Let's talk DX18 here!
#426
The model started out on a DX9 and then I moved it to the DX18 out at the field. That was when I started having trouble. I'll start fresh on the 18. I have in the past used the monitor to solve similar issues. I actually kind of forgot about it. Model building has been kind of slow this past year. Too busy running our 5 events, 2 school programs and the local village.
#427
My Feedback: (44)
OK
Curious there are no comments on the HH Bulliten about possible limited range limit on some DX 18 Gen 2. I've had mine for a year and have basically performed OJT range checks when flying. I always run range check before each day of flying or if I should change models durring the day.
I went ahead and did the controlled full power range check with a receiver and servo on a box and got to 4800 feet before receiver lost line of sight to the transmitter. I may find a longer section of road but I never fly that far.
I generally do my on field range check (reduced power) at 40 paces which is more than the 28 meter distance in the manual. I found at the reduced power check I see the control surfaces jitter at about 80 long paces.
Just thinking this issue may have come up on Quad flyers. They tend to go out a lot further than most type of aircraft because they probably have the come home button if they fly past the range of good visible control.
Funny Story: had a guy in our club flying the 350QX quad and lost sight of it. He panicked a little than hit the come home button: it landed in from of him about 3 minutes later. Of course this feature highlights the problem with quads and not maintaining visible control of the plane at all times.
#428
For more information from the source: http://em.horizonhobby.com/public/?q....VZ8iEQ.nrmvfQ
#429
My Feedback: (44)
OK
Let's discuss range checks. If the use of the reduced power range check is not adequate to sort out this type of issue, perhaps we are dullding ourselves that a full power range check is not necessary. In only 35 years of RC flying, I've never done a full power range check. Never had a flyaway either.
Or perhaps Spectrum should specify more distance for the reduced power range check.
It does appeaar that there are probably very few transmitters with this problem. The bulletin did not cover serial numbers effected. It did say a green dot was in the battery compartment on safe transmitters. My radio did not have the green dot.
I did send HH the results of my range test and serial number.
Cudos to HH for getting this notice out quickly, even if it turns out to be only a hand full of transmitters have the problem.
#430
#431
My Feedback: (57)
I lost my H9 60cc Corsair because of a lock out on the second flight. Total loss ($3K). I sent the DX18 gen2/12ch rx in for a check out, got a clean bill of health. I vowed to never use that radio again and sold it. Now I get this notice in the mail !
Guess what, I will still never use one of these radios again !
#432
My Feedback: (44)
OK
Andy,thanks for clarification. I started uisng 2.4 system in 2009 with the JR 12X and really like that radio. Went to DX18 G2 last year to get the easier program and digital trim on throttle, plus have a lighter unit. Started using voice alerts and getting to like that feature, too.
I've never done full power range checks but now that I'm flying more expensive planes, I can see making that a check at least when the system is new.
Was nice to see that when I moved the receiver out of the line of sight to transmimtter and lost signal, it regained the signal when I moved the unit back to line of sight.
#434
It depends on the wing types. If you have them set up as something with Flaps in the name, then you can use the Flap System screen. This allows you to specify the positions based on a switch. It also includes elevator compensation and delay, which are important features of flap use.
If you have the wings set up as Normal, then flaps are based on the position of switch D. You can adjust the positions using the Servo menu's Travel option. This is a bit kludgy, though. I recommend using a proper Wing Type and the Flap System.
Andy
Andy
#436
[TABLE]
[TR]
[TD]NEW Multi-Rotor AirWare Update Available
[/TD]
[/TR]
[TR]
[TD]With this update, your Spektrum™ transmitter will give you the option of selecting a Multi-Rotor model type that includes specific programming functions for multi-rotor aircraft. These additional functions will be particularly useful with the new AR7700 serial receiver that should be available any day now.
What's New
While the new programming will vary slightly from transmitter to transmitter, common features will include:
- New channel input names: Altitude, Roll, Pitch and Yaw
- New multi-rotor items for pre-flight checklists
- New multi-rotor flight mode setup
- New channel assignment options that let you customize control inputs for each flight mode
- New voice alert options for multi-rotor functions
The complete list of multi-rotor features for your transmitter is available in a Software Update Read Me file on the Spektrum Community site.
Update Version List
This AirWare release applies to the following transmitters and updates their software to the version shown. Remember to back up the models in your transmitter's memory to an SD card before installing this update.
[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD]Go to the Spektrum Community site right now to learn more and download the update for your transmitter.
[/TD]
[/TR]
[/TABLE]
[TR]
[/TD]
[/TR]
[TR]
What's New
Update Version List
[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[/TD]
[/TR]
[/TABLE]
#438
#439
Thank you! I didn't notice that, so I've edited my previous post to avoid confusions.
Carlos
#440
Andy
Andy
Andy,
the link for how to test your DX18 for the range issues no longer exists... can you get us an updated link? I haven't had a chance to test mine and wanted to re-find the information and test it out.
#441
It's the 18G2 and Stealth if memory serves and you don't need it if you have the green dot in the battery comparment
edit: here you go http://www.e-fliterc.com/Products/Su...rodID=SPM18100
#442
I guess my question would be. I don't have a green dot on my Stealth, and I also don't have a place I can really test this out, lots of hills here.... Should I just send it in?
#444
DX-18 G1 software status
I was looking at the DX-18 G2 and see that the G1 is available for a lot less. My understanding is that the only difference is voice, wireless trainer and 1/2 mix rates. Is this true?
Also, can someone tell me what the latest version of the software for the G1 DX-18 is and possibly what it included.
I would probably get a G2 if you could get TX only. I have no use for a 9020 RX. Will sell the one the G1 comes with and take the hit.
Thanks.
Thanks.
#445
Those are the differences. i thought voice was a gimmick till I got used to it and have used WLT several times now.
The software is probably not the latest but it requires nothing more than registering when you get your radio and downloading the latest on the Spektrum web site. What firmware comes on it is either the base or whatever was available when your radio was packaged but I suspect the base version is probably what they ship with.
#446
I like the voice because there are only three alarms w/o it. (i.e. tone, vibration and both) I run telemetry and have a different voice alarm on each parameter. I do not have to take my eyes off the jet to scroll to the telemetry screen and look why one of the three alarms is sounding. Also, the voice is used on flap position as a verbal indicator where the flaps are at. W/o voice, it is hard to tell out there w/o re-positioning the switch. Same thing for brakes and smoke pump when empty , etc. Flameout = tone and vibration.
#448
Want to meet the Chief Monkey? I'll be at the LVRCS Electric Fly on June 4. There are usually a few other guys from Maryland there, so you won't feel alone (you wouldn't feel alone anyway - great crew!). You're welcome to come and I'll be more than happy to show you anything you need to know. I'll have DX20 code in my transmitter, so anything will be possible.
I'll show you exactly how to make the radio do anything you need.
Andy
Andy
#450
Once you get used to the way things are accomplished, things are typically a lot easier. One just has to get used to the fact that when using the Wing and Tail types, certain channels are typically used for certain surfaces. And, ... if you drop Andy a line, he is always there to help us figure out what he was thinking when he designed the software, even when we are less than tactful.
