Savage Racers
NC
RE: Savage Racers
I was having trouble deciding between rear buggy shocks or the LST conversion, but Losi just helped me decide by announcing the release of the Aftershock. It's got plastic versions of the threaded LST2 shocks! Lighter weight, but hopefully that same great performance that the LST2 units provide. They are also designed for a truck that weighs alot more than the Savage, in constrast to the shorter buggy shocks that are designed around a lighter vehicle... so durability should not be a concern.
RE: Savage Racers
ORIGINAL: Chronic
RE: Savage Racers
Have you modified your shocks to lower your ride height yet? You can put a small piece of fuel tubing on the shock shaft inside the shock so that they can't extend fully. It lowers the ride height and improves handling. It does hamper the jumping ability though, as the shocks don't have as much travel. I bought a second set of shocks to do it, so i could switch them out for bashing.
I'd also remove shock pre-load spacers to get it to sit lower and not be as bouncy with the lower ride height.
NC
RE: Savage Racers
The shock mod is a good one. I've got 5/8" limiters in mine right now.
Running uncut springs with the shock mod has the same effects as using the preload spacers. If the truck is too bouncy over irregular terrain, try a softer spring.
RE: Savage Racers
ORIGINAL: gerwen
Thanks and I know about putting in fuel line or what ever spacers in the shock to limit their travel. I have all so heard that using fuel line is not real good as the shock oil eats up the fuel line? No I have not done this yet. I guess if you limit the travel of the shocks taking the spring spacers out would be ok I just wonder if you do not limit the travel and take the spacers out when you do a jump and the shock extends all the way what chance there is of the spring retainer at the bottom of the shock coming off? I have just put lighter springs on that seems to have lowered it a bit. Now I will have to go to the track this weekend to see how it acts this way. I have 3 sets of stock shocks and I am thinking about setting all three up different ways so I can do some testing.
Thanks all for the input.
#31
MA
RE: Savage Racers
I ran maxx bowties on offset velocity wheels, 2 shocks in front and 4 in rear (springs on 2 only) all with black springs and 25wt oil. CP V.2 body with the stock alloy roll-bar, TT TVP's and sts 28. Truck ran great but the shocks were really holding it back. Now my savage is a dedicated basher, I got a great deal on an LST2 which is a much better truck for racing...for me anyway.
#32
MI
RE: Savage Racers
I like the green springs with 30wt oil. Im running springs on all four corners with the four inner shocks as sort of stabilizers, this set up makes for some nice handling with out having to use offset rims or lower the truck too much. Ive also found that the amount of oil you have in the shock will make a difference in performance. I also think it really depends on your particular driving style, like one guys set up might just suck for someone els on the very same track.
#33
RE: Savage Racers
I agree the LST 2 is a very nice racer but in my finical situation right now I either race my Savage or I do not race. All so I like doing things that a lot of people say cannot be done and I like a challenge.
Thanks all for the input!
#34
RE: Savage Racers
my bros savage is a racer. he has flm shock towers;. powerstroke shocks. collari .32 with collari pipe and header. nubz. sepktrum radio. he might get the lcg chassis but he likes his revo and wants to spend money into that
#35
NC
RE: Savage Racers
My Savage eats my LST2 for lunch at everything. Track, straight line, jumping.... you name it, and the Savage wins every time. I'm not saying that the LST2 wouldn't be just as good or maybe even better if it was built as much as the Savvy, but making the Savage compete with other trucks isn't impossible. I run with a guy alot who has about $1200 in his Revo setup and he gets his ass handed to him on a regular basis and once we get off the track and on the bashing field, they are the ones who can't hang. That's the beauty of the Savage...
I will admit that those trucks make a more logical starting point for a racer, but the Savage can hold it's own.
Back to the springs. How stiff are the green ones compared to orange? I've been wanting to try some but I don't know anyone that has any. I'm going to try four blues up front next, and see if they perform like the black/orange combo that's on there now.
#36
RE: Savage Racers
If I am not mistake the green is the next step up form the red/orange as far as hardness. Until I got my Red/ Orange springs I did not understand why people said orange as HPI says red. But after receiving mine they are defiantly closer to orange then red. I have a set of the green ones on the way so I will all so test them after testing the combination I have now. I often wondered about Savage, Revo but did not want to start a flame! Thanks for the input and now I will do my best to get my Savage where it will do well against the other brand. I like doing things people say cannot be done or at least give it one heck of a try.
