Official Tamiya TT-01 Thread
#4151
well I can't really say. They don't give too much information on the batteries themselves and what kind of cells. They provide no max discharge numbers or another form of specification.. SOoo.. get one thats the most capacity in your price range... either 3300 would be fine
so what do u think is better
3000 reedy wolfpack
3200 trinity thunder
3300 trinity refrence
3300 orion rocketpack
or any battery around the $20 range
[/quote]
ORIGINAL: ooberkan
3000 reedy wolfpack
[/quote]
#4152
if any of you guys want a trf415. i have one that i am trying to sell.
https://accounts.craigslist.org/post...46076319&db=lv
#4153
ORIGINAL: mindwreck
3000 reedy wolfpack
ORIGINAL: ooberkan
3000 reedy wolfpack
[/quote]
#4154
Matt,
Your specs are not out of the ordinary. Imho you may have a binding (friction) problem which causes the motor to output more power hence more heat. Check that there is no binding in your drive train and in your wheels. Everything should be spinning freely. You did not mention if you have ball bearings, if not then installing them would definitely help.
ORIGINAL: mattd938
Hi guys, im having a slight problem with my tto1, it runs like s*^t of a shovel for say 10 mins then cuts out, something thermal by the looks of it as the metal part of the teu 101bk heatsink is red hot and after something cools it runs fine again
spec is.......
tt01 drift spec
stock motor rz
motor heatsink
teu 101bk esc
58t spur gear and 24t i think lol pinion
gp battery
how can i fix this so it doesnt overheat ? better esc ? teu 302bk ? is the gearing too high ? i dont really wanna change the gearing as i love the speed lol
help lol
matt
spec is.......
tt01 drift spec
stock motor rz
motor heatsink
teu 101bk esc
gp battery
help lol
matt
#4155
either you burnt the coatings on the armuture. or smoked teh brushes.. It won't be longer much longer and the power would be lower
ORIGINAL: ooberkan
O.O i was running my car today then after 10 mins, my motor started smoking but then its still working
its wierd
its wierd
#4156
ORIGINAL: mindwreck
ORIGINAL: ooberkan
its wierd
its wierd
imma buy new ones or just a new motor
#4157
Thank you for replying
yes its fully ball raced
will check later to see if anything is having issues
Thanks............Matt
#4158
sorry don't know if anyone's posted this already, but is it possibe to convert my tt-01 to a tt-01e by simply purchasing parts from my LHS?
#4159
ok, i checked my car, with it in the air all the wheels turn freely one by one, when i put it on the desk and push it allong its juddering and not moving freely at all,
any ideas what could be causing this ?
also has anyone got a link to the new tt-01e pictures and specs ? hows it different than the current tt-01 ?
thanks............Matt
#4160
right ive done some investigating and removed the motor, when i turn the pinion gear by hand it is massively juddery and not turning smoothly at all,
is it supposed to be like this ?
with the motor not in place the chasis moves very smoothly
help lol...........Matt
#4161
Maybe your motor needs cleaning? Is it one of those that you can take apart? If not maybe spraying some motor cleaner through it might free it up. I got a pebble stuck in my motor one had to take it apart to get it out.
#4162
again thank you for the reply, the motor is brand new just been used properly twice
tried spraying some gt85 into it around the ends where the shaft comes thru, still the same
also, im using 24t pinion and 58t spur gear, if i changed the 24 to a 25t pinion would there be much difference in acceleration / top speed or is it not worth bothering with ?
matt
matt
#4166
ORIGINAL: mattd938
dont get worried about that
#4167
ORIGINAL: The Collector1
If you change to a 25 your acceleration will be alittle slower but more top speed when you used the cleaner did anything come out of it? Was the liquid clear when it came out?
#4168
ORIGINAL: ooberkan
if he changes to a 25, his top speed will go down
#4170
If you change to a 25 your acceleration will be a little slower but will have MORE top speed,I thought thats what I said I did say More as in HIGHER
i thought u meant motor cause he said something about his motor
XD sorry
#4171
i found some radioshack batterys but not sure if there good
http://www.radioshack.com/product/in...entPage=search
#4172
any noises or anything.. when u spin it does it shifting as it rotates. Some motors exhibit this.. its part of the magnet's strength and various other components. the magnets are so strong that its attracted the armature with considerable force and causes that "juddery" feeling you get when you spin your motor
ORIGINAL: mattd938
#4173
those are the ones you want if you can still find them. they have been gone from a lot of radio shack store.
Those are technically gp3300 packs and they are good cells for bashing and maybe club racing, but the capacity might be a little too low for competitive racing.
ORIGINAL: ooberkan
#4175
Hi everyone. I haven't been on here for a while now. But I got a question to ask of you all. Recently my Venom Fireball 15T Mod Motor just crapped out on me. Now I need a new one but do not know which to get. I'm pretty much looking for a decent priced motor and speed
