I see you have the Eldon J. Lind Magnetic Building Board, on mine the plastic is aged and breaking. I've been slowly making aluminum uprights for some of the vertical stands. The board is two .125" x 24' x 8' steel sheets laminated together. I couldn't remove the original board from the work bench in Alexandria. I used contact cement to glue it down, it either bent or tore chunks out of the wood when trying to pry it up.
I take it that the 80-t has a rear vane pump.
yes it does
and yes the magnetic building board is awesome I have had it for a long time.
I need to do that too glue it down or laminate it to another peace. Also it would be nice to be longer.
I have plans to build a new build bench and I will make the modifications as needed
Early Saito FA 30 with A on the right lug:
First series Saito FA 30
Prop=====Xoar 9 x 7, white tips added by me.
Fuel =====Wildcat 10% with 18% full synthetic
Plug=====Glo-Devil 4c special for Saito and Enya
Exhaust==Stock
Max rpm==11,640 de-tuned one single click.
Idle======?
Rocker lash set using OS gauge.
Ambient temp=70 f
One click rich.
White tips visible
Home made rear facing vent, no leaks.
Exhaust==Stock
Idle======?
Ambient temp=70 f
One click rich.
White tips visible
It started two times on the first back flip. The engine stopped after about 5 minutes because some dummy connected the fill line to the engine. I couldn't find the guy anywhere. Good for a laugh eh.
Geek and Capt,
I hope I'm not out of line here, but noticed your discussion about a Saito 120 manual. I have an online pdf of one from 2005. Is this of any use to you?
Bob
Bob
Thanks Bob. That document does cover the 120S (Special).The engine parts list I'm looking for is for the plain old 120, otherwise know as a 120 Fathead. A beastly sized older design that is very different from any of the other big blocks.
Jim you ratbag, a few posts ago you said you had given up on them smelly two strokes, specially the o0ne's attached to heli's. My daddy said leopards never change their spots
Lonnie when i first unwrapped my new fa220 zues i was struck by the level of finish on the engine. Koala poo loads of compression. Once i had it bolted down securely (because an fa115 had escaped previously) i primed it for the first time and hooked up the glow stick. Jeezuz jiminy those things bark at you.
that's right Pete, I'm a cat, and you know cats. they change their minds in a moment and are silent in the night when no one is around. but Pete, while you were gone I gave three 2st's away to Capt44, now see what you made me do, if I wasn't a cat I wouldn't have told on Capt44.
sorry Capt44 !!
but Pete, look at this baby, isn't she just lovely ??
Jim
