Old 09-29-2019, 08:31 AM
  #42501
Glowgeek
Extensive main gear mount rebuild on 50cc Yak fuse. A bit of a challenge on a foam belly fuse. Saito 45 and Crunchies 50 out of the cleaning tub, waiting on parts.
Old 09-29-2019, 09:44 AM
  #42502
Hobbsy
Hobbsy's Avatar
Originally Posted by Glowgeek
How's the shipping cost from Macgregor?
They don't have everything so I pick and chose between them and Horizon. They are pretty quick though.
https://www.hobbyplastic.co.uk/index...parts&x=13&y=7 Read carefully, there are a lot of non 50 parts mixed in.
Shipping===£6.20
Old 09-29-2019, 09:50 AM
  #42503
Glowgeek
Tried out my new Harbor Freight Ultrasonic cleaner and LA's Totally awesome cleaner for the FA50. It worked for a couple of minutes and stopped vibrating. Exchanged it at HF for a new one and the heater wouldn't turn on. Got a refund. Ended up cooking the FA50 at 150°f in the crock pot with green antifreeze, that always works if you have time to wait. Parts come out of the crock, get rinsed with hot water and then brushed down and with DNA while still warm. One more rinse with hot water, blow dry and sprayed with corrosionX. LA's cleaner works very well, even without an US cleaner, but not for hard baked on castor (very dark brown or black).
Has anyone here tried a weak solution of muriatic acid to brighten up these old engines? My 45 is pretty dark from oxidation and also has white powdery corrosion in several places.
Old 09-29-2019, 02:15 PM
  #42504
erieqc
The muriatic acid will make it look milky. We never use it on our polished aluminum rims.
Old 09-29-2019, 03:00 PM
  #42505
Glowgeek
I wouldn't use it on polished aluminum either, muriatic acid etches aluminum and leaves a more of a matte finish. I've used a paste to clean the oxidation off my aluminum canoe, i think it has some sort of acid in it to work like it does. Thing is, if you don't spray it off with water soon enough it will re-oxidize in a minute or two and give that milky looking finish you were talking about.
I have tried muriatic on a K&B cast muffler but I think the solution was too strong. The part actually started fizzing like an alka seltzer! Lol. It looked bright and uniform in color while it was submerged but once removed it oxidized to dark grey within two seconds. Anyway, I'll do some experimenting with the same busted muffler to see if I can dial in a solution that will remove the oxidation layer more slowly. That should give me time to get the part into a buffer solution before re-oxidation occurs.
I like bright Saitos.
Old 09-29-2019, 08:14 PM
  #42506
FlyerInOKC
FlyerInOKC's Avatar
It would be easier to paint it pink!
Old 09-29-2019, 10:25 PM
  #42507
Rudolph Hart
Rudolph Hart's Avatar
No updates on the pink panther yet mike?
Glowgeek you could try a weak solution of vinegar (put the rest on your hot chips) and water or maybe lemon juice. Muriatic, or in it's slightly purer form hydrochloric acid, is used to etch aluminium before painting, it's to harsh for saito's and should never be used.
Gary when the students all protest on their own time and not take a day off school i MAY start to think about fitting something electric to the duke after they throw away their mobile phones and give up airconditioning etc so i think i'm safe. I like all the pics you see of gas or diesel powered gen sets charging batteries for clean electric powered vehicles. Came home from the three day classic bike racing stinking to high heaven of methanol and castrolR hyuk hyuk, i ain't gonna shower for a week
Old 09-30-2019, 02:40 AM
  #42508
Hobbsy
Hobbsy's Avatar
Lonnie, to what extent are you rebuilding the 45 and 50, thanks, the last one I got from Crunch is pretty strong. I debated about getting the longer crank but settled on the short one, It is long enough for most props.
Old 09-30-2019, 03:06 AM
  #42509
Hobbsy
Hobbsy's Avatar
Pete, while you were off sniffing castor clouds, I ran the 50 Cap sent to me with great results turning one of your home grown Bolly Clubman 11.5 x 6. Thrust equals 5.80 pounds.
Old 09-30-2019, 03:35 AM
  #42510
Glowgeek
Tear down and clean up, bearings, tappets, carb kit, gasket set and pushrod cover seals. The piston ring appears ok on both engines, no glazing on the edge surface. Everything else looks good.
