Old 10-03-2006, 09:57 PM
  #4801
EMVIN
The valve gaps have not been adjusted in a while so I will double check that. I have tryed numerous glow plugs. I think Rajul is on to something as I do not have a fuel filter in line (i'm sorry to say) and it was suggested to me that there is a clog,therefore, no matter how much I adjust, the mixture is not right.
Old 10-03-2006, 10:05 PM
  #4802
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Emvin, remove your HS needle and backflush the carb with fuel. See if that helps, with a filter installed
Old 10-03-2006, 10:09 PM
  #4803
EMVIN
Did that....I guy in my club suggests taking the carb apart and using air pressure....
Old 10-04-2006, 05:59 PM
  #4804
N1EDM
Is the fuel fresh? Could it have gotten moisture in it?
Just trying to cover the bases...
Bob
Old 10-05-2006, 09:59 AM
  #4805
EMVIN
Fresh fuel too........I am going to try re adjusting the valve gaps today......That seems to be the only thing I havn't tryed yet. I hope its that simple...
Old 10-05-2006, 01:21 PM
  #4806
JettPilot
JettPilot's Avatar
Where is Dr. Robinson ? I havent seen a post from him for so long im starting to worry [X(]
JettPilot
Old 10-05-2006, 02:52 PM
  #4807
RVM
He said something a week or so ago about him being really busy for a bit. He hasn't answered some PMs either so I'm going to guess real life or something pressing is his priority now, as it should be. He's always been good about returning to us poor, igornant masses, so I wouldn't worry.
ORIGINAL: JettPilot
JettPilot
Old 10-05-2006, 06:02 PM
  #4808
alfredbmor
alfredbmor's Avatar
Hi, I have several saitos and all run just fine, particularly I have a .91 wich runs fine with a 14 x 6 prop near 9,000 rpm and want to try an APC 14 x 7, does anybody here have any sugestions about it?
Old 10-05-2006, 06:33 PM
  #4809
alfredbmor
alfredbmor's Avatar
The Saitos I already have:
.40
.72
.82
.91
1.00
Old 10-05-2006, 07:48 PM
  #4810
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Alfred, the APC 14x7 will run better on the FA-100
Old 10-05-2006, 10:51 PM
  #4811
JPal101
My Feedback: (32)
I run a 15X6 APC on mine in a Show-Time, has plenty of verticle and slows nicely on the down line. I turn approx. 8700 rpm
Old 10-05-2006, 11:27 PM
  #4812
RVM
I was peaking at about 9600 RPM with an APC 14x7 on my .91, using 20% nitro and 15% oil fuel. I flew it at around 9300-9400. It's a great prop on the .91, in my opinion, but a lot depends on the altitude where you fly, your fuel etc. 9000rpm seems a bit low for an APC 14x6.
ORIGINAL: alfredbmor
Old 10-06-2006, 04:49 PM
  #4813
rwithey
Can anyone suggest a place to find these parts?
I have a Saito FA-120 "ALPHA CODE L" that was damaged in a recent crash. I was told by Horizon Hobby that the parts I need are discontinued. I need the intake pushrod and pushrod tube that my dummy radial engine bent in the crash. The Saito 120S (special) parts "ALPHA CODE M" will not work according to Horizon. Any help finding these parts, new or good used condition would be greatly appreciated.
Rob
Old 10-07-2006, 04:10 AM
  #4814
AKFireMedic
AKFireMedic's Avatar
Hello everyone. I just purchased a used (approx 2 gallons) Saito 82 and was wanting to completely check it out, strip it down (if needed) and clean it up before puting in my plane. I was hoping that you all would know what I should look for, (besides the obvious wear and valve lash issues) how far I should dig into it, and where I might find a service manual or similar to help guide me. Thanks for your time.
