Thanks for the info I appreciate it. I'm more of a scale flier than a 3D flier. I don't a vertical climb I want something with enough power to get me out of a dumb thumbs situation and still look scale. The full size airplane with the original 145 Hp Scarab engine she was rated at 150 mph top speed and a 135 mph cruising speed. The stall speed was listed at only 45 mph. I suspect those speed numbers were probably closer to what she did with the 165 Hp Super Scarab engine.
Good karma? What do you call it it when two days later this happens?
I got struck by lightning!
A bad storm came through yesterday, the power cycled off and back on. When I picked up an alarm clock to reset the time a lightning bolt struck in the back yard and lit me up. It hurt a little but dddddidn't rrrreally aaafffffect mmmmmme in any wwwwaay.![EEK!](images/smilies/eek.gif)
About $600 in damage to electrical appliances.![Frown](images/smilies/frown.gif)
dang! I am sorry to hear that. I would help you get things together if I lived around there.
you know. even when I dropped that 3" pipe die on my big toe three years ago I never really believed in karma. good luck Lonnie, good luck
Jim
Well, I ALMOST test ran the Corsair, but I have a bench full of balsa and plywood taking up the space I would use to get the Corsair prepped to test. $884 worth of wood, and got the first GS Corsair short kit in the works, the balsa parts are all done, and now working on the plywood parts. I spent most of today aligning and setting up back and side stops on the table so absolute coordinates work every time, all the time. Only downside is that it some what took away my pass through ability, have to work that part out so I can cut the long sheets to size. Maybe I can get to the 120R3 tomorrow.
![](https://cimg6.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/505a7fd6_9f69_4f0d_8db4_19224d539462_8530b9157e3379762597ff8fa91ec1c48c301414.jpeg)
![](https://cimg8.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/ecc1e247_56cf_4266_92cb_7f97edb841d8_b87ba7568eac23c11607a4fa9797caf9d69c58a4.jpeg)
Wow, in America Speak, that's 110,410 cubic inches, thanks Pete. And it's a two stroke with always verticle piston rods.
Bruce I bet I can drink 884 bucks worth of beer before you finish cutting the 12 kits friend ![Smile](images/smilies/smile.gif)
Dave glad you like the pic of that massive crankshaft, I'd like to see the massive machinery built to manufacture them. I did not realise that the engine was a two stroke so hope I have not encouraged Jim to break in to that factory and paint the crank black and gold or post another heli two stroke engine pic, I've included the appropriate mod tool as a special favour, cheers
![](https://cimg0.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/230x211/img_1291_5880e505f22428695103b312afd9ea11051e41e4.gif)
![](https://cimg1.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/500x335/157957855_10159065520423349_5086491677114537002_n_ec0b0e405072aa3c6e11425351cd19a2322d33a8.jpg)
ps, this one's for you jim![Smile](images/smilies/smile.gif)
The Corsair is $250, the P-47 $225 and the .60 Corsair is $160. Shipping is about $20. I may run a promotion once I get everything finalized and have a web site in production. I still need to get dome photos of the kit together, and get a kit cut of the other two. I get that done and then add a few more kits to the system. Need to finish the Liberty Sport, add the Bearcat, Chipmunk, Ultimate Bipe, couple P-40's, Top Flight and Pic, and a few others. My friend and I are also designing a true 1/8th scale B-17E with scale bomb bay.
The where to put it did not cross my mind when I ordered it, so now I am trying to find places to store it all, including the packaged kits since the boxes are 28 x 8 x 8. Its taking up a full workbench at the moment.
husafreak (03-26-2021)
Slowly getting my various Saito FA's swapped out to FG's in my 60 size warbirds. This requires changing the tank floor height on most of them and coming up with innovative ways to accomodate the ridiculous throttle arm location on these gassers. What's working good is to use a Saito throttle arm extension and replacing the factory 14 oz tank with an 8 oz tank so that the throttle cable can have proper alignment. I'm also adding a vertical partition on the tank floor to keep the tank from interfering with the throttle cable. It's tedious work in cramped spaces but worth the effort to me.
Unlike glow engines gassers require very close fuel metering to operate smoothly. Anything that effects A/F ratio or fuel delivery negatively effects performance. Changing oil type, oil content, octane rating, partially clogged fuel filter, kink in the vent line, changes to air baffling etc. can cause the engine to need retuning. Among the things that can problems is throttle cable alignment. The throttle cable needs to make a straight shot from the firewall to the throttle arm so that side pressures are reduced/eliminated. Also, if the throttle barrel is allowed to oscillate in and out while running it can cause issues so I have been replacing the weaker throttle barrel springs with stronger ones from RCexl spark plug caps when necessary. Just some things I've noticed.
Hello ball bearings with ZZ must be mounted on engines that have a ventilation nipple in the front. motors such as the nipple in the rear cover. shall have open ball bearings
