Old 10-03-2019, 07:11 AM
  #42551
FlyerInOKC
FlyerInOKC's Avatar
Interesting article.
Old 10-03-2019, 03:31 PM
  #42552
Glowgeek
Default Scuffing piston rings
Hey fellas, can you give me ideas on how to scuff a glossy piston ring and what grit of sandpaper to use? The ring is mostly shiny around its perimeter with only a couple of small areas still showing a faint representation of the original grinding marks. My thought is to use adhesive backed 100 grit paper adhered to a clamped down precision machinist square and do the work on my surface plate with the ring lying on a piece of 1/4" precision ground plate. The idea is to apply light pressure against the paper in a circular sweeping motion and take care to not sand across the ring gap. Am I on crack? Is there a better way?
Lonnie
Old 10-03-2019, 03:57 PM
  #42553
Hobbsy
Hobbsy's Avatar
Originally Posted by FlyerInOKC
Impress your grand daughter make the Fling King pink and name it after her! What does a Fling King look like?
Mr. Tharpe Flies his own with a Saito 80.
FLYIN' KING SPECIFICATIONS Wingspan: 80.5 inches Wing Area: 1280 square inches Length: 60 inches Weight: 9.5 to 10 pounds Engines: .60 - .75 2-stroke or .70 - .91 4-stroke or
Old 10-03-2019, 03:58 PM
  #42554
Hobbsy
Hobbsy's Avatar
Lonnie
I personally would not touch it.
Old 10-03-2019, 04:07 PM
  #42555
Glowgeek
Compression is weak, valve train is good and no leaks. It's not a Saito and the OEM ring is only available from Germany. The engine is not worth the cost of the ring but worth trying to scuff it. Thanks for your input though.
Someone posted somewhere that a guy on ebay has picked up where Bowman left off but I forget who the vendor is.
Edit: Found him. Gaviscool is the ebay vendor. He is swarf monkey on RCG. Prices are good and people have nothing but good things to say about his rings. I still want to try scuffing first, just to see if I can make it happen.
Old 10-03-2019, 05:23 PM
  #42556
Jesse Open
Jesse Open's Avatar
By all means scuff. 400 wet or dry is fine, just break the glaze. As little as it takes.
I got some m3 screws of the needed lengths together for that 50 you are reworking .
Old 10-03-2019, 07:53 PM
  #42557
the Wasp
Originally Posted by Jesse Open
Didn't somebody's son recently take a B-17 ride?https://www.nytimes.com/2019/10/02/nyregion/plane-crash.html
Gary, that was my son, and yes I was a bit worried. those poor people, my heart goes out to them !!!
Jim
Old 10-04-2019, 12:12 AM
  #42558
Rudolph Hart
Rudolph Hart's Avatar
I assumed they ran auto extinguishers even back in ww2 ?? because if i remember right the pilot on that audio says he has to get back 'and blow an engine out'
Dave that tharp is an unusual looking tail dragger but to me it looks ugly with the engine mounted like that.
Lonnie scuffing the ring with 320 or 400 grit wet and dry as gary said should break the shine off the outer surface of the ring. We use wet and dry sandpaper of various grades to sand cars before and after painting and i find that if you use soapy water or white spirits/wd40 etc it lubes the paper so it does not clog up, thereby increasing the amount of work you get out of it. Good luck.
Old 10-04-2019, 12:54 AM
  #42559
Rudolph Hart
Guys i planned to do a bench run after work, just finished making up a fa115 but it's too cold to leave my fingers behind the engine and tune it. Even the official gummint weather people are saying this is an unusual weather event here. Are we now in danger of slipping into an early ice age ?
Old 10-04-2019, 01:33 AM
  #42560
Glowgeek
Gary, Pete, thanks.
Old 10-04-2019, 02:29 AM
  #42561
Hobbsy
Hobbsy's Avatar
Don't most people scuff the liner or are you advocating scuffing both, Thanks
Old 10-04-2019, 02:40 AM
  #42562
Hobbsy
Hobbsy's Avatar
Then there is this, there are also twins and triples.