#37
RE: Savage Racers
hey, i have a savage which has a pretty good setup. i finally fixxed the clutch on it and ran it on the track against a revo 3.3 with upgraded electronics, trinity pipe, forward only conversion. pretty much around the track they are about even. i actually like the savage better becuase IMO it handles better in teh air. the revo feels kinda light. i think the biggest things that helped is the hpi nubz....and the suspension adjustments. as we speak i am running stock shocks. with 30 front and 35 rear. running green springs. it made a big difference. i tried the proline powerstrokes and didn't like them too much. so im back to stock ones. it runs great handles much better and jumps even better. i have .5" shock limiters which made it lower and FLM shock towers which also are a must for adjustability. oh yea i forgot one thing. a powerful engine doesn't hurt. lol pm me for any other questions i got a few tips that might be helpful. i did a lot to my truck.
#38
RE: Savage Racers
ORIGINAL: 3spdsavage
Are you running green springs on all 8 shocks? Like I said I think mine handles quite well on the track. As far as running with Revo’s only time will tell.
#40
RE: Savage Racers
ORIGINAL: 46u
What are you going to? Are you going to the 4 buggy shocks? If I stay in racing I am going to the buggy shocks but I would get the LCG set up first.
ORIGINAL: Chronic
I'm running the red/orange springs too. I've got a single spacer on each rear spring, and on the front I now have one black spring and one orange spring on each corner with no spacers. I'm swapping out the whole shock setup soon though. These things just aren't up to the task.
I went to Rodslingers last Saturday and had a blast. Watched and did some refueling in the pit for a racer. Took a couple of laps during the 1 hour break they had. Time to start moding the truck to handle the track. Lots to do and I'm reading a lot. The LHS has the threaded HPI $135, he said he would sell them to me for $80, are they worth it? I need to get tires, wheels and a radio.
The HPI threaded are shocks. !^)=
Eric
#41
RE: Savage Racers
The two things I did to mine that helped the most to this point is the off set wheels and good tire inserts. This took a WHOLE lot of the roll out! I am running the stock shocks and so far they seem to work fine. I will be trying softer springs tomorrow on the track. I know some said they do not like stock shocks.
Hope to see you up at Rodslinger or Macon this summer. If I get more practice on the track hear and make a few more changes I will be going up to Rodslinger for practice. Keep us posted on what you do and how it works out and I will do the same.
#42
RE: Savage Racers
Tazfxrp we will more then likely be the only to Savages around racing here in middle Georgia. I all ways have been the out case and all ways will be!!!!
#43
NJ
RE: Savage Racers
Hey 46u here is a picture of a integy sway bar I put on my sons 25 RTR for
racing last year. It really made a difference at the track. Also when I make
a change to his truck for handling, He does the test drive and I watch.
We've not been to the track yet this year,but hope to soon.
Anyway I had his set up with black springs all around and no spacers.
While watching him test drive I could see the front end bottom out
hard heading into and up a jump. I added the stock spacers to the
stock shocks and that stopped that problem and didn't hurt handling.
Also the stock sway bar that comes in the sway bar kit is junk. I made
a new one out of 1/8" CRS and I also got rid of the ball sockets that the bar ends
attach to. I made new ends out of titanium and I use fuel line for bushings.
I did this for two reasons,
#1 the stock bar sucks.
#2 with the stock ball socket setup it tweeks the front suspension
at shock compression. I.E. at a landing it would cause positive caster.
Now on a dirt track with a monster truck that might not mean much
but me being a machinist I didn't like it. I can be anal. Over all I
do like the sway bar enought that I made the same mods for one
on my LE.
Also Tazfxrp, That a police bike?
on my LE.
#47
RE: Savage Racers
ORIGINAL: 46u
Eric
#48
RE: Savage Racers
ORIGINAL: 46u
Yes he has a FXR Police bike. I still have my Ultra Classis, do you still have your FXRS?
Google RMH group and look for Tazfxrp, you can read the whole story if you care to. Great people and great friends in that group.
Taz