Old 10-07-2006, 05:58 AM
  #4815
w8ye
w8ye's Avatar
here is your manual
http://www.horizonhobby.com/ProdInfo...oke_Manual.pdf
Set the valves .0015"-.004"
Don't take the engine apart unless you have to.
If it ain't broke, don't fix it!
Old 10-08-2006, 04:05 AM
  #4816
AKFireMedic
Thanks a lot. I cleaner her all up, and set the valve lash to .0025 for each valve. It will be a bit before I get around to building the plane that the engine is for so running it will have to wait. Does anyone make a pitts style muffler for this engine? I found that slimline makes them for a number of Saitos bt they do not specifically list the 82. I am imagining that one of the others will probably work but which one? Thanks again for the help.
Old 10-08-2006, 08:08 AM
  #4817
w8ye
w8ye's Avatar
Very few people use pitts mufflers with four strokes
Old 10-08-2006, 10:12 AM
  #4818
JettPilot
JettPilot's Avatar
ORIGINAL: AKFireMedic
You should never take an engine apart that does not need it [:@] You are more likely to damage something and cause problems by taking it apart and putting it back together than if you just leave it alone. Clean up the outside if you want to so that is looks all shiny and new, but dont take it apart.
JettPilot
Old 10-08-2006, 01:04 PM
  #4819
Jonathan.Lam
Jonathan.Lam's Avatar
i have an adrenaline with a saito fa 125, i want to get a good prop for aerobatic flying, do you have any suggestions? i want around 9000-9500 rpm.
thanks
Old 10-08-2006, 01:12 PM
  #4820
JettPilot
JettPilot's Avatar
ORIGINAL: LiL_Chinky_b0i
thanks
Your BEST prop for that engine will be an APC... The APC 16X6 is recommended by Saito. Remember, your RPM will increase while in the air, so dont try go get the max RPM on the ground runup.
JettPilot
Old 10-08-2006, 01:19 PM
  #4821
Jonathan.Lam
would that give an rpm around 9000-9500?
Old 10-08-2006, 01:48 PM
  #4822
JettPilot
JettPilot's Avatar
ORIGINAL: William Robison
Here we go again.
As Dave said, three people, three answers. But generally speaking a Saito will burn one ounce of fuel per minute per cubic inch at full throttle when adjusted properly and matched to the plane and propellor, with 15% nitro fuel.
Chart is most popular sizes with running times for 10 ounces of 15% fuel. First column is full throttle start to finish, second column is with a 60% throttle average. Times are rounded to the nearest minute.
Engine full 60%
FA-56 17 29
FA-65 15 25
FA-72 14 23
FA-80 13 20
FA-82 12 20
FA-91 11 18
FA-100 10 16
FA-120 8 14
FA-125 8 13
FA-150 7 11
FA-180 6 9
The most common reason for excessive fuel consumption on a Saito is the LS needle too rich – at ½ throttle you are still running on the LS adjustment.
Fuel economy is also greatly improved with the use of an intake stack and a Bru-Line fine mesh air filter.
Bill.
This was one of the best posts I have seen reguarding fuel consumption I have ever seen. I wonder how this compares to the 2 strokes of the same power ?
Old 10-08-2006, 04:55 PM
  #4823
rajul
Moderator
My Feedback: (58)
rajul's Avatar
What fuel nitro content are you using? What's your elevation above sea level?
Old 10-09-2006, 12:00 PM
  #4824
dougwill
Bill I've tried the Omega 15% and love it in my Saitos. 4 of them. My question is that I have one YS 91AC also, since i trust your opinion. Will the castrol oil mess up my the YS or am I safe to use the same fuel in all?
Doug
Old 10-09-2006, 03:10 PM
  #4825
jessiej
ORIGINAL: JettPilot
That was indeed a good post, JettPilot and one that takes a lot of work to duplicate. One great problem is "Standard Conditions" I have done some similar tests, but have no illusions that my data is compariable with other information obtained in varying temperaturers, humidities, altitudes', alien influences, etc.
