Reaction 54 Jet Kit
#576
My Feedback: (10)
RE: Reaction 54 Jet Kit
ORIGINAL: mach1-RCU
F-54
Here's a few pics of my ready to cover R54. (newly designated F54)
Will use P60 for power.
Warren G. Hunter
F-54
Warren G. Hunter
LOVE the mods, great model building.
bobparks2, are you the Bob Parks I worked with on special projects a dozen years ago?
#577
I got my R54 framed out last January, and have not had time to work on it since. Maybe this winter! I have an, as yet untested, kit built, Wren 54 MKIII for it.
BTW, Wren makes a nice new mount that is ideal for the R54. Its a band clamp type, but designed to be bolted down directly to a single plate. You will need a shim to get the thrust line, but its lighter, cleaner and looks better than the typical tab type mounts with brackets. I tried linking a photo, but the system wont let me right now. Its on the Wren web site. I also have the FOD screen front end for it. The only problem is the green Wren clashes with all the color schemes I want to use on the R54!
Bob
#578
My Feedback: (10)
Hi Bob,
Nice to talk to you, sorry for the questioning, you never know out here in the RCU Wild West!
I have not opened the box on my kit yet, work and family has taken the hobby to a slow crawl (not even sure if the crawl is forward or backward!)
PS I just got the Nova "Battle of the X Planes", have you seen it....I thought it was excellent!
Talk to you later,
Talk to you later,
#579
Hey Warren, I love it! Very creative - can't wait to see what kind of color scheme you come up with to compliment the new shapes...
Take Bob Parks comments as constructive criticism and keep an eye out for excess heat. The kit comes with a stainless steel sheet to install above the engine and I suspect that will still protect the fuselage just fine.
Tommy, I also love what you've done with your #2 Reaction! You guys should really be proud of your craftsmanship.
#580
My concern is ahead of where the stainless normally is. There is the potential to recirculate some exhaust gas if the scoops are not providing enough air to match what the engine needs plus some to give a bit of bypass flow around the engine.
My Wren 54 wants to ingest about .4 lbs of air per second, which is about 5 cu ft per second. At 100 mph, thats about 5 sq in of inlet area, but thats assuming really good clean inlets, and you still want some extra for bypass. Part of the concern with those ducts is that it looks (from the photos) that the cross section area gets really small as it goes past the wing high point, and then does a pretty rapid divergence from there aft, and that is going to cut the airflow through there.
If enough flow doesnt get into the base region to feed the engine, then its going to suck it in from behind, and with the blunt base that could pull in some exhaust gas.
Like I mentioned, I am not sure if this will be a significant problem, but its worth keeping an eye on things for the first test runs and test flights.
And it will be a bit less thrust and more drag than the stock setup. It should fly just fine, but it certainly will not be faster in level flight.
Finally, I have had to learn a lot more about these kind of things than I really wanted to for a current work project... but putting a 700 lb thrust cruise missile engine into a 10 ft span airplane is kind of interesting.
Bob
#583
Actually, the flow through the inlets is quite good in 'static tests' with 70+ mph flow. Will have to see what the real world brings.
That color scheme looks FANTASTIC! Would you mind if I "borrowed" it for mine?
Bob
#587
Bob,
Here's the inlet dimensions.
Sure does look neat!
Bob
#589
OR
Looks very nice, will certainly attract a crowd. Have any idea where you will be weight wise? Just trying to get an overall feel for what guys have been finding themselves at. Am also wondering since it looks like you glassed this one.
CR
CR
#590
Bruce,
It is a tribute to the great basic design of the R54 that we are "Customising". Warrens is really radical and should look great in the air. I am just trying to make mine a little more "Slippery".
Noel is getting on with his and we are both going to a jet meeting tomorrow. Hope I can show what the R54 can do.
Regards
Regards
#591
My Feedback: (18)
Just wondering if anyone has used the three hour epoxy for joining the wing halves as Bruce has suggested. Although I haven't looked locally, there doesn't seem to be much online. Thanks.
Marty
Marty
#597
My Feedback: (18)
Rcman58,
If you decide to go with the recommended Hitecs suggested in the manual, Check out Servo city. They are having a 20% off all Hitecs this week only. Could save you a couple of bucks. Wish I new about this a week ago[:@]
http://www.servocity.com/html/hitec_servos.html
Marty
Marty
#598
afterburner that is what I had in mind is the manual on line somewhere I need the list of servos Thanks
ORIGINAL: afterburner
Rcman58,
Marty
Rcman58,
Marty
#599
My Feedback: (18)
I'm not sure if the manual is online. Here's the recommended minimum (torque wise) Hitecs:
3 HS-5625MG. 2 for ailerons, 1 for rudder.
3 HS-5645MG 2 for flaps, 1 for elevator
2 HS-225MG Nosewheel steering and Retract valve.
Marty
Marty
#600
I use the same as Marty, but I use Hitec 5245 Mini servos for the steering and brakes so I can program the travel. The steering and brakes are mixed to other chanels and it makes the setup simpler.
I also use a 5245 for the retracts because I had one spare.
Never had a problem with Hitec, and I don't use standard (Non Digital) any more. I think Digital servos just "Feel" better. Just be sure to use a big battery. You need the nose weight anyway. Mine is a 2100 Mah 5 cell pack used WITHOUT a regulator.
regards
regards
