NGH 38CC 4 stroke
#451
Once they are tightened to the desired amount of resiliance, nylock nuts on the back will lock in the setting.
#452
Shorte, Your mount plate looks great! I made 2 separate ones, a little larger than stock and fairly square. I just wanted to see how much of a difference it would make before getting fancy. Your one piece plate is the best idea. I have lots of 5mm plate, so I may make another one just like yours. When you run it, will be quite impressed at the difference a solid mounting makes. Well done!
#453
Thank you misfitsailor I have not run it yet still waiting on amr to send replacement parts. If his motor runs as good as I seen on you tube I will be happy. It looks to be built nice and for 299 what a deal and the weight don't bother me I am not using it for a 3d plane
I couldn't take it anymore I had to order the aeroworks traner just for fun I love tri gear easy to steer and nice flair landing .I might put flaps on it or flaperons. I will change the front gear to a fults gear.
#455
Thanks for the photos Tyor. Interesting, I have looked at my ESM mounts and thought they looked a bit light for this engine. I might be over-cautious!!!!
Still waiting to see if the Greatplanes or Dubro flexi-mounts will do the job.
#458
Hi folks, I'm new to this thread - I found it when trying to gather some information about the NGH GF38. I was looking for an engine that fits to my 82"/2090mm CMP/Jamara AT-6. Initial plan was to install a Zenoah ZG38 with rear outlet which I have available, but it's nearly impossible to package a muffler underneath the cowl or in the fuselage since the AT-6 nose is very short and there's almost no space for a huge muffler as it would be required for the ZG38. Reading through this thread I found some really useful hints and descriptions so that I finally decided to purchase the GF38. Since the price at German dealers is ridiculous (about $650) I was looking for another source. Yesterday I saw that HobbyKing has received new stock so that I could be pretty sure to receive latest design level, hence I ordered a GF38 at HK. Good news is that HobbyKing is now providing a buddy code for the GF38, which lowers the price to $266.69. So if you're aware of somebody who is looking for GF38, you may forward my buddy code which is valid until Jan. 25th:
http://rcsearch.info/hobbyking/buddy/?u=hawk66#catalog
Now I'm looking forward to receive my GF38, hopefully it will arrive within the next 2 or 3 weeks. I'll let you know.
dihin
dihin
#459
There are some question left: What is a reasonable capacity for the ignition battery assuming the engine should be able to run about 3 - 4 hrs without recharging the battery. Is there a max. or nominal current number shown on the ignition module? What is the max. voltage?
Thx. dihin
Thx. dihin
#461
Thx. dihin
Thx. dihin
#462
I usually use a 2100 mah LiFe battery pack for ignition purposes. With my engines and their CDI modules that works out to around three hours of flying time before I need to recharge it. In my opinion, since I fly RC and not FPV, that is way more flying time than I need for a weekend or holiday even.
#463
I am using a regulator with two isolated outputs to run both RX and ign. It has two inputs, so you can run either one or two batteries, and either 2 or 3 cell packs. I have been using a single 2S 2200 lipo the run the whole plane.
#464
Gents, thanks a lot for the quick responses! My power box requires a separate battery for the CDI, so I think I will go for a 2100 mAh LiFe or LiPo as suggested - this should provide enough flying time for a whole weekend.
#465
I tried out the new thick aluminum mounting plates in the air this morning. The first few lights went well, with all mounting parts remaining tight and trouble free. A problem did arise during my last flight, however, The engine started running rough and would threaten to die past 1/3 throttle. Using low throttle settings, I was able to stretch the glide just enough to reach the landing strip. Back home I found that the carb mounting screws had backed out. I had used thread locker on these some time back, but here they are loose again. If it happens again, I will drill and safety wire the screws.
I really like this engine, but when I think of all i have been through trying to make it usable, it occurs to me that the "PRO' version of the NGH-38 is a "kit engine"!
PS: With the retarded timing, it now hand-starts like a dream!
#467
Try running it first, hopefully the production issues have been sorted. But check the ignition timing and set it to about 30btdc. refer to post number 426.
#468
Hi Misfitsailor
I agree there is a lot of work to get these Pro versions running OK. I believe they only made about 100 of the Pro version ( mine is No 47 ), so I guess we are just 2 of a lucky group.
#470
Well I got my 2 parts from AMR that was damaged. they sent me a new hub but the hall sensor is a long one and not original so the sensor is past the magnet so not sure if this will affect timing. so now i need the right length hall senor.And cant find one do I call AMR and complain not right lengh
I ordered a dle 20 sensor it looks like the right length but cost me 9 bucks. This is the second week and still can't run my motor.
Does anyone have a dle 20 and know how long the hall sensor is I need a 10mm long for the ngh38
#471
I do not have a pro version. I have one of the first batches motor. It has only two rings. I have #27 form the first batch, and it is a paint shaker. But it never quits. I have never tried to hand start my NGH. I have an electric starter that I bought after I had the stitches removed from my fingers from a motor that kicked back. No hand fliping for me. But it has never failed to start, it just shakes a lot.
#472
Jeff shaking may signal you either timing error or slight out of valve adjustment. Timing error may signal you either cam timing or ignition timing. I would play with them.
#474
So.... have finished mounting engine to run-up stand. Spark-plug gap looks good, valve clearances look good. Should be able to run on Monday. One question, have you guys been using choke for a cold start?
#475
I use choke, I have a servo operate the choke. What has been working for me is to put on the choke and turn the engine until it starts. For me, it will usually keep running until I can turn off the choke on the TX.
For hand starting gasoline engines, I like a welder's glove. It is thick, stiff cowhide outside and padded inside!
