panzer 4 schurzen
RE: panzer 4 schurzen
Hey Cheap tank It just so happens I have a Pzr III, so do you recall where you saw that Pzr III
shurzen for sale ? and were they selling the Turrett Shurzen also ??
Barry
VA
I installed speaker from old pc junk the box is painted card board hot glued in. I have used a few pc speakers i found in the trash they are small enough to fit and sound alot better.
VA
I got it all put together the gearboxes are mounted on a couple peices of aluminum to brace the hull and raise them up.After fixing the gearboxes they are almost quiet and run alot smoother.
VA
I have sprayed the cammo now i will finnish the tools and a couple of oil washes. Im mot syur i lake the muzzle break but it is my first try and it is made from a peice of broom stick so like the rest of this one i have spent nothing on it
#33
VA
I dont think i like the paint maby just green. If i dont repaint it it will be the first one. Plus the pz3 needs a partner.
#34
VA
Finaly got a chance to repaint and finnish the tools now i need to come up with a new tc and do a couple of brown washes and i think its done. Now that i have run it a bit the bogie and wheel fix makes a big improvement no more wheela flopping around or track throwing in tight turns.
#36
VA
The first thing was to throw away the armor plate on the front then cut the mantlet to fit the opening on the turet add a plastic strip on the top and then fill with squadron putty to get the concave shape on the front. I am not shure what these parts are called but the block is just a plastic face cut and bolted to the stock one then filled and sanded the tube is a peice of gutter nail spacer cut to length. The barrel is a left over from my matorro kt cut and turned on a drill and belt sander to get a little taper to it and the muzzle break is a peice of broom handle turned the same way then use super glue and let it soak in to keep it from splitting then drill the side holes and clean up with a small file. Some of this one i dont think came out that great but i wanted to do it without buying a bunch of high priced parts at least i can get my model fix with out going more broke with work being what it is.
#37
Dunno if it's been mentioned or not yet, i found this site a few days back that has schurzen for panthers, stugs and the panzershttp://www.tank-modellbau.de/
#38
It turned out great. I'm using some Tamiya parts on my HL Pershing. Got the mantlet and barrel and recoil all grafted on. Looks 100% better already. Gonna use the Tamiya electronics to .
