I never availed myself of his services but I do have a Webra 91 that he supposedly modified. It has/had a pressure tap in the left mounting lug, (to run a Perry pump), if the ports are modified, it's not enough to be visible.
Well, I had a serious cave in this AM, I ordered a Robin Hood 80 from Old School Model Works, I've wanted one for a long time. i am thinking it will wear a Saito 82-B. It can take up to a 1.50, but I sure can't see that.
https://www.oldschoolmodels.com/rh80.htm
Robin Hood 80, it looks to be a fun build.
Specifications:
Wingspan: 80 inchesWing Area: 1120 sq inches
Length (airframe only): 58 inches
Weight: 4.5 lbs. (framed), 8-10 lbs.(rtf)
Radio: 4 channel system:
Power:
• Glow (.90-.1.50 engine, 8-12 oz. ounce tank, fuel tubing)
• Gas (20cc engine, 8-12 oz. ounce tank, fuel tubing)
An 82 4-stroke on an 8-9 lb plane...talk about flying on the wing.
My Saito 125-B wins with the CH Ignition, shown below turning a MA 16 x 6 Classic at 9,025 rpm.
Smoke from 3 clicks rich at end of break in.
Good chjoice Dave,
I had one of the original Robin Hood 25s, sold by World engines back around 1982. Powered it with a Super Tigre G20 .23. Covered two tone with Monokote burgundy and cream. A very nice plane and as I recall it built up quick. The kit was around twenty bucks. I wouldn't mind building another. Woody wagon covering ? Why not?
That CDI ignited FA-125B should be very similar to the methanol fueled FG-20s, another fine choice.
It is somewhat based on the Curtiss Robin which was powered by either a straight six or a radial. W8YE had one, (from World Engines), that was designed around a Maloney 100.
The larger Robin Hood came quite a bit later than the 25 version. The original was a popular plane. Mahoney likely figured a big one would sell well and at the same time, help sell a few of those Mahoney engines!
The real Curtiss Robin Hood set some impressive flight duration records in it's time.
Should actually fly very well "on the wing".
I had three Maloney 125's at one time. they did exactly as he claimed turning a 15 x 8 at 7,200 rpm, my Davis Diesel converted one would turn a 15 x 8 three blade at exactly the same 7,200 rpm.
I sure did, I never bought a 100 though, here is a shot of my Diesel conversion. The muffler is a J-Tec Snuffler
My Maloney 125 with a Diesel head by A. J. Coholic of Canada, Mr. Davis later found one he'd lost track of.
J-Tec Snuffler
J-Tec Snuffler
My experience with the 120r3 was that it was just a little stronger than an 82. I have been trying to find a scale airframe to hang that engine on but so far I have not found anything. Is anyone out there flying something they are happy with on the 120r3?
How about a Piper Cub J3P? It used a 3 cylinder radial and there are a ton of kits out there which you could adapt.
I have an FA 90R3 on a Flair Puppeteer. Great sound and scale power levels.
jamesroutledge (01-10-2023)
Yes, you can strip and shorten the nose on most any plane. Gain weight and lose space is a part of the trade-off.
