The Official Tamiya TA05 Thread
Old 09-03-2008, 11:03 AM
  #551
rcluke
rcluke's Avatar
Default RE: The Official Tamiya TA05 Thread
for a 7.5T brushless motor, you want to be running about 7.0:1 in a touring car.
with a 112T 64dp spur gear, you want about a 36T 64dp pinion gear
Old 09-03-2008, 12:03 PM
  #552
[email protected]
Hi. Thanks for the info, I'll try that gearing I'll let you know how it goes. Cheers Ray.
Old 09-05-2008, 06:35 PM
  #553
dragon2k2
how good are TA05 for racing? i am a off road guy so i know nothin bout on road cars but i was thinkin bout buyin the TA05
Old 09-06-2008, 04:00 AM
  #554
[email protected]
Hi Duncan. Iam new to this game myself, I have read a lot about the TA05 and it seems very competitive in the right hands. I bought mine secondhand and it's all blinged up with anodised parts on, I have not run it yet just getting round to putting motor & ESC in. Cheers Ray.
Old 10-09-2008, 12:24 PM
  #555
theheadhunter
I got my TA05 this week and need to ask ;
1. When I look for wheels and tires which measurements do I need to follow?
2. Some wheels I've seen online mention "offset 6mmor 4mm" does this mean they stand out wider regardless to tire size?
3. Are most tire widths the same and do I need to match the wheel width to the tire width ?
4. I have a 10kg MG946R TowerPro servo spare at the moment will this do? What is an ideal servo for these cars?
My previous RC experience is all off-road so I'm pretty green on this build ...
Old 10-10-2008, 05:07 AM
  #556
[email protected]
Hi. Iam new to this game myself. I buy 1/10 scale wheels & tyres already with tyres glued on, 12mm hex fitting. 10Kg servo will be ok.What they mean by offset have not got a clue.? You'll have to ask someone with more experience, Best Regards Ray.
Old 10-11-2008, 10:12 AM
  #557
xxCARLOSxx
xxCARLOSxx's Avatar
offset means how deep the inside of the rim is. its hard to explain so look at these too pictures closely on the inside of the rims. i dont think it affects the width of the rim though
ID:	1049700   Click image for larger version
Old 10-12-2008, 08:53 PM
  #558
mkoresh12
Offset is generally measured from the back of the rim to the mounting area. Take a ruler(or something else that will lay flat) and lay it flat across the back of the rim, then measure the distance from that to the mounting area and there is your offset. This will determine to an extent how far the wheel/tire combo will stick outside the fender area. Obviously body width and tire width will play a part as well. To much/little offset and the wheel may not fit. For instance, the 28mm wheels I had on my car had weren't offset correctly and the rim had too small of an inside diameter, the result was the rim rubbing the ball link through on the front during cornering.
Old 10-13-2008, 02:45 AM
  #559
[email protected]
Hi carlos. Thanks for the info,much appreciated. Cheers Have a nice day, Ray.
Old 10-14-2008, 01:29 AM
  #560
xxCARLOSxx
xxCARLOSxx's Avatar
np dude anytime
Old 11-18-2008, 11:27 PM
  #561
LM4tec
Hey i just got a TA05. The upgrades i have on her is trf shocks and alluminum rear diff cups in the rear. Is there any upgrades i can do to the TA05 to make it more competitive but, not break the bank? Also, what gearing should i run? I want to run 64p spurs. The highest pinion i have is a 35t. If i want more speed do i get a bigger or smaller spur? I am going to run the rubber class with a peak racing 19 turn motor and a Novak TC ESC. Thanks. Tekno.
Old 11-21-2008, 04:31 PM
  #562
gman1
Hey guys. Im in the process of building the TA-05 IFS kit and have come across a problem with my servo being too big to fit in it's place on the chassis. The servo i have chose is a Hitec 311 which i believe is standard size for most servos. So my question is if i will have to trim some of the plastic off the servo ears in order to make it fit, or is there another way to solve this issue. Thanks as always guys.
Old 11-22-2008, 03:21 PM
  #563
macscac
well my ta-05 was received yesterday.
starting building it last nite.... sure love building cars!!!
having never built anything more than a FF-01 and a couple TL-01's, the TA-05 is a bit more difficult.
anyhow lots of fun!
ordered my first round of xtras this AM...
cant find a carbon chassis anywhere so im stuck w/ the base at the moment.
but i did grab some 3racing shocks and front and rear aluminum bulkheads...
too pricy to deck the car out at once... this will be a long term project!!
any suggests on the next round of parts?
