Rear Diff Problem
TN
RE: Rear Diff Problem
what was the problem?? i do have a couple of bent shock shafts, but they do not interfere with the movement of the shock, unless i was to bottom out because the bend is at the bottom. and my shocks are stiffer than stock. the bumper mount is broken and i will be ordering a new one soon if i cant fix this one. i broke it when i first got the truck. what happened was i hit a tree at about 45 mph head on and it broke.[:@] better than something else i guess.
TN
you know, you got me started on that shock!! now i have to get a new shock shaft for it. and i also found out about that it busted while i was driving sometime because it was covered in shock oil.
yeah 2 of my shocks leak shock oil 30wt.
the problem was my diff cup. it was all shredded the spider gears shredded some of the cup. that is why the wheels would still turn but no power out of them!
couldnt see it the first time. or maby it wasnt bad enough but the second time i took apart the diff it was like "whoah! look at that"
so its all good now :P
