Old 02-12-2021, 02:47 PM
  #49851
FlyerInOKC
FlyerInOKC's Avatar
Thank you!
Old 02-12-2021, 03:00 PM
  #49852
acdii
All you need now is a fluffy pink scarf to wear when you fly it. Now THAT would be a sight to see.
Old 02-12-2021, 03:08 PM
  #49853
FlyerInOKC
FlyerInOKC's Avatar
Hmm.. I don't think so.
Old 02-12-2021, 03:09 PM
  #49854
acdii
How about Pink fluffy bunny slippers?
Old 02-12-2021, 03:34 PM
  #49855
FlyerInOKC
FlyerInOKC's Avatar
I'm more of a Hey Dude type of guy and they don't come in pink.
Old 02-12-2021, 03:41 PM
  #49856
acdii
It does for Unimicorns, they love pink hey. LOL
Old 02-13-2021, 03:32 AM
  #49857
1200SportsterRider
1200SportsterRider's Avatar
The Dr. visit went well, I face 8 weeks, (40 days) of daily radiation treatments, but the prospects look good.
I had the back plate ordered for a few month at MacGregors, finally they sent an email saying it was no longer available. The top two bolt holes are each half broken off, the .125" aluminum plate serves the purpose well. And is not very visible.
Old 02-13-2021, 06:06 AM
  #49858
Jesse Open
Jesse Open's Avatar
Well Dave, at least you get weekends off
Old 02-13-2021, 07:45 AM
  #49859
Hyjinx
My buddy grumpy Bob just got that burned out of him.
He did good thought it Dave. You will to, and that cancer will clear out with the burn!
400 degree oven. Looks like a winner on the bendy part!
Old 02-13-2021, 07:46 AM
  #49860
FlyerInOKC
FlyerInOKC's Avatar
A heack of a way to get your weekends off!
Old 02-13-2021, 06:04 PM
  #49861
Glowgeek
Looks like winner. What material is it?
Old 02-13-2021, 07:12 PM
  #49862
acdii
Alright!! Almost done with the Corsair! All the radio gear, the engine, fuel system, Basically everything except polish, canopy, and decals is done on the Fuselage. Just have to connect the servos, hook up the ailerons, and put the flap hatches on and the wing will be done, and all it would need is the same polishing and decals.
Old 02-14-2021, 04:04 AM
  #49863
1200SportsterRider
Thankyou all for the kind words, that is my hope also.
Great looking stuff we're building here. What is twisting the 14 x 7 3-b, I missed that somehow, Thanks
Old 02-14-2021, 08:53 AM
  #49864
Hyjinx
Hyd tubing. .490 with .032 wall. Bent great cold or heated. Working on joining spigots. First try with safety silv 56.
It was cheap. I took my damaged Saito oem ring to a local weld shop. It won't be...HEHE
Old 02-14-2021, 05:34 PM
  #49865
Jesse Open
Jesse Open's Avatar
Great, what flux did you use? You don't need to buy any more siler, I have plenty here next time you are in the "hood, stop by.
Old 02-15-2021, 04:00 AM
  #49866
Hyjinx
Hey GaryThe Raynor paste. I think it may work with a good fit up. Have to play with it a bit. I was over your way last week. Was thinking about barging in on you but couldnt find your number to pre rattle the cage. Pm'd you to late.
Old 02-15-2021, 08:13 AM
  #49867
Jesse Open
Jesse Open's Avatar
Silver solder braze likes to have a fitted overlap. Butt ended joints do not offer much strength. Silver solder is best when sweated at around .002" to .006" thick. You may be better off with bronze or brass brazing. Very similar but higher temperature. If you don't have an oxy-acetylene outfit, you may borrow mine.
With either silver solder or braze it is important to not overheat the filler metal.
Also, you should consider making a fixture to hold all parts in perfect position during brazing . Very important! You may be able to make most of the fixture from hardwood, we did at work often. In the areas exposed to welding flame, you may have to use metal support/locators. Use your imagination a bit, screw heads of screws extending from the wood base etc,
Build your fixture around the engine itself using it to form and fit the connecting tubes perfectly.
PM me your phone number, easier to discuss that way.
Old 02-15-2021, 08:59 AM
  #49868
acdii
Where do you store you acetylene tank? Those things are scary, which is why I don't have one
Old 02-15-2021, 10:15 AM
  #49869
Hyjinx
All my welding, arc, wire and large torch work happens in or around the detached garage. Be lost without torches and a stick welder around here.
Definably not basement tools and gasses.
The hobby stuff i do mostly in the basement shop with mapp or propane. Sort of rare for me. This project is a learning tool as much as anything else. Done very little brazing or torch welding. Specially on tiny stuff like this.
More used to fortifying dragline buckets and dozer blades or a backhoe boom or such.
Another life ago
Old 02-15-2021, 11:28 AM
  #49870
Glowgeek
Acetylene is dangerous if mishandled. Not something I would keep in my house.
Old 02-15-2021, 02:16 PM
  #49871
Jesse Open
Jesse Open's Avatar
Acetylene?
LOL, I won't even start here!
Seems you guys already know far more than I.....
Old 02-15-2021, 02:18 PM
  #49872
acdii
Acetylene?
Didn't you just offer to let someone borrow yours?
Old 02-15-2021, 03:08 PM
  #49873
Jesse Open
Jesse Open's Avatar
And....?????
Those 10 cubic foot acetylene bottles, handled properly are certainly no more hazardous than the 20 pound propane tanks folks have on their RV or backyard grille. Natural gas piped thru houses, five gallon cans of gasoline etc.
I respect tools, no fear needed.
Old 02-15-2021, 03:13 PM
  #49874
Glowgeek
Acetylene?
Really? Does every subject have to turn into a P***ing contest? Sounds like someone just wants some info on OA torches. I use it safely but follow the rules to the letter......accept separating the O and A bottles when not in use.
Old 02-15-2021, 03:22 PM
  #49875
Jesse Open
Jesse Open's Avatar
Looking to assume the high ground?
You tell me about the p------ng contests Lonnie.You have baited several.
I offered to loan tools and was handed stuff about them being too danreous to have around, Like I was recklessy endangering somones home.