Pete, thanks for the tips.
Old 09-30-2019, 03:48 AM
  #42511
Hobbsy
Hobbsy's Avatar
Thanks, I reused both the ring and piston in the 50 I fixed up, I placed the ring gap over the rear of the wrist pin, I always do. The compression was a little soft at first but after the 40 minute run it is solid. I had a slightly better looking cam, so it's in there with new lifters.
Incidently, I calculated the thrust for the Bolly 11.5 x 6 at 10,570 rpm, I think 5.8 pounds is pretty good. I used an APC wide for the style since the Bolly blades are wider than the APC blades. The Xoar 12 x 6 at 9,320 makes 5.06, 9,320 is probably not the best rpm for the 50. The 56 turns the Xoar 12 x 6 at 9,860.
Check this calculator out if you don't mind. It's the one Quicky advocates. http://www.godolloairport.hu/calc/strc_eng/index.htm
Old 09-30-2019, 04:06 AM
  #42512
Glowgeek
That's the same calculator I use. Very handy for matching engines to planes and selecting initial prop sizes to try for flight.
Crunchies FA50 had badly flat spotted tappet edges from being run while gummed up (tappets not spinning in bores) but oddly had no dents on the cam lobes. First time I've seen that.
Old 09-30-2019, 04:11 AM
  #42513
Hobbsy
Hobbsy's Avatar
I am convinced that the dents occur during over revving, I prop for mid 9's and have never had a cam get dented. I do prop the little 30 and FA 40-a in the 10's though.
Old 09-30-2019, 04:34 AM
  #42514
Glowgeek
I can see where valve float would cause cam dents as well, or a sticky valve even, but I have seen it happen with my own engines twice, before I became an advocate of aro and lower castor content fuel. My rebuilt 56 and 62 (including new tappets) but both suffered from tappet beveling and cam denting when run after prolonged storage over the winter months. The valves weren't sticky and those rebuilds never saw the sunny side of 11K in flight. I was using a much higher castor content fuel back then so gumming was an issue. The tappets were stiff in the bores when I tore them down, thereby my assumption.
Edit: Give some thought to how much heat would be generated at the tappet/cam interface on opposite sides of the tappets if they could not spin freely in their bores. Over reving or a sticky valve can cause cam denting, agreed, but the tappet would show a normal circlular wear pattern if allowed to freely spin in its bore imo. My 56, 62 and Crunchies 50 were flat spotted on opposite sides of each lifter.
Old 09-30-2019, 06:09 AM
  #42515
FlyerInOKC
FlyerInOKC's Avatar
Since you asked, I picked up the Circus Pink Monokote late Friday. Not bad match too (see pic) However; this weekend was shot down building and leveling a base for the metal shed to store the new backup generator. I hope to get the shed completed this week. Its a Click-Well Shed made in Oz! I finally got the insurance claim approved on Friday for the storm damage and the contractor is coming by today with the paperwork so I can get that started. I am getting a new roof, gutters, roof turbines, garage doors, and Electric Heat Pump. 80+ mph winds really do a number on trees and the flying debris tears everything else up. I also have to do a bit of shopping to replace the damaged electronics.
Old 09-30-2019, 06:18 AM
  #42516
acdii
Good match. Purple sunburst on the wing?
I have so many things that are water damaged in my house, but have a $2500 deductible too. The only real fix for the money pit is a gas leak.
Old 09-30-2019, 06:37 AM
  #42517
Jesse Open
Jesse Open's Avatar
That tappet wear is accelerated by excessive clearances. Happens on full size flat tappet engines as well.
The rappets miss out on the initial, light loaded acceleration period and are then snapped hard on the closing side. Most of these engines actually seem to have spent more operating time at excessive clearance than they have at correct clearance. Have a look at how many cams show more wear on the closing side than on the opening side. This condition, is not normal in full size, especially on the exhaust lobe which is opening against the residual cylinder pressure.
Old 09-30-2019, 06:38 AM
  #42518
Jesse Open
Jesse Open's Avatar
Watch what you say
Insurance companies may be listening !
