OMP - Ohio Model Products Support Forum Discuss products and get support from OMP. This forum is operated by the owners of OMP and your support questions or complaints will be handled as OMP deems appropriate.
OMP Fusion Picture Gallery
Old 08-18-2007, 09:50 PM
Futaba Owner
Futaba Owner's Avatar
Default RE: OMP Fusion Picture Gallery
I'm not to familiar with all the coverings, so has anybody had problems with the china kote on the fusions?
Old 08-20-2007, 07:41 AM
AFSalmon
AFSalmon's Avatar
As with any ARF is is a good idea to go over allthe covering with medium heat when you first start. The Fusions are no different. Go over all the edges of the covering with your covering iron and medium heat. Any loose edges of covering can be tacked down with trim solvent or even thin ca if you know how to use. I did all this even on my 35% aeroworks yak.
Old 08-20-2007, 08:42 AM
geh3
My Feedback: (84)
geh3's Avatar
I notice that there is a differnce between the ARF fusion and the Kit FUSION in regards to the number and placement of hinges( the kit has more) should the arf be upgraded to the # called for in the kit?
Old 08-21-2007, 07:01 AM
AFSalmon
AFSalmon's Avatar
The ARF has plenty of hinges and we haven't had any issues with the hinges. Hinging is one of those personal preferences on models - folks tend to do hinges they way they like to do them. Some folks use a lot of CA hinges and others like point hinges such as Dubros.
Old 09-08-2007, 02:40 PM
daveopam
My Feedback: (9)
daveopam's Avatar
Mike if I order a Fusion 90 as of right now will it be Ultra Cote? I love my 52" Fusion ARF but will need to recover it. I don't want the 90 size to be the same way.
David
Old 10-24-2007, 03:13 PM
  #31
daveopam
My Feedback: (9)
daveopam's Avatar
Sorry to double post if you guys saw my other thread. I am just so happy with how my 52" came out. I wanted all to see it.
Bottom is 2"x2" Ultracote. Rest is Monocote. Metalic green,yellow,white and red.
David
ID:	789653   Click image for larger version
ID:	789654   Click image for larger version
ID:	789655   Click image for larger version
ID:	789656   Click image for larger version
Old 10-24-2007, 03:26 PM
  #32
exeter_acres
exeter_acres's Avatar
My 40%Carden Extra 330 and my Fusion........
Old 10-24-2007, 05:50 PM
  #33
AFSalmon
AFSalmon's Avatar
SCHWEEEEETT!
Old 11-07-2007, 11:25 PM
  #34
alqwad
My Feedback: (12)
alqwad's Avatar
Here's mine... Began it's life as a white ARF that I got from y'all a few months ago while they were on sale. Maidened today. Flies great. Got about 4 tanks run through it. Saito 82 for power. Great knife edge and KE spins. On final flight for the day, I noticed the gear was lagging toward the rear of the plane a bit. Flew it around the pattern a few times and decided it was just an optical illusion... NO. It was obvious that the top LG bolt had fallen out when the gear "retracted" to the leading edge of the wing on my otherwise smooth landing. Gear just neatly folded back with no damage whatsoever. My mistake for not tightening, I guess. It was actually pretty funny. Unfortunately, no one was there to witness. Again, very good plane. I think I might try an Edge kit...
Old 11-08-2007, 07:56 AM
  #35
AFSalmon
AFSalmon's Avatar
I like the blue prop spinner---Nice touch. Put some graphics here and there and that would really dress it up.
Old 11-08-2007, 10:45 AM
  #36
alqwad
My Feedback: (12)
alqwad's Avatar
Thanks Mike... I have a question for you with the 40 size tetherite gear. I have one that a friend gave me a while back. The mounting holes are drilled 1 1/8" center to center. Is this the same as the newer ones that you guys carry or are they drilled to bolt right up to the ARF 's pre drilled location, which is a bit larger? Thanks.
Old 11-24-2007, 04:10 PM
  #37
daveopam
My Feedback: (9)
daveopam's Avatar
The Tetherite I bought was not drilled. Great covering job. I like the way you did not wrap the black over the top. I never thought about doing it like that.
