Old 11-17-2021, 04:21 AM
  #51526
Glowgeek
Originally Posted by 1200SportsterRider
Something I picked up on when trying the tool out was that the oil hole in the cam bushing is seldom lined up precisely. If the little "nub" on the end of the tool is too long and cannot bottom out, the cam can move around a little.
That's one of the reasons I ground a tapered tip on my tool, never contacts the camshaft bushing, only engages the oiling hole in the cam lobe. The other reason iss because I could make the taper on a bench grinder, no metal lathe handy. 25 cents worth of 5/32" steel rod and 5 minutes, done. The tool doesn't have to be fabricated precisely, 30 degrees of crank rotation is a "mile" and very visible if off by a tooth. As others mentioned, a rubber band works great for keeping the crank pin at TDC.
For me, this is just another case of "run watcha brung". Nothing wrong at all with making pretty shiny overkill tools if that's what floats yer boat.
Old 11-17-2021, 04:34 AM
  #51527
1200SportsterRider
1200SportsterRider's Avatar
Kinda condescending there aren't you. Quote: Nothing wrong at all with making pretty shiny overkill tools if that's what floats yer boat. Making things is fun.
Old 11-17-2021, 04:50 AM
  #51528
Glowgeek
If it came across that way, it was not my intent. I reworded that comment 4 times and you're right, still sounds mean. Sorry.
Old 11-17-2021, 06:38 AM
  #51529
Jesse Open
Jesse Open's Avatar
24 tooth crank pinion:
One tooth error is 15 degrees
Originally Posted by the Wasp
you posted it once, way back.
Jim
That pic was not the finished version with a degree scale on the side.
110% for the run what ya brung
Old 11-17-2021, 06:43 AM
  #51530
Jesse Open
Jesse Open's Avatar
LOL
A lot like "The King of Overkill" tag
You are certainly right Dave.I have been enjoying seeing the stuff you are turning out.
Old 11-17-2021, 09:34 AM
  #51531
1200SportsterRider
Smile
With Lonnie's encouragement I made a brass one.
Old 11-17-2021, 11:55 AM
  #51532
Jesse Open
Jesse Open's Avatar
Brass buffs up real sweet.
I'm overdue to make a new one too.
Learned so much since making that old piece of junk 40 years ago
Old 11-17-2021, 12:21 PM
  #51533
1200SportsterRider
Like this, plus it cuts faster and smoother.
Old 11-17-2021, 01:00 PM
  #51534
Glowgeek
You guys are a hoot.
I like the brass one Dave, came out slick.
Gary, thanks for the correction. Not sure why 30 degrees popped in my head.
Old 11-17-2021, 01:12 PM
  #51535
Jesse Open
Jesse Open's Avatar
LOL
The number was planted by a Svengali.
I didn't expect him to acknowledge.
Old 11-17-2021, 01:14 PM
  #51536
Jesse Open
Jesse Open's Avatar
Nice Dave, Very clean look.
Yes, brass is by far my favorite metal to work with.
Old 11-17-2021, 01:26 PM
  #51537
1200SportsterRider
That thing was hidden inside a piece of brass you sent me.
Old 11-17-2021, 01:28 PM
  #51538
FlyerInOKC
FlyerInOKC's Avatar
I'm glad you were able to find it.
Old 11-17-2021, 02:58 PM
  #51539
Jesse Open
Jesse Open's Avatar
Old 11-17-2021, 08:14 PM
  #51540
the Wasp
(CCTT) Cool Cam Timing Tool
LOL should I post mine again LOL LOL
Jim
Old 11-17-2021, 09:05 PM
  #51541
Jesse Open
Jesse Open's Avatar
Jim
Go for it.
Can you put a motorcycle in the background too!
BTW, PM sent. You should be getting lucky on Monday
Old 11-18-2021, 04:16 AM
  #51542
1200SportsterRider
The Saito big block rocker arm mounts, There is a right and a left rocker arm mount, you have to look close to see the difference, the right one has the upper pushrod seal hole drilled nearly perpendicular to the flat surface. The left seal hole has the hole drilled slightly left and slightly forward. I hope that splains it purty good.
The right rocker arm mount.
The rocker mounts are attached using the two bolts with the red material on them.
Old 11-18-2021, 05:49 AM
  #51543
Jesse Open
Jesse Open's Avatar
The preapplication thread lock is extensively in automotive assembly.
This place is a major supplier worldwide. Located about 8 miles up the road from here.
They supply all the automakers with pre-apply thread lockers.
https://www.precoteusa.com/products
Different grades different colors,
Old 11-18-2021, 08:26 AM
  #51544
1200SportsterRider
Quite a variety, Thanks
Old 11-18-2021, 09:39 AM
  #51545
Jesse Open
Jesse Open's Avatar
No sweat Amigo!
I may drop in on them and see if I can procure "samples"
Old 11-18-2021, 07:26 PM
  #51546
the Wasp
Originally Posted by Jesse Open
Go for it.
there's a joke in there somewhere LOL, but I'm not going to touch it. oops, I think I touched it
Jim
Old 11-18-2021, 09:18 PM
  #51547
Jesse Open
Jesse Open's Avatar
Can't touch it till Monday
I did put a pack of cigarettes in the box just in case you need one.
Oil recirculation. Super clean engine compartment and a much cleaner plane exterior. No power loss and fuel economy improved. So far, I like it. Stay tuned, I will be adding more as I learn more.
Old 11-19-2021, 05:10 AM
  #51548
FlyerInOKC
FlyerInOKC's Avatar
Wow! What a cool idea and you can't beat the execution!
Old 11-19-2021, 06:09 PM
  #51549
the Wasp
Gary, I received the box today, thank you big time !! but don't tell Pete I have more smelly 2st to rebuild and fly, he will be mad at me LOL I will rebuild at-least 1, and I will have to find a plane. I wonder if the latest 40 Gold Cup liner will fit one. that would be nice.
thanks again !!!
Jim
Old 11-19-2021, 09:11 PM
  #51550
Jesse Open
Jesse Open's Avatar
Cool!
There may be yet more on the way.
I figured your place was the perfect home for the "stuff".
Going to sort just a bit , but most, if not all of this is headed your way ........ If you want it.
