Official Tamiya TT-01 Thread
#4202
ON, CANADA
ORIGINAL: DriftingDragon
thanks
does it also give camber/caster adjustment?
thanks
#4203
OR
Hey everyone, I just picked up a huge lot of TT-01 Chassis' there were at least 2 tubs in the picture, parts, full parts trees etc off ebay, once I receive it and figure out what is all there, I will list everything. In the meantime if you want shoot me a message if you are in need of a part and as I go thru the box I will set it aside and message you back
#4205
Hey everyone, first post here.
Anyways, just got an 8turn Single Reedy Modified motor. Went to the hobby shop and got an RC- Line Limitless ESC. That was a cheapo and I could tell because it stopped working. Anyways, I am looking for a good ESC that can run my 8t motor. I think I would rather a limitless and maybe one that can run both brushed and brushless (maybe). I would prefer it to be programable also (but if it's not, oh well). Also, can you tell me if it has reverse and smart braking. Cheers.
And by the way, I am running 55/25 in the TT-01 with 3000mah NimH batteries at 7.2V (6 cells I believe).
TT-01 is a great car..... it just keeps on chugging. And don't worry about hop- ups to handle all that extra power- they are coming!!!
#4207
3racing makes that chasis.
http://www.3racing.hk/products.php?products_key=2572
Try looking on ebay for it.
#4208
Im about to build a 3rd tt01 from all my spare rc parts as a bash car for the backyard. Iv got the stock shocks but no springs so what can i buy to fit into the stock shocks?
#4209
Hi guys! It´s been couple of months since my post, and only now i have finished the 8-cell "conversion".(my stampede has stolen all of my rc-time)
Short clip with worn tires and about 60% throttle. http://www.youtube.com/watch?v=j7tbfgKe-Q0
#4212
Rally thread
http://www.rcuniverse.com/forum/m_67...tm.htm#6707622
Btw, did some testing on track, -needs work... http://www.youtube.com/watch?v=5_KhyLx-Y8k
I need better servo!!!! -this one will not center at all!
#4213
Not too bad stealth it takes a while getting used to track driving alot different from parking lots lol
stick with it m8 more you practice the more you will nail it
And yeh the TT does suffer on turns alot try getting a hi torque servo for steering helps alot.
Or take the servo saver off and recenter that one worth a try [8D]
I found smooth power helps on the track once you learn the layout come into to the corners slow and smoothly out after a few laps u find slow is smooth is faster lap times
#4214
i got my car back together after a catastrophic crash last night, and ran it today. now, i'm not having trouble with overheating the motor or esc, but the battery connector actually MELTED today after a full (4200 mAh) pack with my 8x2T motor. would upgrading to deans connectors help this problem?
#4215
Defo m8 anything under a 10turn and those tamiya connectors start to fuse together lmao
deans are the best for high current
#4216
Tamiya plugs are notorious for melting with high mah batteries. First upgrade aside from the usual bearings, ball diff and one way was to change all my plugs for deans. Lower resistance. Should stop your connection melting problem.
#4218
I had that happen to me after being lazy and not changing mine out I melted mine using a 3.5 to the point it melted a hole in the chassis so the connectors battery wires and chassis needed replacing[:'(] Oh well gave me an excuse to go graphite
#4219
ORIGINAL: nick89_
#4220
Sorry no one answered you,You can get a Novak GTB alone or a Sidewinder bl set,the sidewinder will be less that the novak an you will get a motor. I run a GTB with a 3.5 in my TT01 and had no problems since Ive bought it a year ago. Theres also the Tekin G11 if you dont want reverse thats a good one too.
But if you ask me which has a smoother power band I would say the GTB and the G11 the G11 isnt brushless. I also have a MM 7700 too but its not as smooth as the other two.
These are some of the one that I use I cant tell you of any others because Ive never used them.
#4222
nick, i use the Mamba max, http://www.b-p-p.com/proddetail.php?...Max_Controller and i love the adjustability it has. -and you can find it with brushless motor at about 180usd.
You can change the throttle/brake curve, lipo cut/offs,timing, power out of line/how fast it starts from standstill (saves gears) and alot more -all using your own laptop/pc !
http://www.castlecreations.com/products/mamba_max.html
I dont know what kind of setups Novak has . I do know it is good though.
cool mamba vid. http://www.youtube.com/watch?v=46ssLpgky5E
#4223
So far I am tossing up between a Mamba ESC or a Novak GTB. I know I can run either brushed or brushless with the Novak but can I do the same with the Mamba? I'm only asking because I just bought a new motor and I don't really want that to go to waste.
#4224
ORIGINAL: nick89_
-quote from manual: "note, there is no motor limit with either Reversing brushed or high power brushed wiring methods")
