Alm Meca Turbines
Internal parts just look as the vintage (2009) GR180 engine developped by Gerald Rutten.
Proof here: https://www.rcuniverse.com/forum/8839129-post63.html
A bit dated and expensive design, btw.
joeb
joeb
Dansy (11-16-2022)
The custom wiring harness is just to make the customers life easier, so it makes it easier for install. As you know all the other brands give you one size length wire and from time to time at least for me it’s so long I don’t know what to do or it’s so short that I have to go buy other wires and that’s extra money having to spend. This is just a kill two birds with one stone situation. The reason for build to order is so each turbine could be tested precisely and made sure that ever run as they should and customer doesn’t end up with any issues, worst thing is getting a new turbine and having issues right from the get go because some little thing wasn't don’t correctly and causes you headaches. Customer as of now will not experience any delays because of the built to order, will get it, maybe even quicker then some of the other brands out depending on where you are in the world. Reason for proper clunk is a get clunk is required to work properly, I have tested this with a normal brass clunk and then switching over to felt clunk, I did all the flips and roll and anything I could throw at it and had no flame outs with either but with the brass it would sputter a bit and I did not like that.
#31
Red herring, much? Read the thread again please and be careful what you ask for sir.
IF one simply must rely on data NOT provided by the mf’r or the OP, then I refer you to the June/July RCJI test report.. If one simply must rely on data NOT provided by the mf’r or the OP, then I refer you to the June/July RCJI test report which has no more + than - commentary overall and ranks the subject 180 thrust:weight ratio of this “New” engine as 5th of 7 in the class, only beating engines from tests conducted between 9 and 10 years ago. Engines ranking 1-4 on the other hand are from as many as 12 years ago.
The RCJI report aside, the only “testing” required in order to reach negative conclusions regarding this product line are the OP’s OWN PICS AND COMMENTS, coupled with his deafening non-answers and/or side-steps to specific questions. And if one’s product must resort to claims of no need for a UAT as a “highlight” -a claim actually based on 15+ year-old felt clunk innovation rather than the engine itself- or to outright false claims of superior service intervals, then there are warning signs here regarding both the manufacturer and/or it’s representative. By these standards, one might as well claim Kero start as a “highlight”. The smoke being blown up our skirts here is glaringly obvious.
There’s little or no reason IMO (and apparently others’ as well) to purchase a poorly launched/represented engine from a new, untested manufacturer. All the more so when those engines, as per the manufacturer’s OWN SPECS AND PHOTOS (!) offer no new technologies or performance gains, are heavier, and cost more.
But hey, man. Free Country, so no judgement here on your own conclusions. If your rosier world view compels to spend YOUR OWN $ on these engines then please do. Meanwhile, you might do well to refrain from impugning others judgements of the matter.
Dansy (11-16-2022)
#32
Hey all, I visited this guy’s FB page. What I found were some pretty outlandish claims for this line of turbines as having better specs than ALL others, TWO SECOND acceleration time, etc. This, according to what one may infer from his photos and posts is a very young guy -one might even say a kid- with little or no real expertise. Maybe I’m 100% wrong, but I have tried and failed to find a reason to explore the brand with my $.
I wouldn’t go to the trouble of extending this absurd thread one post longer if he hadn’t been even more dodgy on FB than this forum (if that’s possible) when asked a simple question regarding performance.
I feel genuinely bad for this “Rep” (just not bad enough to hand over my $) because by all appearances, imo -and I truly hope I am wrong here- it seems like he is basically just some young dude in over his head who misjudged then audience here as unsophisticated and therefore vulnerable to weak marketing tactics.
Once again, I will say that I hope I am wrong…
#33
My Feedback: (176)
Ok so I was reading most of the comments about the turbine, so this is my one first hand observation because I have chance to touch and look at the turbine and yes the turbine is bigger than those days 180 size turbines and look definitely different than what we see around but as a performance it’s kind of like the big block engine with small turbocharged engines, it works perfect with very fast response and pushes the jet very well so the job is done, yes there some stuff that I would charge like the big all in one box that is much larger than for example the jet central power box and I will never advertise that the uat is not needed because as long as I fly jets this was a very helpful device no matter what turbine was used specially with multiple fuel tanks setup, so the turbine is maybe different but it works perfectly and only time will show if we the Rc jets enthusiasts going to accept and like the new product, just remember when the first Kingtech was announced what everyone was saying and tell that this is the next junk just like jetjoe from China but after the 2011 jet world masters everything started better for them and the beloved jetcat is not the first choice specially at this moment.that’s it and I wish Piter great success with this new brand.
