Old 11-01-2019, 04:52 AM
  #43251
Jesse Open
Jesse Open's Avatar
Who in the world said it was "wrong" because it was "different"? Then again, seen you do that a few times
Same principle, same factors at play They were around, both store bought and home made copies for decades now. Actually DuBro copied the home made ones.
Hardly ever see anyone using them any more. Like I said, flip the lever arm down, put a ball link on the end, go fly .
Sorry.
Old 11-01-2019, 04:58 AM
  #43252
Hobbsy
Hobbsy's Avatar
I suppose I could drill all the holes out and create some slop.
Old 11-01-2019, 05:04 AM
  #43253
Glowgeek
Someone should invent a small servo that replaces the throttle arm. No slop or friction. Just screw it on and run a servo wire. Probably wouldn't be good for cdi engines though.
Old 11-01-2019, 05:12 AM
  #43254
Jesse Open
Jesse Open's Avatar
Of course you could LOL!
But that would be just additional slop. Save the effort. every joint will wear over time. The increase in slop is automatic. Cumulative clearances and cumulative drag effect:
Every pivot and every joint joint add drag and working clearance. Every angle in the linkage adds more to that. One good thing, as the slop grows, the drag in diminished.
Still better, you could simply....Flip the lever down, put a ball joint on the wire and go fly. Less drag, less slop and far fewer fiddly parts to diddle about with.
Lonnie, A lot of the gasser guys mount the servo on the firewall and use a short, straight wire linkage.
Old 11-01-2019, 05:34 AM
  #43255
FlyerInOKC
FlyerInOKC's Avatar
I have used the DuBro version on my Cub. The engine sits in a box firewall with a 3/4" insert. to keep the profile scale. The box firewall and the lack of space from putting a .80 in an airplane calling for a .40 to .45 two cycle or 45 to 60 for cycle. prevented running a pushrod of any type from getting to the arm. The DuBro linkage made it doable to connect a flex cable and allowed me to adjust the linkage if needed.
Old 11-01-2019, 06:05 AM
  #43256
acdii
I use nothing but cable setups on the 4 strokes. So much easier to route them around the fuel tank, and get close to the firewall. The trick is to slot where the casing exits the firewall so it can move with the throttle arm to prevent binds The one and only time I had a throttle arm failure was on the Gemini 120 where the screw loosened up. On a couple of the DLE setups I used Golden rod due to the distance between the servo and throttle, I would have to had put braces in to prevent the cable from flopping around.
Old 11-01-2019, 06:07 AM
  #43257
Captcrunch44
I probably have more slop in the servo arm then you would have on a Dubro or home made linkage.
I have tried to make linkage but my lack of attention to detail sometimes gets in the way.
that is a cool idea. Make a mount to hook the servo directly to the throttle barrel they do it on elevators in ailerons and some of the big airplanes.
hmmmmm
Old 11-01-2019, 06:14 AM
  #43258
Jesse Open
Jesse Open's Avatar
Here is the DuBro linkage.
Old 11-01-2019, 07:08 AM
  #43259
FlyerInOKC
FlyerInOKC's Avatar
That was what I used.
Old 11-01-2019, 12:46 PM
  #43260
Hobbsy
Hobbsy's Avatar
Xoar Gas Painted 18 x 6's.
Originally Posted by Rudolph Hart
I think they were using the s bend
Ok Pate, question, what does Gas Painted mean, these two Xoars are 18 x 6's for the 180 and 182.
Old 11-01-2019, 12:56 PM
  #43261
Glowgeek
With an aluminum standoff of needed length affixed to the throttle arm (if needed) a flex cable has always reached where needed on my planes. I have also used metal control rods bent in a "U" shape (Trombone) on a couple, nothing wrong with that technique. No monkey motion whizz bangs needed for my planes yet.
Old 11-01-2019, 01:02 PM
  #43262
Hobbsy
Hobbsy's Avatar
No monkey motion, they are slop free as I mentioned earlier. I don't like the U because it's never the same as the full throttle arm arc. They require a slot so they can move with the arc and then they flex in the slot.
Old 11-01-2019, 01:41 PM
  #43263
Jesse Open
Jesse Open's Avatar
For sure. Yes, I often make up a spacer to shift sideways a bit. It has been a long time, like thirty years since using the trombone trick. A little time spent planning and you can, more often than not, avoid using contraptions to do what should be a straightforward simple task.
Straight and direct is the least slop and least friction.
Old 11-01-2019, 02:11 PM
  #43264
Glowgeek
The first trombone I made too short and had problems like you mention, binding. I remade it much longer, reaching almost all the way forward to the prop drive washer with a big radius and then returning to the throttle arm. It also had a bit of an offset to miss the cylinder fins and still align with the throttle arm as it returned. I tried using a ball link on the throttle arm but that allowed it to twist so I ended up using the set screw style adjustable fitting. Not too fond of how that one turned out even with a slot in the firewall. I should have used a throttle arm standoff instead, which I did on the next one. That worked much better but the cable/standoff setups install easier for me.
