Old 04-03-2023, 02:26 AM
  #53676
1200SportsterRider
1200SportsterRider's Avatar
Thanks Jim, I borrowed the idea from the Saito 60 twin carb. It's fun turning an idea into a useful creation.
Old 04-03-2023, 08:27 AM
  #53677
Jesse Open
Jesse Open's Avatar
Originally Posted by the Wasp
any of you guys hear of/or seen those big new hornets coming up from the south? I hear their stings are so powerful they can melt rubber!
Jim
Actually they aren't agressive as you might think. IIRC, their venom is about the same as a regular honeybee
.The biilggest threat thry pose is to agriculture.
Didn't take the do-gooderz long the have the "Asian Hornet" name changed!!
Speaking of \"Hornets"..... Here is my DeHavilland Hornet. 79" span, powered by a pair of Saito FA-56 Golden Knights .
SpartySam (04-09-2023)
Old 04-04-2023, 02:55 AM
  #53678
1200SportsterRider
That is a great looking plane, I'll bet that it howls on a fly by.
Old 04-04-2023, 07:49 AM
  #53679
Captcrunch44
That reminds me I have a duelist in the box
sounds like fun
Old 04-04-2023, 08:19 AM
  #53680
FlyerInOKC
FlyerInOKC's Avatar
sounds like fun
Isn't it amazing how you can forget you have a project? Reminds me I need to look for a suitcase D1 I started.
Old 04-04-2023, 10:45 AM
  #53681
the Wasp
sounds like fun
Capt. who are you and where you been?
^LOL^ it's good to see you hear, back yapping with us again! we missed you.
BTW, thanks to Lonnie I got another FA91 cylinder for the engine you gave me. and I tell you it's one fine cylinder with low run time. it will be the first engine I run this year.
as for the cylinder that was on the engine, I found that the valve seat was not in-line with the guide. I found that the larger100 valve has the same length stem. so I started to make a new seat with a 100 valve and seating compound. it worked out well, but the guide alinement was so far off the new seat opened up into the port. BUT I do believe if I had a 91 cylinder that has a good guide/seat alinement it will be possible to make a new seat for the larger 100 valve. I would love to try that.
yes yes I am in a great mood. Popa has a new grandbaby girl just 2 weeks old. and I got to see her today.
any hoo. it's great to see you reply. I hope all is well for you!
Jim
Old 04-04-2023, 11:29 AM
  #53682
Jesse Open
Jesse Open's Avatar
Ah-ha, that old "A bird in the hand" adage!
Is a 20 year old scratch built Hornet hanging ffom the ceiling worth two unbuilt kits in the boxes?
Get er built before the tyrant outlaws them!
Old 04-06-2023, 10:10 AM
  #53683
1200SportsterRider
good going Dave!
Jim
The tiny little servo has 18.3 oz. in. of torque 6.6 volts, it operates the Saito 125 throttle as if it were nothing. You have to listen really closely to hear them, I like that. The phone just doesn't do good close up work.
The throttle, elevator and rudder all all set up programmed into the green radio.
Old 04-06-2023, 06:42 PM
  #53684
triumphman49
My Feedback: (149)
"How much throw do you need for throttle" was my first thought, but I suppose it has some linkage up front. Nice build
Old 04-07-2023, 02:25 AM
  #53685
1200SportsterRider
Thanks, I'll have to get a bright light to check that as a lot of the carb barrel travel is wasted as it goes way beyond where the throttle is fully closed. I'll scope it out though.
PS, I made an adapter to move the throttle arm outward so the throttle rod would not conflict with the fuel tank.
Last edited by 1200SportsterRider; 04-07-2023 at 02:50 AM. Reason: Add content and image.
jamesroutledge (04-10-2023)
Old 04-07-2023, 04:28 AM
  #53686
FlyerInOKC
FlyerInOKC's Avatar
I think the adapter was a great idea and it looks great!
Old 04-07-2023, 05:53 AM
  #53687
1200SportsterRider
Thanks Flyer.
Somehow most of my post didn't get here, the throttle arm movement for open 1/32" to fully open is 7/8", I'm sorry, the camera didn't catch that either.
The tiny brass wire, "gauge" is 1/32" for the idle point.
The travel to fully open 7/8"
Lots of pretty lights on the new JR equipment when everything is right.
Old 04-07-2023, 06:16 PM
  #53688
the Wasp
that servo looks tinny. but if it works it works lighter
Jim
Old 04-08-2023, 02:29 AM
  #53689
1200SportsterRider
With that long arm on it moves the throttle the required 7/8" as if it were made for it. Although it could very turn out that the 1/32" I used as a guess on the idle opening may well end up being about 1/16". It moves the throttle from full stop closed to full stop open quite easily.
Old 04-08-2023, 07:57 AM
  #53690
Hyjinx
Speaking of "Hornets"..... Here is my DeHavilland Hornet. 79" span, powered by a pair of Saito FA-56 Golden Knights .
Master builder file lol
Old 04-08-2023, 10:00 AM
  #53691
Jesse Open
Jesse Open's Avatar
Yessir
Been tieing them like that too.
Dave was the best! Good to hear from you neighbor!
Old 04-08-2023, 10:21 AM
  #53692
Hyjinx
Yessir
Been tieing them like that for years
Same Buddy. The saito on that build has well over a hunnerd flights on it now in my care.. literally never touched the needle extension rod since Brian's maiden he put unnoticeable thru the one peice balsa cowl. Always my fuel mix. Any weather any time. I have replaces every servo. None twice.
Old 04-08-2023, 01:38 PM
  #53693
1200SportsterRider
Lonnie, I may be able to fix you up, I have two pushrods that are 61.7? mm long, the camera angle created an optical illusion.
Old 04-08-2023, 01:45 PM
  #53694
Glowgeek
Saved by the Dave.........again. Give me a chance to assemble the fatty, to make sure 61.7mm is indeed the correct length.
Old 04-08-2023, 03:50 PM
  #53695
1200SportsterRider
When you get the right combination of lifters and pushrods let me know the length of the lifters and I'll send any that match..
Old 04-09-2023, 08:23 AM
  #53696
Jesse Open
Jesse Open's Avatar
Even Dave's Saitos that sat for twenty years have started right up and flown like the last flight was last week!
For some reason, hd did skrimp on servos and batteries. Sure miss thd guy.
Getting to be a real shortage of creative builders.
Old 04-09-2023, 11:39 AM
  #53697
SpartySam
Wow! Great pic!
Old 04-09-2023, 11:53 AM
  #53698
SpartySam
Default Saito collection
I saw some folks had listed their Saito collections and here's mine:
FA-82GK 22 years old, my first one. Has powered 4 airplanes. Currently taking a bath but powering a Spacewalker 82in WS.
FA-45 - bought brand new in the 80s. Still in original box. Never used.
FA-62B - Powering the Goldberg Tiger 2.
FA-125a Powering the big Sig Rascal.
Old 04-09-2023, 03:10 PM
  #53699
Glowgeek
Nice collection Sam. Hard to beat that 4 stroke growl, isn't it?
Old 04-09-2023, 04:51 PM
  #53700
1200SportsterRider
It sounds much better when they suck, squeeze, bang and blow separately. I am going fly my "66" on an LT 40 midweek this week.
