The Making of a Shelf Queen - Lunchboxer's F103GT Courage
#526
I am sure now that TEX will be ordering a bunch of these Novak glitch buster capacitors... LOL!!
#527
IL
ORIGINAL: Lunchboxer
#528
Any open slot will be okay.. they are all connected together... (the power side of the connection) That's why you can connect a fan, LED light, etc. to any open slot...
#530
So put one in your TC4 FT (as it is using the high power Novak), put one in your semi.. and maybe get a couple for spares.. hee hee.. for your next BL setup..
#531
IL
#532
Different use.. the cap that came w/ the ESC provides the power reserve for the motor.. (give you more punch)..
The glitch buster is a cap for the BEC / receiver power...
ORIGINAL: []TEX[]
The novak already has a cap
#533
IL
I know what you are saying though, not sure what it will help though. It doesn;t glitch.
#534
Hee hee.. well, the glitch buster thing is really designed for a car that has a high power system.. that the sudden pull from the motor system might bring the BEC / receiver voltage down too much for the control system to work properly..
So I guess what I was trying to say is, put one in your TC4 FT, as it is the car that has a high power Novak system..
How's that?!?!
#535
IL
So I guess what I was trying to say is, put one in your TC4 FT, as it is the car that has a high drain system..
How's that?!?!
How's that?!?!
#538
Because of the body post relo kit, the nice blue Tamiya heatsink won't fit..
Need some lower heatsink.. but man, check out the tight space!
#540
Yup.. did a test fit.. it was pretty darn close..
Just to be sure.. I machined 2 of the fins down a little bit.. NICE!!
#544
Interesting headlight setup..
You mask them out.. and then, use double sided tape to tape them from inside w/ stickers on them..
I guess that's just a way to prevent the stickers from rubbing off?! Hmm..
#545
Not done w/ the stickers yet.. argh.. a lot of stickers!!!
Looks good, though.. this will be the shelf queen shell for sure!
#546
Another view.. used 6mm offset wheel this time to push wheel all the way out to the body...
I think it looks good.. maybe add some stability?!
#547
IL
#548
Not sure.. I didn't see any optional LED kits listed on the body kit.. who knows..
I guess it does give it a look like it has a clear lens over the light..
I don't think it is for body dimension as the body is molded with the light sticking up already..
#549
bumpy with some good news. picked up a f103 off ebay for 30 bucks. now i just need to find a sexy body for it
#550
IL
ORIGINAL: mindwreck
Nice catch!
