Lonnie, thanks for the video. but what was he spraying on it ? a spray glue to stop the air from seeping threw the foam?
Gary, cool, thank you too, but stop talking like that, I'm starting to get anxious LOL
Jim
Jim
The outlet area on you P-40 has exit air dams, that's great, as long as the firewall doesn't block them from extracting hot air. Hard to see, but if your inlet openings don't have baffling directing cooler inlet air to ONLY your cylinder it is easy enough to fix. The 3mm/1/8" thick black sheets of "Craft Foam" they sell at dept stores works well and is CA safe.
I use Balsa, but basically do the same
Bert, it is EVA foam. It's easily cut to irregular shapes with scissors,it's flexible, waterproof, paintable and can be glued with many common adhesives. The melting point is somewhere between 170°f to 213°f so care must be taken.
ETA: Your baffling job on that R5 looks great.
Neither the Cline nor the Iron Bay regulator will allow fuel to flow until there is a demand. They eliminate the need for the 300 rpm rich from peak setting. The engine always thinks the fuel supply is only .75" away. The little 30 with the air bleed carb works perfectly with the either brand.
John at Iron Bay was not certain that the regulator would flow enough fuel for the 2.20, I tied it on a 2.20 and on a Super Tigre 4500. It worked perfectly.
Of the two, Iron Bay and Cline, which one was your favorite?
I guess it would be the Cline because the fuel line attachments are standard sized and the Iron Bay because the fuel line attachments are brass. The Cline elbows can pop off with a little rough handling. They don't pop off from pressure. Difficult choice.
Is that the stuff from Hobby Lobby and Michael's that comes in a 8.5 X 11" sheet? I have used to frame jewelry for the wife.
Still have a few of both?
this guy wants to brake the Moped Land Speed Record. LOL you should see his bike. he cast his own cylinder, makes his own pistons, the last I knew of it he was talking 20,000 RPM. but here, if accurate he is only turning 11,000+. so I don't know what's up. but the subject says "SuperCharged" I think it really means "modified"
Jim
If it ant modified, it's going slower.
Jim
Interesting! What is that "craft foam"?
Attachment 2271405
Attachment 2271406
Attachment 2271408Attachment 2271407
Attachment 2271405
Attachment 2271406
From what I've read wrt the Corsair is that the cowl flaps were manually adjusted and the oil cooler flap was thermostatically controlled. The cowl flaps could be adjusted by the pilot in flight to help control engine temps and fuel efficiency however, in the event of an impending dogfight the flaps were fully opened to prevent overheating. The flaps generally were only fully closed on the ground after a cool down period.
Speaking of cooling issues, I have a Sopwith Baby project yet to build. The designer came up with an interesting feature to address this issue. This model's design has an engine 1/16" plywood cooling duct extending from the top of the firewall to the bottom of the fuselage. The baby is a slow flying and with a detailed dummy engine and a tight cowl the old 1960s .60 engine was an overheat risk, the cooling duct prevented this.
Not like this
Like this.
Over the course of the last couple of years I have converted almost all of my cowled glow aircraft to gassers. Much higher temps to deal with. Inlet baffles and a better way to eject hot air became mandatory. Inlet baffles alone did not solve the overheating issues on a couple of them. Some form of air dam to create a low pressure at the outlet opening fixed all my heat related issues.
These tiny louvered vents are quite handy, and cheap, for creating low pressure at the air outlet(s). They can even be trimmed to use only one louver as an air dam if so desired.
https://www.espritmodel.com/cooling-...-x-16mm-2.aspx
Agreed, you need a little bit of lip on the engine side of the outlet to develop the low pressure area to pull the air away from the engine compartment.
I buy this foam core board at Amazon, it is 24 x 36 x 3/16", I use it to back 1,000 piece puzzles after assembly to make picture I can hang. I plan to build a plane out of it too.
Light but strong.
Light but strong.
It is Foam Core Board, the same as Mudducks were made of. This is my second one, the first was the original 108" version.
