Old 03-01-2021, 05:10 AM
  #50026
FlyerInOKC
FlyerInOKC's Avatar
I can't wait to see it in the air and it should be easy to see too! The black decals on the bottom of the wing will make it easy to see if she is upright or inverted.
Old 03-01-2021, 05:27 AM
  #50027
Glowgeek
Originally Posted by 1200SportsterRider
Pinky Plane is "gorguous", a new word.
My Granddaughter would call it Totes Gorge.
Old 03-01-2021, 05:36 AM
  #50028
FlyerInOKC
FlyerInOKC's Avatar
Show her a picture then offer to help her build one, you'll have her hooked for life!
Old 03-01-2021, 07:24 AM
  #50029
husafreak
husafreak's Avatar
Originally Posted by FlyerInOKC
I love the patch! I wonder where I can get one? I lived for a time when I was growing up in Enid, OK home of Vance Air Force base. Vance AFB now days is home to the 71st Flying Training Wing. They have been training pilots there since the 1940s.
​​​​​​https://www.ebay.com/itm/USAF-96TH-F...97.m4902.l9144
I'd send you one but unfortunately I don't have any either! I have a box full of old patches but not, arguably, the best one
Old 03-01-2021, 08:03 AM
  #50030
FlyerInOKC
FlyerInOKC's Avatar
$7 isn't bad for the patch. I just may order one. Right now I'm trying to solve an airplane storage problem. I got one I am sending to my grandson in Kansas but that still leaves finding a place for Pinky. I got a couple more projects I am dying to start but SWMBO wants the storage issue solved first. Both will be 1/5th scale so they won't be small.
Old 03-01-2021, 09:20 AM
  #50031
flyingagin
flyingagin's Avatar
For plane storage, I use racks hung from the ceiling in the garage. Just 2x3s suspended in pairs, maybe 2-3 foot apart and parallel (roughly). I drill about half way through for a dowel on one edge. Can put a lot of airplane (disassembled) in them. But since garage is also a wood shop, they sure get dusty. On one rack hung under it a shelf 4'x8' for flat storage of things. I then put shop lights under the racks.
Ken
Old 03-01-2021, 12:24 PM
  #50032
FlyerInOKC
FlyerInOKC's Avatar
I have been using ceiling space in the garage but I have hit the saturation point. I have a wood rack, airplane rack, ladder, garden tools, etc. I also have two garage doors and openers on both. The garage was built built early 60s when all you stored in the garage was the cars, not much room left over at all.
Old 03-01-2021, 03:21 PM
  #50033
flyingagin
flyingagin's Avatar
Yeah I hear you on room in the garage I was at saturation also, almost. That rack on the left of the pic is 1" above the garage door when it is opened, so I could have built another rack on the opposite side of the door..
Ken
Old 03-01-2021, 04:27 PM
  #50034
FlyerInOKC
FlyerInOKC's Avatar
I don't have the room between the garage doors and ceiling to put anything.
Old 03-01-2021, 05:38 PM
  #50035
modeltronics
My Feedback: (27)
Mike, I had to do a search on SWMBO to figure out what that was.
Old 03-01-2021, 07:23 PM
  #50036
flyingagin
flyingagin's Avatar
FlyerInOKC is your door one those one piece ones, wood that tilts up and in? That was pretty much in the 70s and back. I had one of those and no they don't let you use any of that space. And the bloody blasted things hinge bracket broke while I has lifting it from inside. I caught it, not a good thing. Man that hurt. And as a sailor at the time I thought I had rather robust command of swearing. Not even close, jeez.. I have since put that language behind me.
I did replace the door with a segmented tracked door. Bought the door and did the work myself with my now X's help. I took her to E.R. before the job was done though. She was on the opposite side working on a spring bracket. Loosened it while the door was down and the spring stretched. She caught the bracket in her for head. Laid her right out. Then in E.R. while the Dr. was sewing her head up the power went out. Their emergency gen kicked in then died. I held a flashlight for the Dr. to finish sewing. Lucky that she had already had her head x-rayed.
Had a garage door here break. I hired some one to do the job.
