Your 150GK is making very good numbers, a healthy engine. Have you head-to-head tested CP against CP-MV with that MTEC additive for extra power output?
Rowdog, i'd use some aluminium pipe and a hand held bender, slip the adapter for the exhaust thread on and flare that end. My fa182 twin came with very thick aluminium crush washers.
Hi capt, i have a small, and very vicious, brown and white fox terrier called saito who will be happy to bury your lazy fa125's
Lonnie i am very happy with my three fa82 engines,they are my go to engines for 46 size arf's like the decathlon, the one with the huge dent in the intake tube pulls 300 rpm more than the other two.
ps i hope they let me keep the junior member tag it makes you feel younger
Jim
Last edited by the Wasp; 08-04-2020 at 12:16 PM. Reason: sorry for the late edit, my eyes are getting old
Saito
Saito are finicky when you run them inverted. I have 4 fa180s all of which are inverted but with the help from a Perry pump would think they were upright👍
Right side up or inverted I'm seeing no difference in running behavior, that is, if the centerline of the tank is close to level with spraybar. If the tank is at the correct height +/- 3/8" and you're still experiencing problems the engine is either not broke in yet or the LSN is set too rich.
Flooding can be a problem during refueling when inverted. To avoid that I press and hold my throttle cut switch while turning off the main switch on the aircraft. That keeps the throttle completely closed during refueling and transport.
Sweeeet.
My numbers for the 115 using 15%, F plug and apc props:
FA115
16x8 (7830) 1.812 HP
17x6 (8170) 1.968 HP
15x8 (8680) 1.907 HP
16x6 (8700) 1.864 HP
14x8 (9800) 2.083 HP
15X6 (9850) 2.090 HP
FA115
Question with fuel spitting out of one of my saito carb. I have checked the clunks, changed the fuel line, changed the low speed needle setting and even the high, carb to fuel tank placement is good. The only thing I have not checked are the o-rings, which I feel would lean the mix if they were bad. I changed out the motor with exact same motor and that motor runs good with no spitting. Engine actually runs good considering...
Ideas,Feedback?
It is a 60t...
Ideas,Feedback?
It is a 60t...
Glowgeek Thanks for the suggestion. That still did not work so I decided to pull the engine apart and saw the cam was damaged probably causing it to no turn true. If you see the end of the cam of broken off. Which in turn was probably causing the intake valve to not function properly. Does not seem like any other damage was done but will fully break it down just in case.
Ok Guys
Utter devastation and woe unto me.
My FA 62 wouldn't lift my goldberg arf cub off the water this morning.
7000 rpm with a 12/10 on it. Couldn't break the water lock.
Probably lucky it didn't on the maiden.