David
Old 11-24-2007, 09:38 PM
  #38
alqwad
My Feedback: (12)
alqwad's Avatar
Thanks for the compliments Dave... I'm not much of a covering guy; I don't have much experience and I'm not that good at it. Thanks again.
Old 11-25-2007, 12:05 PM
  #39
daveopam
My Feedback: (9)
daveopam's Avatar
I think you will find that on most covering jobs the defects can only be found by the installer.
David
Old 11-25-2007, 02:13 PM
  #40
eyalbartfeld
Here are some pics of a Fusion-90, built from a kit. Note the 'bud' muffler. (Location: Boston area, look at the foliage in the background)
ID:	811532   Click image for larger version
ID:	811533   Click image for larger version
ID:	811534   Click image for larger version
Old 11-25-2007, 08:10 PM
  #41
John Wells
My Feedback: (10)
John Wells's Avatar
Here are a couple of my Fusion 90 ARF with YS 110.
Fusions ROCK!!
ID:	811868   Click image for larger version
Old 12-18-2007, 12:38 PM
  #42
MIXMASTER
My Feedback: (15)
MIXMASTER's Avatar
Love the ARF's that come with Mono/Ultra cote, hate that China-crap stuff. You know its going to be bad when the covering falls off just handling the parts. The adhesive separates from the film in the worse way, in a spotty way, then you cant get it heated back down in exactly the same position. I had to use packing tape to seal the edges in that spot, nothing to hold anymore, not even finished building yet!
Old 12-18-2007, 01:18 PM
  #43
AFSalmon
AFSalmon's Avatar
ORIGINAL: eyalbartfeld
Love the bud pipe. I have not seen that particuliar can. I have several myself including a nice looking orange fall theme bud can. I'm saving that one for a future plane.
Old 12-26-2007, 03:38 PM
  #44
bodman
I bought a white Fusion with the china cote covering. The covering looks good at first, but it seemed very brittle and the clear seperates from the white when you pull it loose. I used a heat gun to warm up the covering and then pulled it off. Some of the white stayed on, but I used laquer thinner to clean off the white. I am going back with Ultra Cote.
Old 12-26-2007, 07:15 PM
  #45
daveopam
My Feedback: (9)
daveopam's Avatar
bodman, you can also use Trim Solvent if you have some.
David
Old 12-28-2007, 08:27 PM
  #46
bodman
David,
Thanks, I run a body shop, laquer thinner is always on hand. Fusion looks to be a good plane. I have a Mvvs 91 to put on it.
Old 01-03-2008, 06:56 PM
  #47
John Wells
My Feedback: (10)
John Wells's Avatar
Here's the way to deal with the chinakote and it works. Clean your covering with Windex and paper towels (no remaining oil film!). Easier to do this to a new Fusion with no oil residue.
Next, detail the covering with a warm to medium, not hot iron. When you get it all tightened up and the edges ironed down, do this;
Spray some clear Lusterkote (can spray) into the can lid. Wait a minute or so for the tiny aerosol bubbles to dissipate from the liquid. Use a small brush to apply a thin bead of the liquid Lusterkote to the covering seams (where the color meets the white). I did my entire Fusion 90 in about 45 minutes.
Let the stuff dry overnight and guys, your Fusion covering will not be an issue anymore.
Old 01-06-2008, 02:16 PM
  #48
Tango Juliet
Tango Juliet's Avatar
I wish I had seen this earlier, I just ordered the large Fusion ARF in all White. If the "China"Kote is that bad, how hard would it be to just remove it from the beginning and replace it with something of a better quality? Obviously one buys a precovered ARF in an effort to avoid this, but ARC's don't seem to exist anymore, and if I'll need to recover it eventually anyway, I may as well do it now right?
Old 01-06-2008, 02:30 PM
  #49
Tango Juliet
One other Question: What's everyone using for power?
Old 01-06-2008, 03:46 PM
  #50
alqwad
My Feedback: (12)
alqwad's Avatar
Most 4 stroke users are going with Saito 72 or 82. Best power to weight ratio out there... 2 strokes that seem popular are the OS 46AX and 55AX. Engine prefrence runs a plenty. Good luck.
