Official Tamiya TT-01 Thread
#4451
ORIGINAL: solo13
Hello all, just got a used tt01 an was wondering want servo to use. Thanks in advance
Matt
#4453
Doesnt anyone else use RC mart? Had any problems?
#4454
Hi guys i am new to this forum and new to the tt01. What i would like to know is what the difference between the standard silver motor that comes with the tt01 and the sports tuned motor that comes with the tt01d. Is it any quicker.
#4455
Yes it is faster. Look at http://www.tamiyaeurocup.co.uk/cars/motors.htm to compare the various Tamiya motors. The lower the turn, the faster the motor (but the more battery juice it needs). The standard silver can is listed as the RS 540-standard, sometimes also labelled as 540 J where J stands for Johnson, the manufacturer.
#4456
Ok thanx chrisestto1. Can you swap the standard motor out for any 23 turn motor with out having to upgrade the pinion and spur gear. Is it worth the upgrade or would it be better to do a bigger motor and change spur and pinion. Any help would be much appreciated. Thankyou.
#4460
Ah ok so it will work with those spur and pinion, im only new to this. I have the standard tamiya ESC, I will need to upgrade this also wont i? If so what ESC and motor would you recommend. In turms of brand and models.
#4462
stock needs no upgrade in esc, 19t you need to make sure it can handle it. tamiya has charts that explains these options.
#4470
TEU-101BK is an easy to use ESC that boasts all the functions of the high performance TEU-302BK with power output equivalent to the CPR-01. With size and shape virtually the same as the TSU-01, the TEU-101BK can be fitted in most old RC cars.
High quality FET with output compatible with up to a sports tuned class motor(23t).
Easy push button setup for maximum positioning of neutral / acceleration and reverse (braking).
Features reverse disable function for competition races.
Compatible with most makers RC systems
#4471
Why thankyou, i am amazed at the level of knowledge on here. Yeah i do have bearings upgrade and an Auli prop shaft and that has made a difference.
#4473
I dont mate, just got into it. i mostly use it for drifting but i want it to be able to move pretty well when i want it to.
#4475
Hey guys maybe you can help me out! I have a totaly hoped up TT01, its got all the must have upgrades + extras. Im finding tho that my ESC and Motor are getting kinda hot. Im not sure sure what temp is safe so thats what im here to ask. My Motor is a 19T peak racing and its reading 144* and my ESC is a Tazer 15T off the fins im getting 140-145* and the ESC it self is 100-110* Is this normal? Or shoulld i gear it down? i dont have any real wheels right now just a set of home made drift ones and these are the temps im getting just from booting it around in side my house. I do have a heatsink for the motor comming sometime next week i sure ut will help a bit.....Should i mount a fan some how to help cool it aswel?
Any help would be grate! Thanks in advance.
Slim.
Slim.
