Old 09-19-2021, 02:15 PM
  #51276
acdii
My FA-72 needs help, don't know what is wrong with it, but it just wont run. Going to have to tear it out of the lane and put it on the stand. It used to run great, then had to replace the cylinder, hasn't run right since. Has good compression, so it seated well, I just can't get it to run reliably, is sags, or two strokes at times, or just plain quits and wont restart.
Old 09-19-2021, 03:04 PM
  #51277
Glowgeek
Unmetered air getting in somewhere?
Old 09-19-2021, 04:09 PM
  #51278
vertical grimmace
vertical grimmace's Avatar
This is the plane I am building. Thanks for the vid.
Old 09-19-2021, 04:13 PM
  #51279
vertical grimmace
Just an FYI, I have a fellow club member from Norway. He has friends that are still there. He talked to them, and there are 2 LHS that keep glow fuel in stock. So good news. I plan to mix up some 10% for my Saito 180, as this should be no problem to get when in country. I do think it will be a good idea to put the CH ignition on the engine as well, as I wanted on board glow anyway, and this somewhat simplifies that, while adding more control. I am not interested in going full on a gas conversion, not yet anyway.
Old 09-19-2021, 05:18 PM
  #51280
Glowgeek
Good news on the fuel availability in Europe. You'll love how the engine behaves on CDI, regardless of fuel type.
Old 09-19-2021, 08:23 PM
  #51281
Jesse Open
Jesse Open's Avatar
I have repurposed several Saito gassers to methanol fuel with CDI. Very rewarding. The fuel burn rate drops, power moved up, idle is great and they run substantially cooler. The transition is superb.
My favorite has been the FG-20 which is the FA125 in gaspoline disguise.
Another member of this group "Sr. Telemaster" has done several large Saito CDI/Methanol with stellar results. Good on ya, enjoy!
Old 09-20-2021, 01:38 PM
  #51282
the Wasp
Dave, check out this 9cc Pan Head V Twin,
Jim
https://www.stirlingkit.com/collecti...asoline-engine
Old 09-20-2021, 07:33 PM
  #51283
Jesse Open
Jesse Open's Avatar
This fellow from Gulliver Michigan( My favorite fishing place in the Upper Penninsula) was a regular at the NAMES shows about 20 years ago.
He made several fine miniature engines. Including a Gnome Radial and a V-12 Allison, among others. They all started easily and ran well.
Made from real castings!
Old 09-22-2021, 04:35 AM
  #51284
Glowgeek
Crickets chirping here. Fun to watch those two V-Twin vids over and over though.
Old 09-22-2021, 06:07 AM
  #51285
1200SportsterRider
1200SportsterRider's Avatar
Thanks Jim, it does need a better carb, those Perry's just don get it done.
Old 09-22-2021, 07:10 AM
  #51286
1200SportsterRider
I pulled my FG 11 to give it a physical and decided to make a rear facing vent for it. That turned out be a near nightmare. The original vent was so tight it sprung my wrench even though I removed the Hall effect sensor so I could get the wrench on it straight. A pair of small vice grips got it out after smashing it flat. I used my last new vent to make this one. I'm proud of this one.
Old 09-22-2021, 07:24 AM
  #51287
acdii
I use small 1/4" drive 6 point Snap-On sockets to remove them if I can get the socket on. Less chance of damaging the flats. Even the tightest ones come off without damage. Trick is to have the pressure 100% straight down and not off to the side like a wrench does. Broke more fittings using a properly fitted wrench than using the sockets.
I wonder if I can convert my 72 to CDI, and if the extra weight would affect the Something Xtra. I may also look into CDI for the Gemini II 120.
Old 09-22-2021, 07:28 AM
  #51288
1200SportsterRider
Adrian is kind of secretive about it, but he has or had some Hall effect sensors that fit the 72/82. The vent on the FG 11 is too close to the main bearing bulge to get a socket on it, I tried all I had.
Old 09-22-2021, 10:19 AM
  #51289
Jesse Open
Jesse Open's Avatar
This is where I simply reach for the heat gun without even trying 250 deg F does the trick without fail.
BTW, I usually move these vents to the cam box whenever the box is off.
Old 09-22-2021, 01:01 PM
  #51290
Glowgeek
Aaaaaaaamen to using heat for breaking loose stubborn fasteners in aluminum parts. Makes removing those rocker pins a snap, instead of the blade of that tiny screwdriver.
Dave, does the FG14 come from Saito with that casting web milled off? Looks like clearance for the sensor tab. And yes, I'm wondering again.
Old 09-23-2021, 02:40 AM
  #51291
1200SportsterRider
It appears that the bottom center web is milled for clearance on the FG 14.
Bottom web machined for clearance.
82-b not machined
Old 09-23-2021, 03:42 AM
  #51292
Jesse Open
Jesse Open's Avatar
I hand file the ribs to install the CH bracket on FA-125 Saitos.
The CH brackets also perfectly replace the Saito plastic thingy on the FG series.
Old 09-23-2021, 05:51 AM
  #51293
1200SportsterRider
Lonnie, this combination works on the 82-A, but the reinforcing webs are a tiny bit wide to mount the bracket on the 82-b. It could be done with a little careful filing. If you'd like to take a crack at it, I can fix you up.
Old 09-23-2021, 06:07 AM
  #51294
Jesse Open
Jesse Open's Avatar
The hole drilled thru the rib is used for a nylon tie-wfap. Secure strain relief for the Hall Effect pickup lead wire.
I make a similar bracket for small Saitos. Bottom mounted and allows easy timing changes and fixed magnet position.
Old 09-24-2021, 02:06 PM
  #51295
1200SportsterRider
The FG 11 fires right there when turning by hand. I don't think my timing light will read through the CHI high tension lead to check while running.
Old 09-24-2021, 09:26 PM
  #51296
rajul
Moderator
My Feedback: (58)
rajul's Avatar
I have to service my Saito 82 and 125 after many years of storage. I was digging through my inventory of spare parts and found these whitish washers. Not sure if they belong to Saito or OS. Can anyone recognize them? There are two sizes in the pack. Unfortunately I lost the original label and description. Thanks for the inputs!
Old 09-25-2021, 01:32 AM
  #51297
Glowgeek
Originally Posted by rajul
I have to service my Saito 82 and 125 after many years of not using. I was digging through my inventory of spare parts and found these whitish washers. Not sure if they belong to Saito or OS. Can anyone recognize them? There are two sizes in the pack. Unfortunately I lost the original label and description. Thanks for the inputs!
The smaller ones appear to be camgear thrust washers used on older small/midsize saitos. The larger ones for saito choke assemblies perhaps. Hard to say without measurements.
Old 09-25-2021, 02:21 AM
  #51298
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Here's a photo with some scale information. They're either for the Saito 82/125a, or for the OS 46fx/61fx. Non-magnetic material
Old 09-25-2021, 02:58 AM
  #51299
1200SportsterRider
Hey Rajul, long time no see, the larger ones go in the this relief for the choke slider to seal against as Lonnie splained. The relief can also accept these aluminum rings that index the big block velocity stacks.
Old 09-25-2021, 03:06 AM
  #51300
Glowgeek
Neither are for Saito imo.
