Official Tamiya TT-01 Thread
#4752
Re Wheel alineing set up back at post# 2669 "sanshu" has a photo of one car in setup with this device written on it M Racing is that what I need to find.
Cheer's.
Cheer's.
#4753
ORIGINAL: CrocEnd
thank xxSLiMxx
was gusseing around that, go's well enough for our stock can racing.
Cheer's
thank xxSLiMxx
Cheer's
#4754
Hi All
Im a total noob to RC and have recently purchased a TT01 Subaru.
I have just purchased the lexan corrado 1/10 shell for my TT01 i have everything i need to paint it and the item came with pre-prepared window masks. The problem i have is how to make the lights be it via decals or actually installing led lights. Ive googled for over a week to no avail. Does anybody have any suggestions? Does anybody have any custom decals for the corrado 1/10 shell that they could email me? Im at my wits end on this one as i dont want to start the job until i have this sorted out.
Also where can you purchase light buckets? Does anybody have any advise or exeprience in doing up this shell or similar?
Many thanks Jay
P.S im looking forward to joining whats looks like a great community!
Many thanks Jay
#4755
ORIGINAL: jaymassive619
Hi All
Many thanks Jay
Hi All
Many thanks Jay
Iv hear of ppl useing things like molding clay, Lego blocks, scrap lexan to make light buckes, but i found this stuff on ebay. There plastic pellets that you heat up in hot water and mold into what ever shape you like and then it get really hard (sand it, drill it, paint it ect ect) The best part is if you screw up just heat the plastic up again and remake it. I havent tryed it out my self yet (still waiting for it to show up) but from what i heard it works really grate. Just know that it sticks to other plastic stuff really well, so if your forming it around something (like i plan to do) make sure its not plastic, or lube the plastic up 1st (oil, grease, "lube" lol)
Have a look, these are the guys on ebay i found that have this stuff, and its really cheep to buy so why not try it. I payed like $7.00 total for a 100gram bag (no big loss if it dosent work out too good)
Polymorph is what the stuff is called.
Good luck, hopefuly you will find something that will work for you!
Slim.
#4756
Jay
I recently got a TT01 Subaru Impreza 2007 and I painted and assembled the whole thing. It took three days of 5-8 hours each day but I like how it turned out. I saw the headlight stickers but there was no way I would not use the included headlight inserts and the LEDs that came with my kit. Those LEDs are bright too, it lights a good 10-12" in front of the car. You can see pictures of the Subaru on my profile or on the paint and body section under "Does anyone paint bodies and how much"
#4758
Dose'nt matter bought a HUDY Set-Up system today,
Me and the m8"s are laughing now,
ON go's the Silver CAN stock racing.
I could not believe the kids dads and mom's In the last 7 weeks that we have started that turned up,tonight strewth 18 starters,last all up race 15 starters. NOW that was carnage GOOD fun but. Time ran out Finals next week Buuuuuuugerrrrrrr.
#4760
ORIGINAL: halls
does your tt01 handle better with all alum parts/
#4761
Hey guys, just a heads up.
As is usual with a thread this massive, all this may have already been covered, but I feel like I should share my frustrations with you guys so that other newbs like myself might save a few minutes of heartache and some dollars as well.
I bought a set of front (and eventually rear) alum knuckles, and was sad when the stock axles (they're called swing-shafts) didn't fit. So I ordered those as well. I got the front re-assembled and took the car out, and within 5 minutes the new swing shafts had completely disintegrated. Turns out you also need to buy the differential outer joints as well. Another fun fact is that all of the parts are not mix-n-match. You have to get the same brand swing shafts as knuckles and diff joints, or else you'll cause havoc. Fortunately Ms. Wong at The Track is really nice and ordered me the right stuff. (she also keeps trying to tell me that the tt01s are kinda crappy, which I'm coming to find out, but I love the thing and intend to build it out completely into something really nice).
