are these blades any good for cp pro?
#5676
RE: are these blades any good for cp pro?
Heli,
NO! thats not what I am saying. I am sorry I am suffering with the MOTHER of colds and am full ah drugs so forgive me.
What I was saying is; from what I have been following on your new Helicopter, it is "like" at TREX 450. If that is true, then those blades I showed you that are for a 450 TREX "should" fit. What I was trying to explain was that for ME to use these 450 TREX blades on my Blade 400 I must shim them as they are two thin to fill the 400 blade grips. The blades measure 2.16 millmeter in thickness if that helps. Measure the open area of your blade grips and see what you have there kiddo.
NOTE: Eflites are 6.6 mm thick
Nick,
THATS GREAT! I have my plane sitting here next to me in the hobbyroom trying to work up the power to fool around with it. I noticed on my DX6i there is a flap control too. So I am gonna put in a rx and then see what happens, the I'll get back to you.
JPEE
Nick,
JPEE
#5677
NE
Glenn,
Most of the snow is melted, but there is a few spots around town that still have a little bit of snow. I am just waiting for the wind to die down. There have been 30-40MPH gusts.
JPEE,
You might be able to do the same stuff that I am with your DX6i, but I am not familiar with the DX6i menus.
Nick
JPEE,
Nick
#5678
MD
Nick,
Stupid wind...lol..
Glad to hear that you got it all ready for it's maiden with the aileron/flap setup, should be interesting....
I'm not sure what my weekend weather is going to be yet, keeping my fingers crossed...
Be sure to let us know how the first flights go...
Glenn
Stupid wind...lol..
Glenn
#5679
Nick,
I just ran through the entire plane menue with the radio on and I tested (what I think) is every setting and switch flip to NO avail. So it may ned the DX7 to do what your trying for. Thanks for the offer on the DX7 programing help, but in a few days when my head is clear.
Good Luck
Good Luck
#5680
NE
Glenn,
Hope you get some good weather, so you can fly the 500 some more.
I sure hope the maiden is a crash free one. Even if it is, all I need is glue and tape. That would be nice if helis were like that. LOL
JPEE,
On the DX7 I had to activate the flaps in one of the menus that is near the menu to make a new model.
Nick
JPEE,
Nick
#5681
NE
JPEE,
I was looking at the DX6i manual online and you can have the ailerons act like flaps just like the DX7 can.
On page 43 of the manual you need to have the dual aileron selected in the transmitter. You need to have the left aileron in AUX1 and the right aileron in AILE.
On page 68-69 of the manual you need to select a value for the flaps. It is probably a negative number or will say DN or something like that. And the flaps are activated by the flap/gyro switch.
That is what I got from reading the manual.
Nick
Nick
#5682
MD
Nick,
Good luck on the maiden...
Yeah, if only helis were that easy to fix...
Hope the wind dies down for you soon.
Glenn
Glenn
#5683
Nick, thanks for the DXi info.
I have been sitting playing w/o reading to see if would come to me. I got it almost done but I could not get both to come down at once. What I read form you is I must had had the wrong Ali on the AUX channel. Will play more in a bit godda go eat. Old people like to eat on time LOL
THANKS AGAIN........................with all of this rederick Glenn will have to get a PLANE like it or not. I know Glenn is an Island kinda guy, but ALL of us but him have a plane......... he'll have to get one.
OH my vid was on the DX7 I just emailed you.
#5684
NE
JPEE,
I have been re-doing the ailerons on the CUB. I cleaned up the cuts on the ailerons, I used packing tape to get rid of the dihedral(sp), I made a 45 degree cut in the wings to help get more travel out of the ailerons, and re-glued the control horns. Now I have to re-install everything.
Your flaps look good on your video. Do you know you can change the positions on the switch for the direction the flaps go? I made position 0 the neutral spot, then 1 the flaps go down a little, then 2 the flaps go down a lot. You will probably be able to fly your plane before me, so you will have to let me know how it goes. Maybe Jeff can try it out on his Typhoon too.
Nick
Nick
#5685
CT
lol thanks jpee I gott confused for a minute, makes sense now. I will measure the grips when my heli comes in. Nothing today, ups says delivery is tommorrw
#5687
NC
I am also looking for alternate blades. Any comments on these http://www.dealextreme.com/details.dx/sku.15227 or http://www.dealextreme.com/details.dx/sku.15228 ? It seems you may be able to interchange the cp2 and walkera 22e with the cp pro. The walkera are a little longer, but wouldn't that flight a little more stable for a beginner like me?
#5688
ORIGINAL: bhsigman
I'am not familiar with those blades, but they could work... When I was first learning I ditched the lightweight woodies which were about 10 grams and went with a popular brand blade used by some that were called JCS Blades. There heavier design allowed things to slow up for me and tame the heli in my learning phases. If you go with a FLAT bottom blades you'll acquire MUCH more stability than if you were running the symmetrical blades FYI..... These blades are a tough plastic, and takes a lot to break them, but be warned since they won't break other parts could suffer more damage in a crash since the force has to go somewhere.
But they do provide great stability more than the stock woodies and come in different colors. I have a black set and a creme colored set... There is a pic below of one of those JCS Blades, and a CF symmetrical blade.
