Baiojet + Kolibri T25 = 235mph *new video*
RE: Baiojet + Kolibri T25 = 235mph *new video*
This sunday we had a test and tune day where the club was flying and we had an open invitation for everyone who wanted to come and try our trainers. About 100 people outside the club joined us and we had the opportunity to fly dual commands with about 30 spectators, where among several girls(!)
During the day I made several flights with the Funjet which worked perfect. 6min flight - 60min of explaining Engine got 135 cycles now which means the Funjet has been doing over 100 flights so far.
340km/h Turbo Funjet Ultra+
After about 120 flights on my Funjet Ultra I decided to switch to another aiframe that would do the engine more justice. I like the way the Funjet flies, the delta configuration makes it very easy to land and easy to get airborn too. So I thought I would't change the concept too much I orderd a Baiojet and a extra FJU decal set for it... my sense of humor
the Kolibri with it's 2" diameter fits perfect, all electronics from the FJU fits too and I only needed 15grams or lead in the nose to get it to ballance. A shampoo bottle houses 500cc of fuel. All up weight 1290grams dry.
Due to a thunderstorm getting very cloe I only made a quick test flight followed by a run with my HowFast data recorder. Without really pushing it I recorded 340kmh / 213mph in a slight upwards going fly by
henke,
I'm always wanted baiojet for my p20 but I'm sure need to cut tail section like fj to get it fit.I should order t25 Then!
im working on fj/p20 now,the dry weight with 360cc tank plus tamjet mini uat is 1270g!!! that way too heavy I'm now sure how I'm going to launch it!
with your 500cc tank you have massive flight time,do you really need to fly that long?
yiming
yiming
henke,
yiming
yiming
ORIGINAL: SniperWj
henke,
yiming
henke,
yiming
A 1270g funjet will fly well but land fast! launch is NO problem, just add upp elevator on a flight mode and you are fine.
the T25 is 55mm diameter and just fits, the P-20 simply is too large. Also adding another 100grams at the back you need to add more weight in the nose. Reading the German forums a P-20 puts out thrust as a T-20. So chooseing a Jetcat P-20 would give you more modifications to make it fit, 200grams more weight (atleast) and less power.
As for the 500cc fueltank I think it will be fine for 6min flights as the Baiojet can handle more full power runns then the Funjet.
#32
ORIGINAL: gerhard
Hi Henke
Ho are you launching the BAJO? Is handlaunch by yourself possible?
gerhard
Hi Henke
gerhard
#33
Three more flights today, getting used to the new airframe and it does fly really well. I recorded 360kmh / 225mph today.
pics of the engine install as promised.
#34
Another flight today, my friend shot some video with my cellphone. Not the best weather conditions, but again if chooseing 1080p and full screen you can catch the Baiojet from time to time ;-)
Ringing it out fully today it definently goes faster then my logged 225mph runs, estimating 235mph/375kmh today!!
enjoy :-)
[youtube]http://www.youtube.com/watch?v=P_ZdIdaRMng[/youtube]
enjoy :-)
#37
ORIGINAL: csetting
I am in the USA how do i get a hold of a Biaojet. Do thay have a distributer over here or does Als hobby carry them?
#40
ORIGINAL: mr_matt
What have you found to be the best product for cleaning your underwear after a flight?
#41
ORIGINAL: SniperWj
good speed,
you make me want skyrunner300/t32 badly!
good speed,
#42
Congrats Henke,
I still havent got mine going - Its almost there waiting for the paint
I see you havent installed the Canards , can you explain your flight modes for take off ?
I understood that you program a bit of UP elev for take off, how much should one add ?
Xantos
Xantos
#43
Great bird - and congratulations - looks great!!!
How does it handle slow flight?Guess I will need to go down to Ljungby some day:-))
Helihover
Helihover
#44
The Baiojet is an SAB (italy) product, Motors & Rotors have distributed their products for 15 years in the UK
Dw
Dw
#45
ORIGINAL: Xantos
Congrats Henke,
Xantos
Congrats Henke,
Xantos
I programed a flight mode where I have about 45% up elevator for launch, as soon as I launched the plane I reduce throttle to idle and flip the FM switch to normal flight mode and off we go :-) look at the video and you can see the procidure.
#46
ORIGINAL: 1_helihover_1
How does it handle slow flight? Guess I will need to go down to Ljungby some day:-))
Helihover
Helihover
#50
ORIGINAL: gooseF22
I had to clean out my shorts just watching it, and I fly a 35lb thrust kingcat !!
