Old 05-21-2022, 03:49 PM
  #52426
Monty Python
Monty Python's Avatar
Jim, if you are fitting a Saito to your shoestring I'd follow Lonnies advice. If it's a two stroke you are using I'd advise you to completely block all intake holes and let it fry in it's own juices
Old 05-21-2022, 03:54 PM
  #52427
Glowgeek
Can always count on your infinite wisdom, Pete.
Old 05-21-2022, 05:17 PM
  #52428
the Wasp
Lonnie, I plan to do all that, I bought the foam for that. but the air inlet is tiny. because it's made for a 40 size engine.
Pete, I too would love to put a 4st in it, but if I did I would have to cut the cowl up a lot, and the cylinder head would stick out over an inch.
Old 05-21-2022, 05:26 PM
  #52429
Glowgeek
Jim, looks like you can trim the inlet opening a little without affecting the appearance too much. A little trimming makes a big difference in the sq. in. area. Might be ok as is with baffeling and a low pressure exit opening (s).
Old 05-21-2022, 09:09 PM
  #52430
FlyerInOKC
FlyerInOKC's Avatar
If the opening bothers you glue in some black screen wire, the air will pass thru but the black fools the eye..
Old 05-22-2022, 04:34 AM
  #52431
Glowgeek
A course screen might be ok but I wouldn't use the fine screen like that used for residential windows. That type of screen blocks a lot of airflow. Next time it's windy outside hold up one of your window screens, you'll get the idea pretty quick just how hard it is for air to pass through.
Old 05-22-2022, 02:28 PM
  #52432
bldrumsVa
Red face Well ...I'm back after taking a long RC break
Unfortunately I can not log back on to my original account. The old email address is dead and I have not been able to get a reply from RC U admin.
bldrums 2002 to 2012 lots of good stuff on my account !!
Member Rivanna RCC 1979 to date !!
Anyway its a new day and definately a new era in technology ...electric is okay but I still love the Saitos and that oil LOL @@!!
Old 05-22-2022, 10:26 PM
  #52433
the Wasp
Lonnie. I flew it one whole summer without a cowl. one of the guys at the field told me with a smile that I "just had to put one on it because it didn't look good without one". LOL he was correct.
you know, when some one tells you the air intake size doesn't matter much, it's only the hot air exit that matters.. it kind-a sticks questions in your head.
Jim
Old 05-22-2022, 10:34 PM
  #52434
the Wasp
Mike. only the opening's small size bothers me, it'is made for a 40 size engine, my engine is the OS 70sz Heli engine with the over size Heli carb, it should be turning around 13 grand with an APC 11x9.
Jim
Old 05-23-2022, 04:28 AM
  #52435
FlyerInOKC
FlyerInOKC's Avatar
Good luck Jim! I know you will get it figured out.
Old 05-23-2022, 04:09 PM
  #52436
Monty Python
Jim
That's because it's true Jim. You need a low pressure area to "suck" air out of the cowl in flight. Plenty of info available about that and easy to understand.
Old 05-23-2022, 04:33 PM
  #52437
Glowgeek
He said suck.......eh,eh,eh,eh
Old 05-23-2022, 06:25 PM
  #52438
the Wasp
I forgot to tell you guys that my Heli parts went out Saturday. the money I got will go for my new rolling toolbox.
Jim
Old 05-26-2022, 11:39 AM
  #52439
the Wasp
guys, I like this hobby foam. it's cool because it sands great with 150 grit. it would sand faster with 100 grit but the 150 gives a good finish. you can file it too but it can get a bit raggedy with a wood file.
so I am working on the ShoeString cowl and I have to fit the foam inside the cowl's airduct. this will keep the air closer to the top of the engines head, if the foam wasn't add there would be a lot of wanted air passing by the top of the head. I'l get photos when done.
thanks guys for telling about the foam!
Jim
Old 05-28-2022, 03:44 AM
  #52440
1200SportsterRider
1200SportsterRider's Avatar
Jim
Jim, I'm going to dig out some discarded Saito cams and maybe we can discuss normal wear, over revving wear and loose lash wear.
Old 05-28-2022, 03:48 AM
  #52441
Glowgeek
Welcome back Dave. How'd the fish'n trip go?
Old 05-28-2022, 08:35 AM
  #52442
the Wasp
Dave, that would be great!
Fishing Trip? how did I miss that news
Jim
Old 05-29-2022, 02:26 AM
  #52443
1200SportsterRider
It was great, but cold, 51 degrees most mornings. We caught our limit of Crappie most days. In the rain sometimes. Going 55 mph in a big Lund is right chilly.
I am way behind on lawn mowing, it rained here too. I didn't get to the cams yet, maybe today.
Old 05-30-2022, 03:53 AM
  #52444
1200SportsterRider
Big block cams
Cam # 1 barely worn
Cams 2 & 3 worn out
Cams 4 & 5 like new.
A program on my Computer called One Drive will not let pictures upload to RCU.
Old 05-30-2022, 04:57 AM
  #52445
FlyerInOKC
FlyerInOKC's Avatar
One Drive is a back up drive in the cloud. You will have to move them to the pictures folder to upload them. I don't use One Drive I think its a pain somewhere below the belt!
Old 05-30-2022, 05:31 AM
  #52446
Jesse Open
Jesse Open's Avatar
One Drive must be a lot like the Amazon photo storage or Apple's iCloud. Like they take your photos and then make it difficult for you to use them. Meantime, they now have pics of you, your home, family and friends, places you have been, things you have done. Along with much information about when and where those pics were taken.
Dave,
Hope you can get those pics downloaded and posted. Would be interesting to see them.
Old 05-30-2022, 06:19 AM
  #52447
acdii
Dave,
Yep
Like Facebook.
Old 05-31-2022, 03:13 PM
  #52448
Glowgeek
Big block cams
Cam # 1 barely worn
Cams 2 & 3 worn out
Still no luck?
Old 06-01-2022, 02:09 AM
  #52449
1200SportsterRider
Still working on it.. There seems to be several way to shut down/remove onedrive but no lucck.
Old 06-01-2022, 04:30 AM
  #52450
FlyerInOKC
FlyerInOKC's Avatar
Have you opened it photo and saved them to the computer? I usually store them on the "C" drive to solve this problem. I made sure to deactivate One Drive on my new laptop.
