JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Let's talk DX18 here!
Old 07-10-2016, 01:07 PM
  #476
twhite6728
My Feedback: (20)
Originally Posted by AndyKunz
Version 1.11?
I have 1.04D
Old 07-10-2016, 03:16 PM
  #477
twhite6728
My Feedback: (20)
I just updated firmware and now have the ability to get to the flight mode table to be able to assign switch position to Fmodes. I did forget to copy models to my SD card before hand! Now I have a hole lot of programming to do.
Old 07-11-2016, 03:41 AM
  #478
BarracudaHockey
BarracudaHockey's Avatar
Really? Updating your firmware shouldn't have wiped out your models
Old 07-11-2016, 04:45 AM
  #479
AndyKunz
He went from a 50-model version to 250-model version. That always wipes out models.
Andy
Old 07-11-2016, 07:06 AM
  #480
BarracudaHockey
Ahh yes, I forget that not all the 18's were 250 models.
Old 07-11-2016, 10:01 PM
  #481
twhite6728
My Feedback: (20)
I have a friend with a DX18 with firmware 1.01 I believe, and I had taken my SD card that has the current firmware on it and when he tried to update his radio with my SD card, the radio didn't update. Are there prerequisite firmwares that must be done before the most current firmware is uploaded?
Old 07-12-2016, 04:16 AM
  #482
AndyKunz
Each update is serialized to match the transmitter. His radio won't load your file. Have your friend register his radio and download the update.
NOTE: HE NEEDS TO BACK UP HIS MODELS! The update will convert from 50-model to 250-model memory, and doing so wipes out all the current models, unfortunately.
Andy
Old 08-25-2016, 08:51 PM
  #483
liftmys10
I noticed my right gimbal's travel throw up and down is more that the left gimbal.
Upon further investigation it looks like there is a plastic spacer missing from inside that limits the travel. Any reason for this?
Both my gen1 and gen2 dx18s have this issue. Thanks
Old 08-26-2016, 04:09 AM
  #484
AndyKunz
They are called "throttle wedges" and they are there to limit travel of the throttle stick. When you change between Mode 1 and Mode 2, they are moved with the throttle stick. This is why you need to recalibrate after changing modes.
If you need more details, I've explained it more thoroughly in the past on RCG. You can find explanations in dx8 threads going back six years.
Andy
Old 08-26-2016, 04:28 AM
  #485
BarracudaHockey
It's not an issue, its a feature
