my first gasser
My Feedback: (97)
MO
RE: my first gasser
FPE is First Place Engine- gasoline powered. Mine is a 2.4 (40cc). A ST2300 is a Super Tigre 2300.
My FPE has 3.1 bhp @7300 running a 20-10 prop. and 18 lbs of thrust.
Altogether with muffler the FPE 2.4 weighs 3.25 lbs.
I would think that should pull this EDGE to the moon. But it don't.
MD
RE: my first gasser
http://rcshowcase.com/ - talk to mike dooley the give great deals although pricy engines
Anyone have any servos?
TN
RE: my first gasser
I tend to agree with the less pitch more diameter, and here comes the BUT, I would use a tach and be careful not to exceed the manufacturer's max rpm numbers. Less pitch will cause rpm to go up however, there is a trade off. You will notice a drop in top speed of the aircraft and gain in verticle performance up to a point. A glow motor is designed to turn approx. 12000 rpm, don't expect your gasser to match that. Where a change of prop pitch on a glow motor may give half again the rpm change (8000 up to 12000) a gasser will probably not gain as much due to the internal mass of the engine.
Also be careful in just accepting HP numbers that you read in the ads. Many times the only way to acheive those kind of numbers is with tuned pipes etc. Also, HP can, and I feel is often, published based on calculation rather than actual measurement. There is also a difference between BHP (brake horsepower) and HP (also commonly refered to as indicated horsepower) which is oftened based on theoretical calculation rather than actual measurement. Some ads rate theirs in BHP other give it in HP. Do a search on the net for good info regarding horsepower values.
My Feedback: (97)
MO
RE: my first gasser
I just don't get why this FPE 2.4 doesn't pull this 140 size Edge verticle. It is a 40cc engine that is pretty light compaired to other engines on the market and has the same HP ratings. There isn't too much to tuning on gas engines. Set the low end and then match the high end with the low. As long as it doesn't quit while the plane is pointed straight up you should be fine.
It runs great BUT . doesn't have the power it should I guess.
#31
NJ
RE: my first gasser
O YEAH WELL WELL MY DA 150 has 16.52 HP!!! Carden 40% Giles WITH A 32x10!!
AND JR8611's all around
LOL[>:][>:] And no thats not me its my grandfather...
#32
NJ
RE: my first gasser
HeHe
Zach Should have gotten a Funtana CHEAPER!![>:][>:][>:]
WITH A YS 1.40L AND TUNED PIPE [>:][>:]IM A POWER FREAK!![>:][>:][>:]
#37
TN
RE: my first gasser
WHAT has any of that to do with this thread? Answer: NOTHING!!!!!!!!!!
Brison doesn't make a 2.2
Zenoah G-23 over-weight, under powered POS
ZDZ 80? Are you stoned?
Saito 180 a good engine for this plane but, NOT A GAS ENGINE!
Your DA 150 - who cares and I doubt if it's yours!
If you can't be of any assistance why bother piping in with your 2 cents!
#38
MD
RE: my first gasser
hey hes playing around. I can vouge for for jon aka j-to-low w/ the da 150. Email the specs of your curent engine and ill find you somthing! [email protected]
sniperwolf12190
sniperwolf12190
#40
MD
RE: my first gasser
no offense iowa but fpe mabey at this case the engine sucks or you have it mounted at the wrong cg the engine box can slide so i will have no prob with cg!
#41
NJ
RE: my first gasser
ORIGINAL: aj and phoenix
CANT HOLD BACK ANY LONGER WELL LETS SEE i HAVE A bRISSON 2.2 SITTING IN gp GILES RIGHT NOW
O AND THE DA150 IS IN THE BASEMENT AND WILL BE FLOWN BETTER THEN YOU WILL EVER HAVE IN YOUR LIFE[>:][sm=punching.gif]
#43
CO
RE: my first gasser
Some engines take time to brake in and give full power. Have you tried to adjust the needle settings? Prop sizes and brands to see what works best on that engine/air frame combination.
#46
MD
RE: my first gasser
j is right man my motor has never seen a plane because the mount is taped and used a metric screw and i cant find anyone with a metric blind nut!!! but plane should be done soon, (im gettin a shipment of odds and ends to finish up). That stinks i have the old version with stock muff. Im going to a special hardware store just to get blind nuts on sat. Airplane should be done in two weeks!
