Official Tamiya TT-01 Thread
#5276
#5277
Read through and must recommend this website: http://www.cheapbatterypacks.com/main.asp?sid=1579631
I haven't ordered fromn there yet but i have heard good reviews about them and they are very cheap.
#5278
#5281
AB, AUSTRALIA
HAHAHAHAHAHAHA i saw ur mudda last night i=an wen she jump 4 joy she got stuck
ur mudda so fat she 150kg
cheyou mudda bad in bed last night
ddddDOUBLE KILL!!!!!!![sm=punching.gif]
#5282
Hey i got a Onyx Charger for about $65.00 Shipped the same model you have used so i saved my self some bucks...Also bought the balancer and lipo pack 2s 2200mah so that should be fun for now.
I am so enticed to buy the 9tezrun but lets see what happens.
Thanks Slim i will try to post pics tonight of the ride.
#5283
ORIGINAL: boosteda4tq
Hey i got a Onyx Charger for about $65.00 Shipped the same model you have used so i saved my self some bucks...now what Lipo Battery should i get to run the 9tezrun Motor?
#5284
Today I swapped out the stock pinion and spur for a 22/58, and i got a metal motor mount. As soon as I got the parts in the gears seemed a bit loose. I followed the instructions for what position to mount the motor, but they didn't quite fit. The 23t pinion fit a bit better, I thought it was going to work, but of course it didn't. What can I do to make my gears mesh right? I made sure the gears were right for my car... Thanks guys!
#5286
Even the tamiya 22t doesn't mesh up with the tamiya 58t spur... I tried mounting the engine in the three different positions, none worked... The gears mesh enough to work, but as soon as i put the car on the ground it just grinds... Any advice?
#5292
hey guys, im getting back into the rc thing and just got a tt-01 and am thrilled about it i want to put my old superstock motor in but i want to know if there is a site with a diagrame on how to rebuild the motor and maybe some tips on what to do to restore it.
thanks guys
thanks guys
#5293
Sorry to be a bother again... I got a tazer 12t esc, from recommendations of my LHS and from you guys... but it only have one cable, out to the receiver. my receiver, a futaba, has a separate power in... so my esc doesn't power it... are there any solutions to this, or do i need to return it? THanks guys!
#5294
Hey guys, im looking round for a cheap touring car i can just mess about with, so looking for a tt01 roller
i was just wondering what i need to handle brushless power. I've got the 13t ezrun combo in a truck and might try it out in the tt01 if i get one. I'm also getting lipo's soon, so will tt01 handle lipo brushess aswell ?
I've come across this offer on another forum.. all i've got is a pic for you guys, but from looking at it do you think it's worth around £30 for just roller (comes with shell, servo aswell.)
And last question, if i did get that tt01 shown in the pic, will most of the common sized body shells fit on it from other onroad 1/10 cars
Thanks![Smile](images/smilies/smile.gif)
#5295
Bargain for 30 notes m8
the kit parts would cost you more for a roller
Yeah any 190mm shells will fit straight on for 200mm you will need offset wheels to fill out the wheel archies
the TT can handle BL/lipo just keep an eye on temps and gear from there i went from 19/61 gearing to 23/58 and left it at that on a 5700 setup.
#5296
Hi all,
I playing TT-01D for Touring
What should i need to Hop-up to improve the car ?
i already Hop-up
<ul>[*]Gear (25/55)[*]Ball Bearing[*]CVA Shock[*]<font color="#00265e">Aluminium Drive Shaft
</font>[/list]<font color="#00265e">
DO the Ball Diff and the Steering Set make a big diff in handling? ( recommended?)</font>
i already Hop-up
#5298
Recieved the brushless system and installed it but to set it up i need a futaba radio set. What radio set do you use slim?
#5299
ORIGINAL: SpeedstaBrad
Recieved the brushless system and installed it but to set it up i needa futaba radio set. What radio set do you use slim?