I've seen those 4 stroke linkages on other planes, warbirds mostly and no complaints by their owners. "Whatever suits you just tickles me plumb to death".
Old 11-01-2019, 02:50 PM
  #43265
Hobbsy
Hobbsy's Avatar
Quote: ""Whatever suits you just tickles me plumb to death". Amen Brother the light shines on us both..
In a way of explanation, I use a 3/16" length of fuel tube inside the splines of the servo arm to serve as a bushing which is very precise. A little bolt tension on it keeps the linkage from dancing around. I need some Ball Links for the future ones.
The paint on those Xoar props is absolutely flawless. No chicken stick for them. Back flip if the engine is amenable.
Old 11-01-2019, 02:55 PM
  #43266
Glowgeek
Those props do look nice Dave. Paint rollers make great chicken sticks.
Old 11-01-2019, 02:56 PM
  #43267
rafeeki
rafeeki's Avatar
Default Saito FA 180 anyone?
Looking for an unaltered Saito FA 180. anyone has one?
I already have 2 and a Golden Knight Fa 150. Very reliable imho
Tks
Rafeek
Old 11-01-2019, 03:22 PM
  #43268
Jesse Open
Jesse Open's Avatar
More like it.
A bit of reality tossed in helps.
Old 11-01-2019, 03:43 PM
  #43269
Jesse Open
Jesse Open's Avatar
Default What's up with Saito carbs lately?
A few months ago Jim had a rather snug carb problem. I massaged it and sent it back thinking all was well. When he got it back it was still too tight for his setup. I sent him a brand new body and that worked fine. I since did a bit more massaging and that carb is on a fine running engine.
Last month I bought a brand new 125 Saito carb for an FG 20 gasper that I converted to methanol/spark running. It was sooooo sloppy that it rattled. Real bad!
I called the dealer and they said send it back. I left out in an unsealed box on the freezer. The Norwegian Princess thought it was an empty scrap box and tossed it out. No problem, it was garbage!
Well, earlier this week I ordered another 125 carb.
It arrived today. Another sloppy rattle.
I surely prefer a tight one that needs relaxing.
Old 11-01-2019, 03:57 PM
  #43270
FlyerInOKC
FlyerInOKC's Avatar
Old man Saito would have had someone's head on a pike for that kind of quality control!
Old 11-01-2019, 04:39 PM
  #43271
acdii
Did it have made in china stamped on it anywhere?
Old 11-01-2019, 05:15 PM
  #43272
Jesse Open
Jesse Open's Avatar
Not yet but thanks for the idea!
Old 11-01-2019, 07:14 PM
  #43273
the Wasp
as for the throttle linkage I like the Golden Rod, it's so easy to setup.for the servo side I take some metal linkage rod that is only threaded at the end, ".072 OD is too small", cut it to the length I need and push it into the Golden Rod. usually I can only push it into the G-Rod 3 inches or so. or thread it into the G-Rod and used E-Z Connectors. on 2 stroke I do the same on the Carb side
I have heard people say they do not like E-Z Connectors because they become loose, but those complaints were when used on control surfaces not the throttle that has a lost less friction on the parts.
my World Models P-40,
my Great Planes ShoeString,
Jim
Old 11-01-2019, 07:23 PM
  #43274
the Wasp
Notice the Airtronics "wing" servo I used on the throttle of my P-40, it came on a used plane I bought, it had an JR connector on it and it had only 2 flights on it. it's small, so I used it for the P-40's throttle, I have one more
Jim
Old 11-01-2019, 11:36 PM
  #43275
Rudolph Hart
Rudolph Hart's Avatar
I hate trombone throttle set ups like sylvester hates them meeces to peeces. Agree with everyone that golden rod throttle set ups are reliable and easy plus long lasting, but i did make a mistake when i modified the throttle set up for the fa182 powering the h9 taylorcraft. Only had about ten flights from new and was prepping it for a coming weekend with the cowl off when i noticed the exposed yellow rod that sat next to the right hand of the right exhaust pipe had turned slightly brown and had a kink in it, making it a little shorter, so no full throttle. After installing a heat shield that divided the exhaust and plastic throttle cable i was sure problem was solved after ground testing. Long story short two flights later and doing a few touch and goes i throttled back on climb out but nothing happened, in australia we have a very hearty black sense of humour so the dozen or two sympathetic pilots had all sorts of suggestions for me. In those days it had a very big fuel tank so the agony went on for more than twenty minutes, turns out the brass clevis got hooked up at full throttle on the leading edge of the heatshield i fitted.
ps dave i never heard of gas painting in the sense you mention do you have a link?
