Returning to glow-powered kits that I build, after a long hiatus, I bought a Saito 40 a couple of months ago for my SIG Cub. Earlier this week, I got a Saito 62 for the Somethin' Extra that I am currently building, and I will be breaking it in either tomorrow or Monday, after my prop reamer arrives. The only thing that currently bugs me about Saitos is that some prop shafts are US (the 40 - 1/4-28), and some are metric (the 62 - 7mm, I believe). I would think they would all be the same units.
Many years ago, I had a Saito 100 and 72.
I am extremely partial to 4-strokes, and doubt I will be buying any 2-strokes for future models that I build. I'm the same way with motorcycle engines.
what,,, wait,,, is your name Gary ? LOL
http://www.mecoa.com/index1.htm
Jim
Mike! stop stealing my jokes but seriously, it is always a shame to see a nice model lost through pee poor piloting skills. it would have sounded far better with an fa125 in it
ps i hope the builder and or pilot remembered the old trick of stashing a huge garbage bag behind the cockpit in the fuse, it makes it easier to carry the electric motor and house brick size battery packs back to the pits. If it had a 125 in it you could just leave it there.
Jim Bob
Maybe the lincoln wasn't powder coated or perhaps poorly prepped or didn't didn't get cured at the correct temperature. Who knows, but powder coating is one of the toughest finishes out there if done right. Not something you're going to rub off with your finger anyway.
FG-20 Converted to Methanol
Lonnie,
I think you commented some time ago about never having seen a 125 CDI on methanol fuel
This is a very old FG-20 that I converted back to methanol.
Has an RCexl ignition and an FA-125 carb.
Also has factory silencer fitted with a custom oversized tail
I was a little disappointed to not get more revs out of it with that much time on it, and I hope it gets better. But it sure did start easily and idle pretty low already. I'm building my SSE fairly light, so I am really hoping it has enough power for unlimited vertical and a little hovering.
ps gary good to hear from you
I ran four 8 oz tanks through the 62 today, before it rained, and it is now fairly broken in. I imagine (and hope) the top rpm's increase a good bit as it gets more broken in, as I was only seeing just under 10k with a 13x6 APC. The instructions state 11,500 peak on a 13x6. I wasn't trying to lean it out for the max yet, but near the end of the 4th tank, with over 40 minutes run time, I wanted to get it near the peak, then richen it up until it dropped about 300 rpm (following the instructions). At about that 10k, going any leaner, it started dropping revs, so I immediately richened it, before shutting it down, as the rain started.
You didn't state what fuel you're using but anything over 9700 peak rpm with an apc 13x6 is excellent power output. The Horizon Hobby benchmark is "APC 13x6 @ 9900" however that kind of performance would likely require 25% or higher nitro content in your fuel.
Now that your break in procedure is complete it's time to check and readjust the valve lash. Using a .002" feeler gauge is best to use for that purpose. The religious use of after run oil or Dextron ll ATF after each day's flying session is a good idea, It minimizes rust formation on the internal parts. Injecting approx 3cc into the engine through the crankcase vent line and tilting the engine in different directions to distribute the oil works best.
My two 62's would turn an apc 13x6 at 9600 peak on 15% fuel. Richened 300 rpm for flight (9300) produces right at 7 lbs of thrust, plenty for unlimited vertical on a 5lb plane such as an SSE. My SSE built to just over 5 lbs and flew good with that engine/prop combo. A 12x7 prop on this engine is great for flying 40 size warbirds at scale speeds.
Lonnie
Key Features
- 0.62 cubic inches of power in a 0.56-size case
- Integrated head transfers heat more easily and evenly
- Turns an APC 13 x 6 prop at 9900 rpm
- Installs easily in all .40–.72 models
- Unique champagne color drive washer
- True chrome AAC cylinder lining
- 1-piece cylinder head allows engine to run cooler
- Backed by a full 3-year warranty
My numbers for a Saito 62-b: MA 12x6 3 blade 10% full syn. fuel max rpm 10,150, idle 1,850 Glo-Devil, 4c plug.
Yes, very collectable to the right person, some are in love with them it seems. They have an excellent reputation for having the grunt to spin larger props than the 120S (except maybe the high cr early version). I'm not sure why as they have the same cam, bore and stroke. Not sure on the carb bore differences. They are said to run smoother as well, no doubt due to the additional weight from using larger castings.
Anyway, it should be a fun project to refresh the ol' girl.
Edited to remove misinformation.
As I recall not the same cam, the lifters as well are totally different. No mushroom. The Fathead will idle far, far lower than any other Saito I have seen. Lots of fin, very tame compression. Not an engine for those looking for a virtual two stroke on peak RPM. For those who fly the wing, the Fathead is precious.
