DLE 20 Ignition & life4 battery question?
RE: DLE 20 Ignition & life4 battery question?
ORIGINAL: OliverJacob
If a Diode is rated for 1 Amp, then I would not put more current through it. It may be ok to overload it for a short time. Doing so consistingly will heat it up and sooner or later cause it to fail. Again - this one is good for most ignition systems.
But is is not enough for most radio systems. More then likely it will be more then 1 Amp, depending on the servos, the flying style and some other factors. Hard to measure.
If you fly a big bird, your servos combined will draw a lot more current. It may work for some time, but will fail under higher servo workload.
Diodes are the cheapest and smalles part on your plane, why not spending a few more cents to be on the safe side?
To the previous poster - do you think the manufacturer of this diode lies when he states a max current? Or do you think your receiver with servos will draw less? See, I point out this potential problem and maybe prevent someone from loosing their expensive model - by changing out a cheap part. I am happy if I can help people out and sometimes I need someones opinion. You are welcome.
So what is your mission here?
ORIGINAL: jstanton
I am thinking aout trying a RCeXL ignition kill swith w/BEC. Here is the web site. Has anyone used one of these on the DLE ignitiona with a Life4 or A123 battery?
http://www.valleyviewrc.com/estore/r...-with-bec.html
It must a a RF filter built into it because it pulls the power from the reciever.
My Feedback: (14)
There is another site that is discussing the version 2 RCEXL Kill switch with BEC and they are saying it is delivering 6v to the ignition using a 6.6v A123 battery. I am going to order 3 of these and test them. If they deliver more than 6v I will use the diode mether to cut the voltage under 6v
DC
One 2 oz nickel metal hydrice 4.8 800 ma battery, no voltage reducers, no nothing, no problem with any RC EXL ignition for at least 2 solid hours of flying time..
Just sayin'
Sometimes we get carried away with new technology...
Just sayin'
My Feedback: (12)
WI
There are different ignition systems. Most people know this, some don't. Find the specs for your system and
make sure your diode can take the current. Plain and simple.
#31
DC
The RC EXL specs call for 4.8 to 6 volts...What they don't say is MORE than 6.0000000 volts from a new charge in a battery will exceed 6.000000 vots and damage the ignition...
The specs also say 35 BTDC for timing, wrong...Do I know more than RC EXL ? apparently about timing..Since 1986..When did RC EXL start ? RC EXL is a clone of C&H...Maybe Bill is wrong too ????[>:]
#32
My Feedback: (12)
WI
Agree, a 4 cell NiMh works fine on the ignition. You can charge a LiFe very quick, but a fully charged pack gives you more than enough run time for a day.
Sufficient for the average user.
#33
My Feedback: (14)
I totally understand what you guy's are saying about the 4.8v nimh batteries and I have used them for years. I like the newer life4 batteries better and I like the idea of having only one type of battery to charge. That is why I am looking into the RCXEL Kill switch with BEC. I plan on running dual Life4 battery packs so I will have some redunacy. I will also make sure the RCEXL doesn't deliver any more than 6v to the ignition.
#34
My Feedback: (14)
I have done a little more recearch and it looks like the newer DLE ignition will take a 6.6v Life battery with out any regulator needed. Take a look at the DLE 20 manual.
http://www.dle-engines.com/dleg0020.html
From what it says in the technical notes a RCEXL kill switch with BEC should not need to be regulated down to under 6v
#35
My Feedback: (12)
WI
The max. voltage on NiCd or NiMh is 6 Volts. But when you use a LiFe it is 6.6? Why would the ignition box care what type of battery is connected?
I would not trust this statement, drop the voltage down and you are on the safe side. When your LiFe is fully charged, it has more then 6.6 Volts.
My 2 cents - stay under 6 Volts, it's not worth to safe a few bucks and have your ignition module fail
#36
My Feedback: (14)
#37
ORIGINAL: jstanton
I WOULD NOT trust the owner's manual or anyone else regarding running the ign. module on a 5 cell NiMh or LiFe pack that's over 6 volts. Agree with others. It's way too easy to install a diode.