David J Ruskin (11-18-2022)
#34
that’s one hell of a sentence!… 🥲
#36
Can you please explain to me about I was “Dodge” on Fbook even more on this group? Someone asked a question and I asked them to please refer to my more recent posts, nothing dodge about that just seems like laziness on your part because you could hav exist clicked on my name and seen more about the turbine. The two secound response was a spec on the engine but since has been bounced up to 3 sec. Nothing fishy that’s how it was.
#37
Thank you Sysiek and I agree with you. This is a launch of a turbine, obviously it’s going to have some stuff needing updating. Nothing is perfect and I appreciate all your guys comments so I can tell the manufacturer what they should work on to make it even better.
#38
#39
#40
#44
#45
Hey guys, so I did some investigating to see what the specs are for all the major turbines on the U.S market for the 210 size turbines(some brands have a bit larger or a bit smaller but more or less around the 210 mark) and I got to say the a-210 is a real competitor comparing to all the normal specs that the turbine mfrs have on there websites. Starting off with price, it is very competitive considering some brands are asking over $4000 for less powered turbines but we aren’t here to judge. A-210 has the smallest diameter at 109mm followed by jc-200 at 111mm. It does have the longest length at 330mm but this includes the cone at the end not the actual can, again some brands don’t have it even specified. Has the smallest amount of consumption rate at 450ml/min at 100k rpm, some companies, as you can see below don’t, don’t even mention at what rpm but alm meca has that specified. All around the 21kg mark since they are all around the 210n mark. Is the the second most heaviest followed by the p-200 but again some companies don’t specify complete weight. On the high end has the highest rpm out of all the other engines at 124k, and has a 3.5sec acceleration from 33k-124k, again some of the companies don’t have times specified(almost none actually) and has almost the lowest idle rpm at 33k, Jc-200 at 32k.
So to come to a conclusion, the A-210 is like I stated above very competitive in the 210n market. Also has some key specs specified even with other brands not having anything you guys have mentioned like 5000ft tests. Some brands don’t even have some basic specs specified. Soon I will be making comparisons for the A-180. So all in all most of you guys made this turbine seem like it’s an ancient artifact that doesn’t have any specs but like I have proven has many key features that beat some of the other larger brands on the market. All of these came directly from the companies websites not making any of this stuff up.
Alm meca A-210
$3250
Diameter: 109mm
Length: 330mm
Consumption/min: 450 ml/min at 100,000 rpm
Thrust 210 nm = 21KG
Complete weight = 2.1 KG (turbines + control box) 2100grams
Temperature (Celsius): 550/750°
Fuels: Kerosene, Diesel, Jet 1A
Materials: Aluminum, steel, stainless steel
RPM Speeds: 33,000/ 124,000 in 3.5sec
Kingtech K-210
$3150
Diameter: 112.6 mm
Length: 280 mm
Weight: 1740g
RPM Range: up to 33,000-120,000RPM
Thrust: 21 kg @ max RPM ( 46.3 lbs at max RPM)
EGT: 650°C max
Fuel consumption: 590 g / min ( 20.8 oz / min ) 615ml/min
Swinwin sw-220
$2950
Thrust
22 kg / 47.5 lb
RPM Range
35,000 r/min ~ 110,000 r/min
Rated Exhaust Temperature
750℃ / 750~1382℉
Fuel Consumption
16 oz/min @ 90% Power 110,000 RPM(473ml/min)
Fuel
Kerosene, Jet A or diesel
Lubrication
5% kerosene, Jet A or 3% diesel
Start
Full auto-start
Restart
Auto-restart
Weight
1700 g / 60 oz / 3.75 lbs
Diameter
116mm / 4.57 in
Length
280mm / 11.02 in
Maintenance Interval
Every 25 hours
ECU Supply
3 cell li-po
Total Weight
2000 g / 70.5 oz / 4.4 lbs
Behotech jb-220
$4150
Diameter
113 mm – 4,45inch
Length
313 mm – 12,32inch
Weight
1640g – 3,62lbs
max. thrust
220N – 49,46lbs @ 123,000 rpm
min. thrust
8,05N – 1,7~1,81lbs @ 35,000 rpm
Fuel consumption @max. thrust
arround 720 ml/min
Exhaust gas temperature@ max. thrust
arround 750°
Fuel
Diesel or Jet A1 (+5% turbine oil)
Acceleration 35.000 – 120.000 rpm
4 seconds aprox.