Ken
Old 03-01-2021, 08:58 PM
  #50037
FlyerInOKC
FlyerInOKC's Avatar
I have the 4 segment doors with tracks on each side and a spring system on the door header. When the doors are open the space between the door and the ceiling isn't sufficient to hang airplanes.
Old 03-02-2021, 12:11 AM
  #50038
Monty Python
Monty Python's Avatar
It comes from an english comedy tv show called Rumpole Of The Bailey, he's a barrister.
Old 03-02-2021, 12:16 AM
  #50039
Monty Python
Ken sorry to hear about your wife being injured while helping, bad news and hope she is fully recovered. Now as to your assertion that you have laid off swearing for good I bet you a slab of Australia's finest Emu Export stubbies that this picture will prove me right in the future buddy
Old 03-02-2021, 02:36 AM
  #50040
MarkYouatt
I only have one - an FA82 bought second hand. Very little use and looks to be running well on the WhatSapp call before I paid.
Unfortunately, when it arrived, a few months ago, the main needle and the throttle arm were separate in the box. What is a good starting point for the high and low needles?
TIA
GG
Old 03-02-2021, 03:48 AM
  #50041
1200SportsterRider
1200SportsterRider's Avatar
Hey Mark, welcome, about 1/16th" below the face of the plastic throttle arm.
Old 03-02-2021, 04:24 AM
  #50042
Glowgeek
TIA
GG
Hi Mark. As Dave said, a good starting point for the lsn is 1/16" in from flush with the outside of the plastic throttle arm. This will put it flush with the inside of the plastic arm. That setting will likely to be too rich. Lean from there.
Set hsn 3 turns out from lightly seated. This will also be too rich so lean from there. You'll likely end up with the hsn set at 1-1/4 to 1-1/2 turns out peaked at wot.
Old 03-02-2021, 10:50 PM
  #50043
MarkYouatt
Cheers guys. When we are allowed out to play again (hopefully 29/3), I'll give it a go!
Very eager to use this little jewel of an engine..
GG
Old 03-04-2021, 06:22 PM
  #50044
1200SportsterRider
I was supposed to receive a nice clean Saito 80 with the rough finish rocker covers. Maybe a high compression one, here's hoping.
I got the USPS favorite buzz term, "on it's way but running late"
Old 03-04-2021, 08:14 PM
  #50045
FlyerInOKC
FlyerInOKC's Avatar
Yeah right, good luck with that! That is what my mail order prescription shipment says too. It was mail 2/16/21 and made it to the distribution center on 2/16/21 and you can see the last history item below is dated 2/20/21 is "In Transit, arriving Late".
Feb 20
In Transit, Arriving Late
Feb 16
12:11 pm
Arrived at USPS Regional Origin Facility
LAKE MARY FL DISTRIBUTION CENTER
Feb 16
10:56 am
Accepted at USPS Origin Facility
OVIEDO,FL 32765
Feb 16
Pre-Shipment Info Sent to USPS, USPS Awaiting Item
Old 03-05-2021, 01:35 AM
  #50046
erieqc
I always hate to ship anything to Florida it sets in the distribution center for at least 2 weeks.
Old 03-05-2021, 04:11 AM
  #50047
Hyjinx
Default Shipping, what shipping
Have variable props coming from Germany. Vendor said may be a minute but could be eight months. DHL charged an additional ten for a tracking number.
It can't find the package.
Old 03-05-2021, 05:31 AM
  #50048
FlyerInOKC
FlyerInOKC's Avatar
I had a order from China that showed fairly quickly but it wasn't what I ordered. I got tired of PayPal taking forever and turned it over the cc company. I had a previous shipment from Asia that never appeared, Amazon ended up refunding that one.
Old 03-05-2021, 05:41 AM
  #50049
Jesse Open
Jesse Open's Avatar
I allow NOTHING to ship via the US Postal Service tyrants. Abo****ey will not support their union's temper tantrum. FedEx shipping is getting the job done reliably.
Been paying with PayPal for about 20 years and their record is stellar.
Old 03-05-2021, 05:44 AM
  #50050
1200SportsterRider
This one is coning from Florida, coming north didn't help.