Old 09-30-2019, 06:56 AM
  #42519
FlyerInOKC
FlyerInOKC's Avatar
I was lucky, there was a contractor who had a relationship with AAA Insurance and he waived my $2000 deductible on the roof. I have cost of replacement so the electronics were settled at the cost of new equipment. With all the damage in the county the insurance premiums are going to jump again, they went up $400 this year, but you kind of expect that. I will get that little surprise next September when the insurance renews.
I'm going with white/red checkerboard on the vertical fin and rudder I have just enough to do it. I was thinking of adding some angled red strips on the top across the cord and maybe black or white on the bottom. I have a little of all three colors on hand. I haven't the cash right now for decals. The LHS I buy at these days after my regular shop retired is more of a R/C car place and he doesn't have much in stock. It took a little over two weeks for him to get the pink Monokote in stock. He blamed it on coming from the California warehouse, I think he didn't have enough to order and waited a week. He did charge me the same price as Tower and there was no freight so I can't complain about that.
Old 09-30-2019, 04:45 PM
  #42520
Glowgeek
Yes, the cam damage (dents) have always been on the closing side of the lobes, and more so on the exhaust lobe than the intake in every case. I dont however think it's coincidence that every Saito engine I've torn down that exhibited cam dents also had the coinciding tappet flat spotted on both sides. In the case of my rebuilt 56 and 62 all can say is the tappets and cams went south in less than 10 hrs flying time after the rebuilds. They were never over revved, the valve lash never exceeded. 004" but the tappets were not free to spin in the bores when I tore them down.
During the cam and tappet replacement this last time the tappet bores were cleaned spotless.
It'll be interesting to see how things look after 100 hrs with lower castor % and religious use of aro.
Disclaimer: I am not and never claimed to be an engine failure analysis expert.
Old 09-30-2019, 06:51 PM
  #42521
Jesse Open
Jesse Open's Avatar
Lonnie, I will have a look for the screw set. They may be all gone but I might have the individual acres.
Note, no pictures of trucks were posted. maybe if the bike had a Saito sticker on it, they would have kept it?
I lost posts without pictures
I think it had more to do with the person than the picture.
Old 09-30-2019, 07:09 PM
  #42522
Jesse Open
Jesse Open's Avatar
Not seeing the severe wear on my personal castor content oiled engines, but not seeing gumming at 2% to 4% castor either. I run between .001" and .002" clearance.
Saito tappets are far from precisely finished and it seems the tappet bores are short on lobe offset when you read the wear pattern on cam faces.
Hydraulic lifter and properly adjusted solid lifter cams show most wear on opening ramp. The engines with sloppy lifters usually show more wear on closing side. Not an "expert" analysis, not smart enough to be called an expert on anything. Just an empirical observation after over 20 years as part owner in a full service automotive machine shop during 50 years of working on engines of all types.
Old 10-01-2019, 02:58 AM
  #42523
Hobbsy
Hobbsy's Avatar
Nor have I seen excess wear on cams of my own nor on the ones I got from w8ye, Gary or Captain Crunch. I have one cam with a huge dent, the others are smaller. I use the OS gauge at a slightly draggy slide. So far so good. For years I used the Saito gauge with excellent results also.
Old 10-01-2019, 05:04 AM
  #42524
Glowgeek
I use a .0015" feeler gauge. The valve springs are so light on these model engines so I make sure the feeler has almost no drag. The end result is probably closer to .002"-.0025. I check the lash after the first 40 min run in period and again after each half gallon of fuel until things stabilize. Once a season after that. Never see more than .004" on my engines. On used engines I've bought and those rebuilt for others I've seen the lash as wide as .014". Those cams are always dented.
Old 10-02-2019, 12:11 AM
  #42525
Rudolph Hart
I use a tallyho roll up cigarette paper, if you can gently pull it through the gap without tearing it your done. We used to use rolly papers to check clearance on heavy barreled varmint rifles after glass bedding the action and barrel to a new stock.
ps my re distilling of fine spirits friend popped into work today with a part for me to paint. I'd been mulling over cleaning methods for aluminium on our saito engines and since he knows a lot about chemicals, i asked him if he thought coca cola would be worth trying. He got this look on his face like a baby the first time it get's it's arse slapped, biggest insult to fine spirits he's ever heard of.
