Old 10-25-2022, 01:21 PM
  #53151
1200SportsterRider
1200SportsterRider's Avatar
Yeah-----Well
Old 10-25-2022, 01:26 PM
  #53152
1200SportsterRider
The compression ratio of my E 180 is 9.56 to, that's not exactly low.
Old 10-27-2022, 01:12 PM
  #53153
Glowgeek
I recently got a great deal on a "bench run only" 180GK. I could tell it had been run a little more than claimed and cleaned up. Turns out it had brand new bearings and wouldn't run, just spat the prop. Yep, cam timing was off. Hee hee. I love it when people sell out cheap when their engine won't run after an overhaul.
Old 10-28-2022, 02:22 AM
  #53154
1200SportsterRider
What initial on the right lug, if I may ask, Thanks
Old 10-28-2022, 03:36 AM
  #53155
Glowgeek
Marked "l".
Any significant changes to the 180 throughout production?
Old 10-28-2022, 04:13 AM
  #53156
1200SportsterRider
It does not appear so, interestingly, Clarence says that the valve timing of the 180 is a little, (wilder) in that the overlap period is 80 degrees, whereas the 150's overlap is 65 degrees. Replacement parts lists all say the 120 through 220 cams are all the same. Hmmmm.
Old 10-28-2022, 04:51 AM
  #53157
Jesse Open
Jesse Open's Avatar
Being one of the latest big block Saitos, the FA-180 has had very few if any revisions that I am aware of. The FA-120 on the other hand has seen a mryiad of changes. Cam specs is one . The cherished "Fat head", the dual pluggers, several intake tube variations.Even the muffler variety. They could be a collector's favorite subject.
Old 10-28-2022, 05:32 AM
  #53158
daniel711
Default goos idea the Saito club
Dears, i have a 120s, more than 10 years working in my CAP 232 from TNT models from Argentina, a few days ago I desassemble, for change gasquets and ball bearings, mow i working again like new brand.
my others engines are gas engines, but glow i have only my loved Saito.
Regards an sorry my english
Old 10-28-2022, 06:13 AM
  #53159
FlyerInOKC
FlyerInOKC's Avatar
Nice to hear from you Daniel! Welcome!
Old 10-29-2022, 01:16 PM
  #53160
Hyjinx
Hey Saito heads.
Guilt free porn, LoL
Old 10-30-2022, 03:07 AM
  #53161
1200SportsterRider
Originally Posted by Glowgeek
Sorry to hear that. Morgans has been a trusted fuel for many years. Hopefully the tradition will carry on with the family.
Not by everybody.
The props are hung up somewhere, I hope the USPS hasn't smashed up the box. They were supposed to arrive today.
Old 10-30-2022, 05:10 AM
  #53162
Glowgeek
Not by everybody.
Yeah......well.
I've had very good luck with the USPS and UPS. If it were FedEx, I'd be worried. I'm pretty sure they take turns punting packages.
I had a female Fedex driver knock on my door last week. "I can't make it up your driveway", she said. Lol, my gravel is fairly steep but nobody else has trouble coming up here. She wanted me to guide her as she backed down the hill. It became very apparent why she had trouble. The van had an extended height top, subframe connectors and 2 wheel drive w/ traction control. As she backed down my undulating drive one wheel after the other would lift off the ground. When she finally got the thing turned around down by my shop and went to leave the traction control almost kept her from climbing the little hill there. It would slip and stop, slip and stop.......
Those rigs have no business being used around these parts.
Old 10-30-2022, 06:42 AM
  #53163
Jesse Open
Jesse Open's Avatar
Yessir,
During periods when I was out of home brew fuel I often picked up a case or two of Morgan's "Omega" fuel. Always a very reliable fuel.
I still refer new fliers to our local hobby shop and Omega fuel.
Old 10-30-2022, 01:52 PM
  #53164
Glowgeek
Default Saito 220 mushy compression
Tore down the low time 220 for inspection. Compression was mushy and it's weak on peak power.
The ring gap (crater) measures .009" anywhere up and down the cylinder bore. It should be between .005"-.006" for a 38mm bore. This is not the reason for the mushy compression or power loss however.
The bore measures 38 mm, piston measures 37.96mm. Both are very round but the ring is worn A LOT near the gap and unevenly worn everywhere else. In fact there are areas of the ring which appear to make no contact with the cylinder at all. The ring is simply not round. RJM ring on order!
The carbon buildup is from an improperly working electronic gas conversion setup. That problem has been resolved. The cylinder and valves will be cleaned up before reassembly.
Linkan2 (10-31-2022)
Old 10-31-2022, 01:41 AM
  #53165
1200SportsterRider
And I have an RJM ring coming for my little 30.
Old 10-31-2022, 05:11 AM
  #53166
Jesse Open
Jesse Open's Avatar
Dave,
Ever thought of making your own?
...Rings that is.
Old 10-31-2022, 12:42 PM
  #53167
Glowgeek
Originally Posted by Jesse Open
Dave,
...Rings that is.
Like this?
Make piston rings easily
Old 10-31-2022, 02:28 PM
  #53168
Jesse Open
Jesse Open's Avatar
That is a good article. There are countless variations but his methods should produce very good rings.
Old 11-01-2022, 09:04 AM
  #53169
Hyjinx
Not by everybody.
Jeepers. Never had a hitch with Morgan. I get it at my LHS since I started in the hobby. Talked to the blender/chemist twice on the phone. They always answer and even returned A call. I blend their 30 percent heli with methanol and Klotz. Used almost everything they make. I was sad to read that bad news about the owner. Here is my blend in action last Saturday. To bad you can't smell it on the video lol.
Old 11-01-2022, 09:42 AM
  #53170
Glowgeek
Nice flight Aaron and a nice Claude.
Old 11-01-2022, 09:43 AM
  #53171
Jesse Open
Jesse Open's Avatar
Good one Aaron! Certainly a very fine flying plane that also happens to look good too.
Morgan's fuel has always been very popular in Michigan. Of course Cool Power gets a pass here, in favor of their Omega fuel.
Old 11-01-2022, 09:49 AM
  #53172
Glowgeek
Here, for 4 strokes, it's Omega and Cool Power mixed 50/50. Essentially Omega with reduced castor content. Works great, valve lash takes a looooong time to open up. I have never used straight Coolpower so can't remark.
Old 11-01-2022, 10:11 AM
  #53173
1200SportsterRider
I did not say that quite right, I only ever owned one jug of Morgan's fuel, a jug of 20/20 for my YS engines.
Old 11-01-2022, 10:26 AM
  #53174
Glowgeek
Any issue you had with the YS engines probably wasn't fuel related.
YS engines are the best thing since sliced bread, ya know? That question is rhetorical of course.
Old 11-01-2022, 11:03 AM
  #53175
Hyjinx
Based on who and where it came to me It has become one of the favorite planes I have ever flown and owned.
