your tank even looks high. When I ran mine upright My LS had to be dangerously lean. Even more so inverted. I am waiting for my upgrade kit. they sent one fo the 180 by mistake. I'll keep in touch. Thanks.
#4165
MB, CANADA
Horizon sent me an assembly for a 180 by mistake(which I still have not received). Contact them and find out if they have an upgrade for the 180. The last 3 digits were the same on the part number. I ordered it about 2 weeks ago. They sent the 80 one on Wednesday.
#4167
MB, CANADA
Hobbsy-one more thing if you don"t mind; how far would you say your idle bar is from the spray bar? To idle mine is paper thin I need a magnifying glass to see a space between them. That is why I call the idle dangerously lean. Any closer and I can't Richen HS. Thanks for all your help. Proves again modellers are great people.
#4168
My Feedback: (79)
I just picked up a new Saito .40a cheap last night at the LHS going out of business sale (50% off). What would be a good plane to match it with, and how much more powerfull is it than the .30. Is there anyone who would be interested in a new Saito.
#4174
Scratch, according to "mikey" the LS needle is precisely .016 inch from the end of the spraybar. Each Saito feeler guage you see measures .004, 3 of them fall right through, 4 of them stay put with only minor pressure required to move them.
#4175
MB, CANADA
Wow and you can still get the HS rich if you try? I can only get 3 guages in my gap. Could we really be dealing with such small changes to make such a difference? I could run mine like this but i can only richen the HS slightly. It doesn't sound like the upgrade will make much of a difference to the idle. Will come back when I install the upgrade. Thanks for all your efforts, we may learn something here to benefit others.
