Official Tamiya TT-01 Thread
#5526
oh ok. the battery holder looks 3 racing to me.
how much heaver is the car with all the alloy upgrades.
for what i wana do weight is my enermy...
#5527
ORIGINAL: d.k.v
#5528
im looking to use min to test my new land speed body im desgining.
so i need to rebuild my car lighter and more powerfull then ever
#5533
This is the 3racing chasis for the TT-01. It gives me the ability to run a gearing of 55t Spur, 35t Pinion which gives me a ratio of 4.09. As you can see I also have the stabilizer set, center brace, I am rocking a front one-way and rear ball diff. I am able to do camber and droop adjustments with this chasis and I am running a Speed Passion LPF Brushless esc with a Trinity Pulse 17.5 motor for RCGT Class Oil filled shocks all the way around as well.
#5534
"im looking to use min to test my new land speed body im desgining.
so i need to rebuild my car lighter and more powerfull then ever "
get a different chassis. the tt is a good basher, high speed, not so good.
just popped off my front sway bar and my oh my does it lock better, i am suspecting body roll on this chassis is a good thing.....
#5535
cydog510 im just going to test the basics of the body. eg stablity.. then im getting a ta-05 ifs
Btw the body is going to be custom made by me once the tt-01 is rebuilt
dfiantii 35t pinion what do u use thi thing 4?
#5536
I am going to start in an RCGT Class. For my brushless motor I need to get down to a 3.8 gearing. Because neither Tamiya or HPI make a pinion bigger than 35t. I can only get down to a 4.0 ration.
#5538
I have actually had no problem with acceleration. I will let you know more when I actually get it to the track and do testing. On the street in front of my house its very squirrely. I can see the difference in speed in it also from what I had in there before.
#5540
i was out this evening, racing about, put on the bald radials for some high speed drifting, half way through a corner the rear wheel spits out and starts rolling off.... turns a\out the axle clean sheered off, not a worry as i have plenty, but lost the pin, oh well, one extra, but gotta be careful now....
on a side note, i just received the carbon bumper stay (yes i know, just for looks) the rear stabilizer set, aluminum arm holders and aspacer set from a seller in HK, i bought a small item from him off ebay some time ago and recieved a note with it, pictured below, so i thought i would go for it, could get burned, but what the hell, 15% off AND free shipping. so i tried it and he is legit. http://www.rc-mall.net/productlist_a...miya&type=tt01.
#5542
You nedd one of these:
http://www.etamiya.com/shop/tamiya-9...01-p-5045.html
http://www.etamiya.com/shop/tamiya-9...01-p-5046.html
Each has 1 set of bevel gears for diff.
#5544
Alright I got my TT01 last night (the red alu one I posted on last page (215)). Drove it some with the Drift tyres on, but decided fast to change to my HPI X-Pattern tyres... Damnit this machine is moving compared to my E10
There is a Yokomo Pro Stock 23T in it now, I'm not really sure if it will preform better with my Venom 13T (have to change the ESC too obviously), any comments?
#5545
post some pics man! put the 13turn in, serious, you think it goes now, pop that 13t in and it'll really fly. i suggest getting yourself a drive shaft set, you'll definately bend axles at high speed and you can find it on ebay for $3-$4, well worth it.
also mathew, you can get that bevel set on ebay for $6 shipped.
#5546
Will get some pics maybe tomorrow, I have most of the alu upgrades so that won't be a problem... I think next upgrade I'm getting is the chassis
I'll try to fit the Venom motor in tomorrow then
#5547
Semi bad news guys. I think I broke something in my steering, a part that is close to the servo... is there an upgradeable part for this that holds better, or do I have to order a new plastic one? ![Smile](images/smilies/smile.gif)
It didn't really look broken at first, and if I snap it back it stays there for a little bit. However when I compare to the picture, I see it's deffo broken. Someone had the same problem?
![](http://baev.sharkbait.se/rc/servothingy.jpg)
#5549
Ok I pulled the whole steering thing at the servo apart, and now all the sudden it doesn't look broken at all :P
Anyone had problems tho that the steering thing in above picture jumped off the servo and you had to click it back in place?