Old 10-04-2019, 04:03 AM
  #42563
acdii
We have had an unusual amount of rain this year. At least 4 times we have had flooding. In fact for the first time since I moved here in 2001 the road was flooded down 1/4 mile from my house. I am keeping a constant watch in my shop to get any water before it can get to my work area. Don't want any of my Saitos to be in danger.
Old 10-04-2019, 04:14 AM
  #42564
Glowgeek
I bet those quads sound great!
Old 10-04-2019, 04:19 AM
  #42565
Captcrunch44
I just got another 50GK
looked bad on the outside but on tar down I found its a low time engine. Some cleaning and new bearings and I should have pretty good little 50
Old 10-04-2019, 04:38 AM
  #42566
FlyerInOKC
FlyerInOKC's Avatar
I wonder if it has one big tank or 4 smaller tanks?
Old 10-04-2019, 04:43 AM
  #42567
Captcrunch44
Usually they have four tanks or one per engine.
Did you ever see the de Havilland flying boat with 18 four strokes on it. it had one tank per engine
correction don year 12 engine airplane
Old 10-04-2019, 04:50 AM
  #42568
Captcrunch44
And to think there are people who can’t keep one glow engine running
Old 10-04-2019, 04:57 AM
  #42569
Glowgeek
Crunchy, congrats on that 50GK.
Dave, I've never heard of anyone scuffing a chromed cylinder. That's some pretty hard stuff.
Old 10-04-2019, 03:09 PM
  #42570
Hobbsy
Hobbsy's Avatar
Me neither too, On installing old the piston in a new 82 cylinder, the ring I had in a package of several I got from w8ye has a black edge. It's new and fits perfectly I am not going to touch it. I don't think it's a Saito ring.
Those 50's are addictive.
Old 10-04-2019, 07:21 PM
  #42571
the Wasp
https://m.youtube.com/watch?v=q_j1EP5gwqA
yes, I posted it about a year ago. it's a crazy-cool plane, love it. but I don't understand why he did not use Saito 100s, they would turn larger props and therefore he could fly it at a lower throttle setting. and, if 1 or 2,,,,, or 3 engines flamed-out he would had more power to get it around to land. never the less the plane is just too-cool
wait wait wait, 12 Saito 100Ts would be even better
Jim
Saito owners have longer strokes and larger pistons
Old 10-04-2019, 09:51 PM
  #42572
the Wasp
not a Saito, but pretty cool indeed,,, man
Jim
Old 10-04-2019, 11:08 PM
  #42573
Fast Pilot
I need help.
My Saito 82B vibrates too much with 14x4W propeller.
My Hangar 9 Twist 60, without wings, vibrates so much that I'm afraid it will shatter. Which propeller do you recommend?Thanks a lot
Old 10-05-2019, 01:25 AM
  #42574
Rudolph Hart
FP welcome. It sounds like you are running way to rich saito's are silky smooth for the most part. A 14x4 prop is on the small side for the fa82, i usually run apc 14x6 pattern props and you can hover on those.
Dave can you post a pic of the fa82 ring, what brand is it?
Crunchy does that dornier float plane run gas two strokes, it sure sounds like 20 of your best mates have rolled up at your house to mow the lawn with weed wackers but i admire that guys scale building effort and he flew it well too. Can you imagine crashing that many hours detailed work? it would take you just as long to sweep the parts up.
ps how many here like me who cannot understand spending heaps of money and hours on a scale classic only to fit a weed wacker to it?
Old 10-05-2019, 02:07 AM
  #42575
Glowgeek
Originally Posted by Fast Pilot
I need help.
I have two 82b engines, they both vibrate more than any other saito engine that I have run. The APC 14x4W prop should work well for your Twist. Make sure your Prop and Spinner are perfectly balanced. If the engine is new or still breaking in you will need to lean the low speed needle as the engine gets more and more broken in. As Pete mentioned, a rich running engine will vibrate more than one which is properly tuned.
Note: Without the ballast weight of the wings the fuselage will vibrate more than with the wings attached.
