ACE Turbine Software Basics - Data Terminal
My Feedback: (20)
NY
Guys, I really need some help here! I bought a second hand HSD F16 with the Ace 60 turbine in it. Previous owner started it up for me OK and then removed his Jeti RX prior to me taking delivery. I am using a JR 11X 24 TX and the RX is a Spectrum AR12000 DSM2. When I go to learn RC, the green Study RC shows a value of about 1200 for only one second and then goes to a value of 0, (zero). I have replaced all leads, changed travel adjust to plus and minus 150%, but to no avail. I don't know what I am doing wrong, because I can't Learn RC, and run the engine!!
i use Spektrum DX18 with the AR1200. I think I had to reverse my throttle channel. But my values didn't go away. Once the throttle was raised the ok button is pressed, same with trim up, and trim down throttle down. (Might not be in that order) but make sure to click ok to save values. No clue if any of this will help.
My Feedback: (20)
NY
Yes Andy with USA Swiwin is where it will be sent if you are unable to get the issue resolved. Hopefully the the info he sends will help. I am Really happy with mine first Swiwin turbine and have gotten another. Best of luck.