Acceleration 60.000 – 120.000 rpm
1 second aprox
Jet central rhino 200
$3450
200 Newtons (45 Lbs) @ 121,000 RPM
Idle Thrust
6 Newtons (1.34 Lbs) @ 32,000 RPM
RPM Range
32,000 – 121,000
Weight
1.78 Kg (3.93 Lbs)
Diameter
111.0 mm (4.37”)
Length
302 mm (11.89”)
Exhaust Gas Temperature
500ş C – 700ş C
Fuel Consumption
0.55 Lt/min (19.5 Oz/min) @121 k 576ml/min
Jetcat p-200-Rx
$4600
Thrust: 52 lbs @ 112,000 RPM
Weight: 5.53 lb (2510g)
Diameter: 5.12 inches (130 mm)
RPM Range: 33,000 – 112,000 RPM
Exhaust gas temp.: MAX 750°C
Fuel consumption: 25 oz per/min at full power
Fuel: Jet A1, 1-K kerosene
Lubrication: approximately 5% synthetic Oil in the fuel
Maintenance interval: 25 hours
Alm meca A-210
$3250
Diameter: 109mm
Length: 330mm
Kingtech K-210
$3150
Diameter: 112.6 mm
Length: 280 mm
Weight: 1740g
EGT: 650°C max
Swinwin sw-220
$2950
Thrust
22 kg / 47.5 lb
RPM Range
750℃ / 750~1382℉
Fuel Consumption
Fuel
Lubrication
Start
Full auto-start
Restart
Auto-restart
Weight
Diameter
116mm / 4.57 in
Length
280mm / 11.02 in
Every 25 hours
ECU Supply
3 cell li-po
Total Weight
Behotech jb-220
$4150
Diameter
113 mm – 4,45inch
Length
313 mm – 12,32inch
Weight
1640g – 3,62lbs
max. thrust
min. thrust
arround 720 ml/min
arround 750°
Fuel
4 seconds aprox.
1 second aprox
$3450
Idle Thrust
RPM Range
32,000 – 121,000
Weight
1.78 Kg (3.93 Lbs)
Diameter
111.0 mm (4.37”)
Length
302 mm (11.89”)
500ş C – 700ş C
Fuel Consumption
Jetcat p-200-Rx
$4600
#46
Not going to jump in on this too much and I wish you guys luck but how is it competitive, its older tech? Its 180 thrust, weight and size of turbines that produce more thrust? If you run the numbers of fuel consumption at full RPM vs about 60% its going to be thirsty as well.
Im generally curious not being rude and base my comments on whats been shown about this product.
#47
Here are the 180 comparisons for some of the most popular that are currently on the market and a lot of people run in the U.S. So again starting with price, very competitive priced at $2850 with most brands being around that price. But again some at almost $4000 which is a bit steep. With diameter it definitely isn’t the smallest, but definitely not the largest, it places third in the line up k-180 being at the smallest at 103mm and largest being in-180 being at 113mm. Length is the largest at 330mm but tied exactly with p-180 at also 330mm. Has the smallest consumption at 370ml/min at 100k rpm by a long shot to the other brands; closest being sw-190 at 380ml/min at 103,5k rpm and p-180 being at 610ml/min. It is the heaviest at 2000g, k-180 being at 1540g but most don’t say what that includes, Alm-meca includes that. Doesn’t have the least idle rpm, x-180 does at 28k but does come in second tied with sw-190, and p-180, but again some brands don’t state idle rpm but Alm-meca does. Doesn’t have the highest max rpm, k-180 does have 130k but does come in second at 126k. Alm meca does 33-126k in 3.5 seconds which from what I can see is second in line behind jb-180 being at 3sec flat but again most don’t include it, p-180 claims 1min which seems the highest but again others don’t specify.
