The Fathead is a beastly chunck of metal and to me it looks BA!
Pete,
That original rear cover is set up with the tank pressure check valves. The valves worked in conjunction with a pressre bleed valve to pressurize the tank. Some had problems with the system, others got it to work. Should you ever care to experiment, I have the valves and a needle assembly that I will send along.
IIRC,the fathead, heavyweight did about 8300 RPM on a typical wood 15-8 of the day type prop. Perhaps a turn better with an APC. The idle was amazing with the old bucket tappeted cam.
Try here ( https://www.dbproducts.com/index2.htm ) they show 4 different lengths and a lock nut available.
Thanks, but I'm looking for a solid spinner nut - not just a regular aluminum spinner. Kind of like this, but with M7 x 1 threads: https://www.towerhobbies.com/product.../OSMG2925.html
Would something like this work?
Ultra_Heavy_Hub
The Brass nut (spinner) above I believe is still one the shop if you want it. There is also an optional flywheel that wraps around the drive hub and extends thru the cowl. That Flybaby needed a lot of nose weight even with two large batteries straddling the fuel tank. Plane started out with a stupidly overpower .82 Saito and wound up with a very capable .62.
Anyhow, if you can use that "spinner" nut, let me know.
My Feedback: (27)
Gary,
I tried the pressure system you talk about above years ago. I spent hours trying to get it to work just right. I could never hit the sweet spot where everything balanced out. I was much happier without it. Now I will say I had a lot less experience back then. Right now the 120 Dual Plug runs great without it and should be in the air today.
Pete
Pete
Gary,
Pete
Pete
Mostly used by pattern fliers back in the day, a bit fussy. I use the valves to promote better case venting, period.
If a checked venting system is better I'd love to hear how.
Surely you would, I usually move the rear vent forward, among other changes.
No thanks Lonnie nice try.
Cap44, The Saito 30 is on the way.
Hobbsy, If you are monitoring, the Saito mufflers are on the way.
Modeltronics, The Saito 120 is also on the way.
Dave, hoping for healing. My very deepest regrets to your daughter and the young man's father especially.
Are you reading between the lines and finding things that aren't there again? A simple question from curiousity on my part results in smoke and mirrors on yours? Seems to happen more often than not lately. Keep your secrets.
Based on recent history, your initial comment set the tone.
Not smoke and mirrors at this end.
I don't resort to the valves often. Certainly not about regulating oil levels.
Seems you are happy with the stock setup.
Let's just agree to disagree and save time
My Feedback: (27)
I flew the 120 Dual Plug for three flights today. Late morning it was overcast and that is my favorite sky to fly in. The first flight was 20 minutes and I could see a healthy smoke trail. One thing I like about this plane is that in a low slow pass I can see how much fuel I have in the tank. After landing I leaned it two clicks, fueled up and was back in the air. I did not tach it, but it has more than enough power for this plane. The throttle response on this engine is excellent. On the last flight I wanted to try different glow plugs. I installed 2 Fireball hot plugs. The engine started just fine and ran the same as the OS F plugs. On starting the engine every time, I only applied power to the back plug. It would be interesting to know how it would run with a bad plug in the front.
I’m going to pull the engine off the plane this weekend and let it sit waiting for its new power source, Gary’s Fat Head 120. I will install that engine after a brief run on the test stand using my low nitro home brew.
The 120 DP was a fun project.
73s
Pete
73s
Pete
73s
Pete
73s
Pete
Jim
the Saito Engine; the sort where all others are less