I also bought the steering saver kit (forget the brand name, but it's the only one called "steering saver" as opposed to linkage or steering kit). It's got metal ball joints with plastic push-on cups. The kit is great in that I can adjust my toe-in now, as well as fix the trim on the steering before having to adjust the radio (which I'm kinda OCD about) but there's still a bunch of play in the swing arms. I'm thinking I might have gone with a different system (and I still may) if I'd have known how much play those ball-and-cup joints have. I'd like to switch to something else, but I don't want to re-buy the bearing arms or the main turnbuckles, just the cross member and maybe a new joint system.
Does anyone know what else you need to buy if you want to do the 3racing graphite chassis conversion? I've still got a long way to go before I get there, but I don't want to order things from overseas and then find out I've only got half of what I need.
Thanks again guys!
Thanks again guys!
#4762
the only way to find out is by letting someone run your ride through a battery and se how it handles, my all aluninum rides great
#4763
Most of the kit has the parts for the conversion but, aluminum shocks, aluminum steering, aluminum center shaft, universals I use Tamiya and have never broke one and its going on 2 years now, If you want you can get aluminum hubs, steering blocks but its optional, I use my car for speed runs so I need the extra stiffness.
Thats the driver looking over things
The pic with the body off is old it doesnt look like that now since the rebuild
#4764
ORIGINAL: SIRCC
Are you sure all the parts you have got are for the TT01 and not for something like a TA05 (i thinks thats the one, its almost the same)
As for a TT-01 beening crappy bone stock they are....but with a few mods they can be good little cars, Not the best but good.
#4766
ORIGINAL: xxSLiMxx
x1 All my alum. parts are made by GPM Racing. and iv never had a problem fitting parts.
-Yes, all my parts are for the TT01. I'm as sure as the labels on the packaging.
-Ms. Wong called it a "beginner's car" which is great since I'm a beginner. I think there's a certain charm to taking a car that's mediocre and making it into a real burner. Sort of like rooting for the underdog.
@SirCC:
I've seen a bunch of green parts on other brand's chassis, and that looks really cool too. I'd love to find orange, but that's sort of a pipe dream.
#4768
I'm not going to claim i'm a pro, but i have been racing tt-01 since i can remember and upgraded as I saw fit
my last project I put a traxxas velineon on a tt-01 wit h a 3-cell with speeds of 67mph clocked on a 100ft strip by a state trooper.
#4770
ORIGINAL: deejayqueue
Yes, you can certainly get a better car for less money overall if you go with something other than the TT-01 chassis system, but I personally believe analyzing the weaknesses in the TT-01 and tweaking the car to overcome those weaknesses are what makes the platform great. Plus you gain a far better understanding of what effects your mods and wrench-twiddling have on the car's performance envelope...
Look, any noob dweeb with a checkbook can buy a top-end, zoot-couture roadburner and turn quick lap times or high top-end speeds, assuming he can drive it halfways decently, but how many of 'em can decypher what happened when their car turns in a soft lap time and improve or repair it? How many of 'em can even fix their buggies when they sideswipe a lamppost at WFO speed, without having to haul the whole thing back to the LHS? I think working with the TT-01 chassis system gives people starting out in the world of R/C racing (and some who've been here a while, too) a far, far better understanding of chassis dynamics and drive system mods. Plus it's just a whole lot of fun. ;^)
Anyway, that's just what I believe. YMMV, obviously...
-Dave
#4771
Well i finally got my Honda Civic body and its all painted up now. All i need to do it make my light buckets and hook up my LED's Let me know what you think!
The last picture is my 1:1 cvic i used to own.
#4773
ORIGINAL: The Collector1
That looks awesome, what are you going to use to for the buckets?
#4774
Can someone teach an old dog a trick?
I will ask here tried on TB resource nothing back.
Please a way to remove old tyres from rims?
Thanx fella's
Thanx fella's
#4775
ORIGINAL: CrocEnd
Thanx fella's
Thanx fella's
