Danker,
I can't answer your question but I did run into a similar situation and thought of something for your consideration. I was building up a P-51 kit and was going to use a Saito 125 for it. Luckly, I had the forethought to put the engine against the plans and found out that the Saito 125 would not fit my particular airplane - the engine was too long and I couldn't move the firewall back. If I hadn't checked, I could have painted myself into a bad corner on this one.
I don't know if this is an issue for your kit and the 150. I just thought I would point it out in case you might want to check.
Just my $.02
Bob.
Just my $.02
Bob.
So, decided to put the progress on the recovering up. https://www.rcuniverse.com/forum/kit...l#post12610740
Has the Saito 100 on it, now have to find a prop and spinner for it
See what you've done? You've made the rest of the Chippie look so nice there's just no way you can leave those two lower stripes on the rudder like that.![Big Grin](images/smilies/biggrin.gif)
A 14x8 would work well with the fa100.
Yeah, that will be fixed too. I have to order some props. Going direct to APC, Tower prices are outrageous. Went to Valley View RC but they are out of stock on the XOAR props I need. I need to do a quick once around to gather the sizes in use on my planes and get a few spares for them all. The one size I have plenty of are 11x7 for the LT-40. I may throw a 12 x 4W on it for kicks to see if I can actually get it to hover. I came close a few times before the nose flipped over.
I hovered my LT-40, it's not easy, even harder if nose heavy as most high wing aircraft are set up. Moving the cg back will help.
Stall the plane up high and with no throttle put it in a vertical dive to see how aggresively it pulls out towards the canopy with the sticks at nuetral. Keep moving the cg back until it barely pulls out on its own; that will ensure that the plane is still stable. It will not only hover better but will also require less down elev when inverted and little to no up elev to land. Other bonuses to a more rearward cg will be greater elev sensitivity and less propensity to climb with increase in throttle.
saito Saito SAITO!
Well, it no longer has a trainer wing, it goes where I point it. If I point it nose down, it goes nose down, nose up, it goes nose up, 45* bank it stays in a 45* bank. I flattened the wing so it no longer recovers on it's own. The only thing it won't do is tip stall because of the angled wing tips. I know it is nose heavy though, I have zero weight in it, it just built nose heavy but plane to move the battery pack back a bit, probably under the servo tray. It flies well with the FG-11, and actually did hover a bit with the OS 52 on it on a calm day, any wind would push the nose over though.
It only had one flaw, it wasn't powered by a Saito.
![EEK!](images/smilies/eek.gif)
Originally Posted by Danker16 View Post
in regard to the top flite p 51 arf 64.5in would a saito 150 be too much for it? Im looking for a speedy p51. Or would the 71in p 51 hangar 9 be better suited?
I agree that the 150 would be too much/too large. we have a guy in our club with a .60 size TF P-51 and it had an OS 65AX and it flew great, while not overly powerful it climbed out well. so I would suggest the Saito 125..if you go to Y.T. and search you will find many TF .60 size war planes flying very well/even fast with the Saito 100. I will come back and edit videos..
Jim
my favored Saito video, a TF Spitfire with a Saito 100 in-line twin,
P-40 with a Saito 100 in-line twin,
P-47/a Saito 100,,
oopps, here you go, a TF .60 size Mustang with a Saito 150,,
another one, same^ plane,,
Counter productive though, more weight on the nose means more weight in the tail. A good balance of weight and power is a must. If a 115 puts out the same as a 125 but at a few ounces lighter, then it is a big plus. If a 150 fits without any added tail weight, then it is also a good fit. It's a point of diminishing returns.
Look at pickup trucks as an example. Ford has lighter trucks with higher capacity, but also smaller displacement engines with more power than much larger engines. A big bad V8 6.2 might have as much power as the 3.5EB, but the lighter truck the 3.5EB is in makes it faster yet also give it more payload, so bigger, isn't always better.
or do what I did on my ShoeString, put the battery in the tail to get the correct balance.
Jim
Counter productive though, more weight on the nose means more weight in the tail. A good balance of weight and power is a must. If a 115 puts out the same as a 125 but at a few ounces lighter, then it is a big plus. If a 150 fits without any added tail weight, then it is also a good fit. It's a point of diminishing returns.............................
Jim, I agree. Always better to shift existing weight than add weight. My WM 46 size P51 has two 4.8v batts in parallel mounted in the radiator scoop to balance and that's only with an OS70 surpass up front! I have plans for that old girl. She's getting slab tail feathers and a YS 91. I'm adding weight to both ends! AUW should be just a touch over 7lbs.
Can't wait to hear that thing scream at 12K plus with a 12x12N prop. Muhahaaaa
![Stick Out Tongue](images/smilies/tongue.gif)
True on all points except what's in bold. Surely I didn't spend all that time comparing the 115 to the 125, did I?
Can't wait to hear that thing scream at 12K plus with a 12x12N prop. Muhahaaaa![Stick Out Tongue](images/smilies/tongue.gif)
https://www.youtube.com/results?sear...midget+mustang
later !
Jim
Oh ok Jim, thanks for looking. Mine is a WM .46 size P51 (Rockwell International version). The Bob Hoover Reno Racer model. It's still available from WM. Solid built plane but mine needs some work, the horz stab is busted (previous owner). Also the hinge lines are too wide so I thought I'd rebuild the empanage with solid balsa, recover the whole plane and get a set of decals from Callie. It's going to be fast, not pylon racing fast but fast enough. I'm shooting for 125mph with the ys91 and a 12x12 or 12x13 prop, we'll see but that project is down the road a piece.
