#5851
RE: Welcome to Club SAITO !
Just ran my Saito 1.25
Prop=Master Airscrew Classic 16x6
FUel == WildCat 15% nitro with 18% 80/20 blend
Plug==Saito SS
RPM==9,390 peak.
Spool up, kept up with throttle movement.
Plug==Saito SS
RPM==9,390 peak.
#5852
MI
I need some help from the Saito Mavens.
I have to 82's and just bought a used 150. The manual says to start the high speed needle 5 turns out but says nothing about the low speed. On my 82's they came with the low speed set about flush with the top but on the 150 I got, that screw is about 3 turn past the top.
What is a good starting point for the low speed needle?
I tried to search in this thread before asking a question that may have been asked and answered 10 times but I couldn't get it to work.
Ed
Ed
#5854
Ed
Your low speed needles are correct on the 82's for the beginning break in. You will have to screw them in a couple turns as you get them broken in.
If your used 150 has a plastic throttle arm someone has already set the low speed mixture. I would try it there and see what you have.
If your used 150 has a steel throttle arm the needle is in too far. When the needle is about right with the steel throttle arm, the screw is about flush with the outer surface.
#5855
AZ
I bought a Saito 100 from a guy that hasn't been run yet. He couldn't find the muffler, muffler nuts or manifold. When I look at the manual's exploded view there appears to be a "muffler gasket" between the manifold and head. Is this a washer? Is it aluminum, stainless? Does anybody know where I can get one? It doesn't seem to have a part number. Thanks.
#5858
WI
I have a RCV 91CD which is a messy engine. It blows a lot of oil out of the crankcase vent. One of the ways to minimize the mess is to install a nipple on the exhaust manifold (not the muffler) and run a piece of tubing from the crankcase vent to the new nipple. The method is approved by RCV and the engine suffers no ill effects. Has any one tried doing this on a Saito? Before I do it on my 91 I thought I'd check with other users.
Larry
Larry
#5859
MS
Give this a try and let us know how it works out. I usually just run my crank vent tube out the bottom. I don't notice much residue on the airplane related that that. One thing to keep in mind is to make it where you can use afterrun oil, we wouldn't want any rust on any of these great engines.
#5860
AZ
ORIGINAL: Birman
Larry
Larry
#5864
By installing a nipple in the exhaust stream prior to the muffler the highspeed gasses act as a venturi and siphons or creates a low pressure in the line coming from the crankcase. This will pull the excess oil and add it to the exhaust stream. The reason you get pressure to the fuel tank from the nipple on the muffler is because the outlet of the muffler acts as a restriction and causes a pressure rise in the muffler itself. I hope this sheds some light on this for you.
#5866
ORIGINAL: turboapache
[link]http://www.horizonhobby.com/Search/Default.aspx?SearchTerm=sai182td1112&CatId=[/link]
Is the nipple used to pressure the tank or connect to the crankcase to pull out the excess oil?
AZ
#5868
if you install the crankcase vent line to the exhaust you will burn your engine up, simple, no oil will get to the bottom end. dont do it. the vent has to go to atmosphere on a saito
#5869
ORIGINAL: IronCross
Isn't that kind of like saying water in part of the hose is moving at 1000 gallons per second but only coming out at 100 gallons per second ?... Hard for me to visualize... I would have asumbed the pressure in the hose was the same from source to outlet... ???
Pressure and flow are two different things. You can have a 1000 gal/minute flowing from a given orifice but at low pressure. You can also have the same 1000/gal minute flowing from a smaller orifice at a much higher pressure. It all depends on the restriction.
To follow it to the other end of the scale, I seem to recall also from my dim dark youth a law of compressability: A force exerted on an (enclosed) liquid will be transmitted equally throughout that liquid. This is pressure and is a basic pricipal of hydraulics I think.
Does this help any?
#5870
AZ
ORIGINAL: Thunderchild
Ironcross,
Does this help any?
ORIGINAL: IronCross
Does this help any?
I think Jim had the best idea by just running it along side the muffler...
#5871
I think maybe you are confusing pressure with volumetric flow. It is not pressure we are dealing with in this instance but the hot expanding gasses flowing at high speed past the nipple in the stream. As a gas or liquid moving at speed passes from a small area to a large area you get a pressure drop as when going from the manifold to the muffler and pressure rises when it gets to the exit of the muffler because of the restriction at the end of the muffler. Think of drinking thru a straw with a small hole in it. What happens? The same principle as a paint spray gun. The air flowing at high speed pulls the paint into the stream and atomizes it. Hope this helps and if not just let me know and I will be quiet.
#5873
Manufactures are using the same principle when they hook the vent to the intake. The air moving thru the intake is a low pressure area and draws on the vent.