BTW welcome to RCU.....
http://www.jcshobbies.com/products_blade.html
~ Jeff
#5689
NE
bhsigman,
I had a CP2 head assembly on my CPP for awhile and the blade grips looked identical in size, so the CP2 blades should work on the CPP grips. However, I am not sure whether the Walkera blades will work or not.
JPEE,
Now I have a cold too. It is 30 degrees out, but feels a lot warmer with the sun and there is hardly any wind. It is almost perfect out to maiden the cub, but I can't go 15min without having to blow my nose.
Nick
JPEE,
Nick
#5690
MD
Nick,
Sorry to hear about your cold...that's a bummer, hope it's short one...
But, I'd rather have one in the winter, I HATE summer colds even worse...all that much more miserable!
Jeff, JPEE, Carl,
I am a dumb ass...LOL...
I have the same scale as JPEE, and just now realized that it reads up to 5000 Grams....I thought it was a 500 Gram max scale...LOL
So, later on, I'll try to remember to weigh my 500 for comparisons, since everyone "weighed in" theirs already...
Talk to you guys later....
Glenn
Jeff, JPEE, Carl,
Glenn
#5691
Nick ~
Dang sorry to hear ya have JPEE's cold. Ya I can't wait to hear a report on your Cub maiden, and it should make a big diff in the way you can maneuver the plane... You did a crazy fantastic job adding those Ailerons.
Glenn ~
Lol... See.... You have so many gadgets you forget what ya have ! I thought it was weird you didn't have one with all the accessories and gizmo's you have scattered about...LMAO... [8D] Yeah that will be interesting on the 500's weight. Cool....
We need B-400 weights also....... Reason being stock there 590 grams supposively, and now I want to see what they average out after gents have had them for a bit and added a few things like MG servo's, gyro's etc. etc. JPEE has three of them suckers so I'll nudge him for some weight specs also... [8D]
Heli ~
I know it came today............. Your quiet........................ [8D]
~ Jeff
Glenn ~
Heli ~
~ Jeff
#5692
Hey Nick, sorry to hear your sick too. That is exaclty how mine started. Did you get my last video using the DX6i? If so did it appear my alierons were moving in the correct fashion? Hows the plane coming?
Jeff, I'll weigh two of the three. Both are EXACTLY the same, servos, canopys, just everything. 544 grams and 534 WOW! I had not idea they were different. The only thing is the fiberglass canopys are not expensive so they could very. And the heavier the heli had stock eflite blades and the lighter one has the thinner T-Rex 450 blades. The third one has no electrics right now. It is a complete air frame only, including canopy and blades and such, just not esc, motor, servos, or gyro. It came in at 376 grams and they ALL had their blue foam blade holders on too.
Glenn, I thought one time we talked about having the same Harbor Freight scales but I did not want to call on you on it. Any Jeffs right as anside, you have more NEAT gadgets it was hard to believe you did not have the big scale.
Here is my new Heli 400 heli carrier. Only $40.00 to my door. Right now out of the box I can lay a 400 flat in "on top" of the foam and close the door nicely. If I pull the foam insert out the heli drops down deep inside. My goal is to play with it and see if I can reshape the foam so I can two 400's in there. They will fit now but it is the ANTI RUB factor I need to work on.
JPEE
JPEE
#5693
MD
Jeff,
LOL, yeah, that could be part of the problem, too much stuff!
I got my Align one way bearing tool with the canopy from Heliproz, for the B400 main gears...I have about 3 stripped gears with one way bearings in them, so I can buy just the 3 gears, and swap the bearings over in them...save a bit of $$$$
I'll get on the scale thing tonight, and I do have a 100% BONE STOCK B400, for comparison. Still got everything original, even the blades..lol...should be interesting...[X(]
Glenn
Glenn
#5694
NE
JPEE,
The only video I got was with the DX7 that you sent yesterday. I finished the CUB last night. I now have a lot more travel than before after I re-did the ailerons last night. The servos will go to the end of their travel before the ailerons reach the end of their travel.
Nice heli carrier.
Glenn,
Cool to hear you got a one way bearing removal tool. They have been life savers for me with the Belt CP and 600.
Nick
Nice heli carrier.
Glenn,
Nick
#5695
CT
well guys just got my heli only thing I didn't like with xheli is the brushless motor didn't come in :/
they never said it was back ordered or anything, just sent me a card in the box saying it could be 2-4 weeks ahhh
I might just get my money refunded and buy it elsewhere
#5696
MD
Heli,
AWESOME...take some pics!!!
How does it look otherwise, aside from the motor issue?
Wonder why the motor is delayed, any explanation?
That is cool that you got it OK, since we were a bit skeptical of Xheli....
Glenn
Glenn
#5697
MD
Hey guys,
Just got my screws from RCscewz...the ones that were not in the 500 stainless kit...for the TT version...
I was expecting 6 of one size, and 2 of the other size that I didn't get in the kit...
He sent a bag of 25, and 15 screws, respectively...
I can honestly say that RCscrewz is a class act, he shipped them priority mail, at no cost to me....and fast too...
Glenn
Glenn
#5698
NE
Glenn,
Cool to hear RCscrewz is a good company and that you got a lot of extras.
Heli,
Cool to hear you got your heli. Sorry to hear about your motor. Does your LHS have a 450 sized motor?
Nick
Heli,
Nick