#38
My Feedback: (7)
IN
ORIGINAL: jstanton
Rcexl's own pdf files clearly state for over 6.0 volts to regulate down.
http://www.modelaviation.com.au/manu...rcexlspecs.pdf
Also, with a bit more research right here in the Gas Engine section, you'll find numerous posting by Jody & others, where the DLE20 ign module clearly dislikes 6.0 volts and over. Higher voltages fed into an ign module may be doable, but it shortens their life span.
All that's truly needed is 4.8 volts, and over 6.0 while doable isn't advisable.
While some claim to be using higher input voltages, when your fries, will those people replace yours?
#39
ORIGINAL: jstanton
Milton
#40
Three DLE 20s, all using an RCEXL opti-kill, a single diode and a single LiFe battery for ignition and receiver.
I put the diode between the opti-kill and the ignition module. The receiver and servos run on the full 6.6V from the LIFE battery. My set up is LiFe Batter > Switch > Y-Harness. One leg of the Y-harness goes to the Opti-Kill and the other to the receiver.
Some of those saying the diode is a single point of failure - well so is the switch, the ignition battery, the opti-kill and any connector that isn't put together right can fail. Just because they don't/can't do it doesn't mean it can be done. In my case, I've been doing the single LiFe battery with opti-kill and diode for more than a year now with no problems. I'm not buying the doom and gloom stories. Buy yourself a 2.4ghz radio and welcome yourself to the 21st century!
#41
[quote]ORIGINAL: a1pcfixer
ORIGINAL: jstanton
Take a look a this bottom of the page info on your statement.
voltage Supply range by:
NiCd/NiMh 4 cell battery pack (4.8v >500mA)
NiCd/NiMh 5 cell battery pack (6.0v >800mA)
Li-Fe (A123)2 cell battery pack (6.6v>1000mA)
Li-Poly 2 cell battery pack and other bettery or More (use Switching BEC
voltage regulator. out 5.0V~6.0v) or (7.4V Li-Poly Serially connects two
IN4007 diode to fall voltage the use)
http://www.rcexl.com By Rcexl 2007-09-01
A123 6.6 volts packs are not the ones to be regulated as per Rcexl mnfg.
#42
I tested my Rcexl ignitions down to 3.3v and up to 6.6v and all worked fine. I use BP Hobbies Ignition battery eliminator circuit w/kill switch feeded from the receiver with two A123 packs direct to the receiver with individual switches. We fly almost 52 weeks of the year at 85 to 95 degrees of temperature and no problem with the ignitions
#44
My Feedback: (14)
I really do appricate all of the input you all have given, but here is what I plan to try. I will buy the RCXEL Opto Kill switch with BEC and use the diode method to bring the voltage down to 5.4v going into the Ignition. I will be using two 2500mah life4 6v batteries and two switchs going to the reciever. The diode will plug into the reciever and than into the RCXEL Opto Kill switch which will plug into the ignition. The RCEXL Opto Kill switch with BEC pulls power from the reciever. Here is the link to it and you will see from the photo on VV web page that it is inteneded to plug into the reciever.
Thanks for all your help
#45
I am still trying to figure out where Valley View gets there is a BEC made into the RCexl Opto kill, The instruction say in red bright letters they do not have them and it is the same opto I sell.
Type K
Ver 2.0
Milton
Type K
Ver 2.0
Milton
#46
NC
i know this is for dle 20 but i run a castle bec programmed at 5.5 volts and a 11.1 lipo battery for my zenoah G20 i charge it once a month and never had a problem with it yet
#47
ORIGINAL: btflycrazy
This will do the same thing for 6 bucks plus shipping.
http://www.hobbyking.com/hobbyking/s...for_Lipo_.html
Milton
#48
My Feedback: (7)
IN
Now I can understand why TOM and Jedi ran away from this....
Some people 'get it', while others don't.[&:]
But it is fun to watch the crazy input from some.
Very entertaining![8D]
#49
My Feedback: (7)
IN
ORIGINAL: BadAzzMaxx
Type K
Ver 2.0
Milton
Type K
Ver 2.0
Milton
Something about soldering a spot on the unit.
Directions are in extreme fine print.
#50
My Feedback: (14)
I have been reading two forums on this and here is the link to the other forum and it seems they have a good grasp on what is going on with the RCEXL Opto kill switch with BEC. Here is the link. It seems VV has a new version in stock that is not yet been posted to thier web site. I am calling them tomorrow morning to find out for sure.
http://www.flyinggiants.com/forums/s...=2#post1632748
