Old 12-07-2022, 04:00 AM
  #53351
1200SportsterRider
1200SportsterRider's Avatar
I wouldn't mind getting hold of the Bolly Clubman props.
Old 12-07-2022, 04:36 AM
  #53352
Jesse Open
Jesse Open's Avatar
But not while they are running
Old 12-07-2022, 04:39 AM
  #53353
1200SportsterRider
True, that earned me 27 stitches one time. An OS 62-v turning an APC 13 x 6 at 6,000 rpm.
Old 12-07-2022, 06:09 AM
  #53354
Glowgeek
Yikes!
Old 12-07-2022, 06:47 AM
  #53355
FlyerInOKC
FlyerInOKC's Avatar
Look on the brite side, you didn't pickup a new nickname like 3 Finger!
Old 12-07-2022, 08:22 AM
  #53356
1200SportsterRider
It didn't even stall the OS 62-v, my wife made me burn all my APC props, of which I had few anyway. Two numb fingered Dave would be more accurate.
Old 12-07-2022, 08:59 AM
  #53357
Glowgeek
"Lonnie 3-3/4 fingers" is my nickname. Don't ask. All I can say is that when you're young and drunk (reads stupid), you shouldn't work on cars.
Old 12-07-2022, 04:21 PM
  #53358
Jesse Open
Jesse Open's Avatar
Seen plenty younger and sober guys I wouldn't let near my car either
Old 12-07-2022, 04:29 PM
  #53359
FlyerInOKC
FlyerInOKC's Avatar
Old 12-12-2022, 04:13 AM
  #53360
1200SportsterRider
Lonnie, I'm going to fire this 180 prop driver your way to see if it will help your slippage problem. Lets hope, also pictured are the 33.5mm FA 30-s pushrods.
Old 12-12-2022, 04:17 AM
  #53361
Glowgeek
Thanks Dave, you're the greatest!
Old 12-13-2022, 06:17 AM
  #53362
Jesse Open
Jesse Open's Avatar
Anybody looking for a good deal on a tach. This one is in great condition.
Old 12-13-2022, 06:58 AM
  #53363
Glowgeek
That is a good deal. I absolutely love mine, excellent range and accuracy. Due to its size and rarity I use it for bench testing only, don't want it to bang around in my flight box. Elcheapo digitals are good enough for field use. Thanks again for sending it my way, Gary.
Old 12-13-2022, 08:17 AM
  #53364
1200SportsterRider
I've had one of those for a long time and a matching Volt master II.
Old 12-13-2022, 02:03 PM
  #53365
Jesse Open
Jesse Open's Avatar
Really miss that company. They made fine kits and as a result many modelers gained some experience in the electronics aspects of our hobby.
Old 12-14-2022, 04:03 AM
  #53366
1200SportsterRider
I also have this guy, one of the handiest tools I have.
Old 12-14-2022, 12:50 PM
  #53367
rams
After soaking in the heated antifreeze, what is the next step? Do you rinse off the antifreeze? If so what do you use to rinse with? Do you need to apply a lubricant? Jim Nordly
Old 12-14-2022, 01:02 PM
  #53368
Glowgeek
Scrub the parts while still hot/warm with stiff plastic bristle brushes. Fingernail brushes, tooth brushes, gun cleaning brushes etc work good. I use denatured alcohol while brushing. Oiling after cleaning is a good idea.
Old 12-14-2022, 03:47 PM
  #53369
Jesse Open
Jesse Open's Avatar
About the same here but I scrub with Dawn Powersolve dish detergent and water.
Old 12-14-2022, 07:19 PM
  #53370
the Wasp
I have used both WD and rubbing alcohol. it's a dirty job but someone has got to do it.. if it comes out gray remove the Antifreeze and let it set a little while with WD on it, 10 minutes should make it shine.
Jim
Old 12-14-2022, 08:18 PM
  #53371
the Wasp
hey guys, check out this machinist
Jim
Old 12-14-2022, 09:13 PM
  #53372
Jesse Open
Jesse Open's Avatar
Yeah, they used to sell both kits and plans for those shapers at the machinist hobby expos.
Several fellows at work built them.
The "Iron Grasshopper" is what we called shapers. Used to be on of my favorite machines to operate. We had a 24" stroke Cleveland at Parts Fab. With a carefully sharpened bit, a good operator could resurface a cylinder head and get an excellent sealing surface.
Those blue hot chips had a knack for finding any opening in your clothes that leads to bare skin!
Old 12-16-2022, 05:36 AM
  #53373
Jesse Open
Jesse Open's Avatar
Here is one:
https://www.pmmodelengines.com/shop/...nk-shaper-kit/
Nice project fun to watch too.
Old 12-17-2022, 03:53 PM
  #53374
Monty Python
Monty Python's Avatar
Well, here's a Saito story with a sting in the tail. Since before the Ukraine/Russia war and now, hundreds of " Sea Eagle " Orlan 10 UAV drones have been guiding Russian shelling of Ukrainian targets. Part of the illegal supply of advanced US chip technology comes from South East Florida house. The report states the drone is powered by Saito Seisakusho engines, big sales for Saito, wonder which supplier was involved.
Old 12-17-2022, 05:25 PM
  #53375
Monty Python
Update. Just watched a vid called " what can the Orlan-10 do ".
Wingspan: 3mtrs.
Length: 2mtrs.
Weights: 12.5 kgs min.
16.5 kgs AUW.
Cruising speed between 115 and 150 kph.
Endurance of up to 18 hours.
Saito garbage can mufflers visible on either side of cowl, engine seems to have a very soft rubber mounting and is self starting.
Black coarse pitch prop appears to be approx 14 to 16 inch dia.
Picture of crashed drone without cowl shows petrol Saito flat twin with small oil hole drilled in pushrod covers??
Anyone like to guess how big the twin is and who supplied the hundreds of engines, may even be thousands, good business for the supplier.