Old 11-29-2008, 01:46 AM
  #564
xxCARLOSxx
xxCARLOSxx's Avatar
ORIGINAL: gman1
yup u have to trim the plastic a little...
ok guys im a noob and i dont really understand what pinion gear to buy for my ta05 ifs-r. the stock spur gear is 105t i think, i want to buy the 5700k mamba max system, and i have a 3600 6c battery. which pinions should i buy?
edit: also what is the "Front/Rear Differential Gear Ratio" and "Transmission Gear Ratio" of my car?
Old 11-29-2008, 02:11 AM
  #565
xxCARLOSxx
xxCARLOSxx's Avatar
ORIGINAL: macscac
anyhow lots of fun!
i found sumthing 4 u http://www.rcmart.com/catalog/rc-ta0...4523ab5d8e7385
Old 11-29-2008, 11:25 PM
  #566
Mash13
Hey Fellas,
I just finished building my TA05 IFS, installed the stock silver can and an old XL5 (ex stampede) ESC. I was looking to start in the 540 class at my local club, but was so disappointed with the 540 can I legged it down the LHS and bought a LRP Sphere TC comp spec esc, LRP Vector 17.5 stock brushless motor and 54002S lipo I also got a new 69T 48P spur gear. the problem I have is this: how do I solder the esc to the motor as you can see on some of the pics the solder tabs have small holes in them and I wasn't sure if you stick the wires through these holes when soldering (I just wanna make sure I do this right)
Also when connecting the lipo to the esc, can I just solder on two corally plugs on the end of the esc wires and plug them dirctly into the lipo, or must I go esc-wire-deans-deans-wire-corally-batt (if that makes sense to you )
ID:	1081180   Click image for larger version
ID:	1081181   Click image for larger version
ID:	1081182   Click image for larger version
ID:	1081183   Click image for larger version
ID:	1081184   Click image for larger version
Old 11-29-2008, 11:36 PM
  #567
xxCARLOSxx
xxCARLOSxx's Avatar
dam that thing is gonna fly!
Old 12-03-2008, 12:26 AM
  #568
macscac
ORIGINAL: xxCARLOSxx
very cool!
someone on rctech referred me to a shop in auburn,wa last week who had a 3racing chassis in stock as well
i actually just got it in the mail saturday!
thanks for the link tho
Old 12-07-2008, 02:31 AM
  #569
xxCARLOSxx
xxCARLOSxx's Avatar
np post sum pics when u get it all set up i bet it looks sik!
Old 12-10-2008, 08:08 PM
  #570
booey
does the mamba max esc fit in the ta05, I just got the arta nsx kit and its a pretty nice kit, really good quality, just need esc,servo,radio and such, suggestions on what to get would be cool, and also what wheel offset would I need to run 200mm bodies[sm=thumbup.gif] thanks this site rocks.
Old 12-11-2008, 12:14 AM
  #571
xxCARLOSxx
xxCARLOSxx's Avatar
ORIGINAL: booey
i've seen at sum forums that it doesn't fit but i bought it anyways online today and i guess ill have to modify the chassis
idk about the wheel offset, but i dont think it makes a huge difference
oh and yeah... this site definitely rocks good luck with everything!
Old 12-11-2008, 08:31 PM
  #572
gbasile77
gbasile77's Avatar
I was looking at getting a TA-05 IFS, but was not sure if it would accept my existing lipos.
My packs measure 137mm long, 44.2mm wide and 26.6mm thick.
Would these fit without any mods?
Old 12-16-2008, 09:48 PM
  #573
brownstone101
brownstone101's Avatar
bump/
i got a question about dose anyone know were to find setup sheets for the 05? or dose anyone here have a setup sheet of there car?
im got a 19T spec motor and rubber tires gona be practicein on a decent grip carpet track just wondering if anyone here can give me a decent starting setup?
thanks
Old 12-16-2008, 10:50 PM
  #574
littleleon
I think if you go here:
[link]http://www.petitrc.com/view_news.php?id=4622[/link]
There will be a couple of initial setup sheets if you follow the TA05 link.
Old 12-17-2008, 01:41 AM
  #575
brownstone101
thanks that helped. its almost set to that already but im going to key it in and get some track time and work on it some more. thanks