So again all these specs come from the mfrs websites and again the alm meca A-180 is very competitive and proves it’s not a ancient relic like most of you portray it to be, but it could truly hold its own. Again alm meca has many specifics that most don’t even specify. So for all you guys out there talking all this crap this just proves you guys have no idea what you are talking about and shows what this turbine can actually do.
A-180
$2850
Diameter: 109mm
Length: 330mm
Consumption/min: 370 ml/min at 100,000 rpm
Thrust 180 nm = 18KG
Complete weight = 2KG turbines + control box 2000g
RPM Speeds: 33,000/ 126,000 in 3.5sec
K-180g4+
$2850
Diameter: 103mm
Length: 251 mm
Weight: 1540 g
Maximum RPM: up to 130000
Thrust: 18 KG @ 15°C (40lb @ 59°F )
EGT: 700°C max
Fuel consumption: 560g / min ( 17.28oz / min ) 511ml/min
Sw-190
$2750
19 kg / 41.8 lb
RPM Range
33,000 r/min ~ 115,000 r/min
700℃ / 1292 ℉
Fuel Consumption
380 ml/min / 12.8 oz/min @ 90% Power 103,500 RPM
Fuel
Lubrication
Start
Full auto-start
Restart
Auto-restart
Engine Weight
1457 g / 51.4 oz / 3.2 lb
Diameter
110mm / 4.3 in
Length
258mm / 10.2 in
Every 25 hours
ECU Supply
3 cell li-po
Total Weight
1768 g / 62.4 oz / 3.9 lbs
P-180-NX
$3700
Thrust: 175N at 125,000 1 / min
Residual thrust: 5N
Weight:. 1710g incl starter / generator
Diameter: 112mm
Overall length: 330mm
Speed: 33000-125000 1 / min.
Exhaust temperature: max. 730 ° C
Fuel consumption: 610ml / min (full load)
JB-180
$3400
Thrust:
Maximum thrust adjustable from 100 to 180N (40,4 Lbf, 18,3Kg )
Size:
106mm diameter, 247mm long
Weight:
1400g (3,1lb) engine, 1.600g (3,5lb) total installed weight except battery
Rpm Range:
28,000 ... 122.000 RPM
Idle Thrust:
4,8N (1,2Lbf) @28.000RPM
Fuel:
Kerosene + 4% oil. Diesel allowed but not reccomended. Fuels containing Biodiesel not allowed.
Fuel consumption:
470g/minute at 180N. (590ml/min
A-180
$2850
Diameter: 109mm
Length: 330mm
K-180g4+
$2850
Diameter: 103mm
Length: 251 mm
Weight: 1540 g
EGT: 700°C max
Sw-190
$2750
19 kg / 41.8 lb
RPM Range
700℃ / 1292 ℉
Fuel Consumption
Fuel
Lubrication
Start
Full auto-start
Restart
Auto-restart
Engine Weight
Diameter
110mm / 4.3 in
Length
258mm / 10.2 in
Every 25 hours
ECU Supply
3 cell li-po
Total Weight
P-180-NX
$3700
Residual thrust: 5N
Diameter: 112mm
JB-180
$3400
- Diameter: 113mm - 4.45"
- Length: 320mm - 12.32"
- Weight: 1540g - 3.5 lbs
- Max Thrust: 180N - 40.5 lbs @ 120,000 rpm
- Min Thrust: 8.0N @ 35,000 rpm
- Consumption at Max Thrust: 550ml/ min
- Exhaust Temperature: 660°
- Fuel: Diesel or Jet A1 (+5% Turbine Oil)
- Acceleration from 35,000-120,000 rpm: 3.0 s
- Acceleration from 60,000-120,000 rpm: 1.0 s
Thrust:
Size:
Weight:
Rpm Range:
Idle Thrust:
Fuel:
Fuel consumption:
#48
Im sorry but I don’t understand your comment, the 210 has the same thrust as all the others out there with the least fuel consumption at around the same rpm with some brands not even specifying what they consume! This is the case with both the A-210 size and also A-180. Both consume the smallest amount at the rpm’s specified by other brands but again other brands don’t even specify.
#49
#50
