Official Tamiya TT-01 Thread
#5652
If you set everything correctly and use good batteries - you shouldn't have any cogging until the battery pack gets low. That's been my experience anyway and I have many sensorless brushless controllers.
#5653
holy cooling batman! those yeah racing high flow fans are the best out there, 2 for the motor? whoa, brilliant placement of the 9V by the way, well thought! looks great Andyjk. i am running a sensored novak with the ezrun 60A, and have some pretty heavy cogging on take off (see youtube link below) i have a 5.5t hobbywing on it's way, so i will see how that goes. i found that setting the punch to the lowest helps with the cogging. have you found performance difference when changing the timing? i guess i will find all this out when the 5.5t shows up, but curious non-the-less.
cogging: http://www.youtube.com/watch?v=GNVz70H4l68
this is a great thread!
#5654
I haven't played around with the timing at all, I don't fully understand what its purpose is.
Anyway, I have a GT350 Mustang body which I love to use but at high speed it loses control and cornering isn't the best either. I made a spoiler out of aluminium and it looks great. Massive improvement in stability. Here's some pics, ENJOY!
Cheers
Cheers
#5655
looks great, the down force really helps at high speeds i've found. you should experiment with the timing, could make a big difference, or not...
#5656
Well I don't want to play around with it until I know what it does lol.
So......what does it do? In my instructons it reads:
"There are many differences among structures and parameters of different brushless motors, so a fixed timing ESC is difficult to compatible with all brushless motors. It is necessary to make the timing value programmable. Please select the most suitable timing value according to the motor you are using. Generally, higher timing value brings out higher power output, but the whole efficiency of the system will be slightly lower down."
Hmmm....doesn't really tell me much, even after you get around the bad grammar. LOL
#5657
from what i've read here:
http://www.rcuniverse.com/forum/m_84..._1/key_/tm.htm
is that if you set it at 8, or the highest timing, you'll get higher top speed/better exceleration, but it will drastically reduce run time, and might run hot. buuuut, i have not actually found any difference from setting #1 to #8, i think because i am running a sensored novak motor with the ezrun ESC. i am really looking forward to the arrival of the ezrun 5.5t so i can get the full adjustability. do you have the program card? if not i would suggest it, $10 on the bay and makes it easy.
#5658
Yeah I've got the program card. My mate has the EZ run 5.5t motor and ESC. IT IS MENTAL. I think its a little too much power for it though. (Can't believe I just said that lol)
#5659
nice!, you can always keep off the throttle if need be. i just cracked my chassis, it's real easy to switch everything over. my ezrun 5.5t JUST turned up, i'll pop it in tonight and have a report and video soon.
on another note, i am not really a fan of drifting, especially the PVC tyre type drifting, but [link=http://www.youtube.com/watch?v=J8cP93yG1Ao&feature=PlayList&p=8D31FD784AC 3623A]drift[/link]THIS:
is pretty cool.
is pretty cool.
#5660
I'm in the process of picking up a used TT-01. It's coming with no batteries or charger. I currently have 2 low mah rotostart batteries from my Savage I plan to use temporarily. Knowing they'll be terrible what should I be looking to get? I understand I need a decent charger right, peak etc? Then batteries wise should I look for ni-mh or lipo? Ideally 2 decent batteries and a charger is what I want.
#5661
with this chassis i don't know if you wanna invest in lipo, just get a simple charger like THIS:
http://www.horizonhobby.com/Products...ProdID=DYN4056
and a few 5000mah packs like THIS:
http://www.rc-mall.net/acc.php?brand...=IN50006&type=
#5662
Thanks for the info, and I guess considering I'll use my Savage way more than the TT-01 the Lipos might be a waste.
To keep it local (Canada) would this work as well: http://www.greathobbies.com/producti...rod_id=DYM4063
Looks to be same spec to me.
ORIGINAL: cydog510
#5664
Ya too bad the battery packs are more than double the US sites...
Are Duratrax and Venom to be avoided? They seem to be easily available in my area.
#5668
nuts! so well done, i just drilled holes and popped the led in there. if anyone wants to know how to make headlamps that erun off a 9v, it is SUPER easy, cost me $4 for 3 sets for all my bodies. looks really good andy!
#5669
MB, CANADA
Hi guys,
I'm looking at getting a TT01 but unsure which version to get... I'm leaning towards the TT01ED but only body available is the lexus and it doesn't do it for me. (Can swap out the body I guess) Im going to be using it for drifting so that is why Im not sure if I should or shouldn't go with just the TT01E instead which has gazillion body's to choose from and then upgrade to drift specs.
Anyone want to try and make my decision a bit easier?
I am planning on going BL but I want to try to keep it under $100 plus lipo's. Is the ezrun 10T a good choice? Just for some fun weekly drift nights during the winter.
ORIGINAL: xc7
Hi guys,
Hi guys,
I would get the TT01ED because for just $50 more you get oil shocks ($26), bearings ($27), adjustable upper arms ($14), heatsink ($11) and sport tuned motor ($25). Since you're going brushless, you can sell the motor and heatsink and use the money to get another body
#5671
i agree in full. as for the ezrun combo, i would just get the 5.5t combo, more power for about $20 more, you'll always wanna go faster, why not just have the power available?
plus the whole number(10t, 13t, etc.) hobbywing motors have a smaller rotor, 350 i believe, where as the .5 numbered ones have a full size 540 rotor. more torque i think. here is the best deal on the bay:
http://cgi.ebay.com/EZRUN-COMBO-B4-5...item2a010c2e39
SO FAST! i just put mine in.
#5672
MB, CANADA
Thanks for info guys.
you got me going hmmmmmm
Are you running stock pinion with that motor ? Any breakage issues?
I'm planning on running 5000 mah lipo's
#5673
ORIGINAL: xc7
Hi guys,
Hi guys,
Feel free to PM me if you want to sell the body, I'm getting a used TT-01 with no body so I'm looking...
#5674
Well my Lipo yesterday took a crap...i am in need of a new chassis so what you guys reccommend? should i get 3R chassis, Stock Chassis, or Stock Chassis rally Style? I am running a ezrun Combo 9t but want to switch to MM???? not sure which motor.
The Car still runs its just where the battery goes it got completely melted.
here is the Aftermath!!
#5675
VA
Maybe thats why i haven't went Lipo yet[X(] Sorry to hear about your loss.. looks like some serious carnage. Got any pics of it after you peeled that body off?
